Hi all,
Context
I am sorry if this is a silly or repeated question, I’ve made a few searches but couldn’t really figure my head around this.
So to give a little insight, I was using the HomeBridge integration for HomeKit but I’ve become a little fed up with plugins that don’t work and a very slow response (and most times insufficient) from the community.
Some example of things that didn’t work there, my Panasonic Viera TV, couldn’t even add it, Home Assistant was a zero effort config, Broadlink RM4 Pro there didn’t give me temperature and humidity information, here is always up to date, and so on.
At the same time I’ve recently started discovering Home Assistant, I was very positively surprised by seeing that adding all these devices was a simple and zero effort task, everything works well, just wasn’t connected to the HomeKit, instead been using the Home Assistant app on iOS. So I had sort of the systems in parallel. Now, I’m shutting down HomeBridge and would like to make everything work via Home Assistant.
Configuration steps
I removed the bridge of homebridge and all sub-bridges and all devices were removed from HomeKit this way.
Next I went to Home Assistant, added a HomeKit Bridge, and selected:
HomeKit Mode: bridge
Inclusion Mode: include
Domains to include:
- Alarm Control Panel, Binary Sensor, Climate, Cover, Fan, Humidifier, Light, Lock, Remote, Sensor, Switch, Vacuum;
Entities to be included: I’ve selected SOLELY:
- RM4 Pro Humidity (sensor.broadlink_rm4_pro_humidity);
- RM4 Pro Temperature (sensor.broadlink_rm4_pro_temperature);
- iRobot (vacuum.irobot);
- iRobot Bin Full (binary_sensor.irobot_bin_full);
- iRobot Battery Level (sensor.irobot_battery_level);
- Smoke detectores (several - binary_sensor.smoke_detector_X sensor.smoke_detector_X_battery and sensor.smoke_detector_X_smoke_amount);
Advanced Configuration - Device (Triggers):
- I have selected NONE.
My objective on this first stage lets call it that, is to ONLY ADD these to my HomeKit / Home App: sensors and the iRobot.
Results
So I was expecting to get the sensor information from the sensors of RM4 Pro, the iRobot vacuum state (working, stopped, bin, battery); and from the smoke sensors. This is like the first step starting with easy stuff that was working well with Homebridge PLUS the temperature and humidity sensors from the Broadlink device.
When I scanned the bridge QR code, it added:
- An Airport Express that is on the network, completely useless add);
- The Bedroom Apple TV (its an Apple TV 3);
- My 4K Apple TV which is already on Home;
- The iRobot;
- The Panasonic TV;
- Broadlink RM4 Pro REMOTE (beside the sensors)
All of these show as “No response” on the Home App.
I have “8 Accessories No Response”.
I didn’t ask or selected the broadlink remote - only the sensors, I didn’t select the Panasonic TV, I didn’t select any Apple TV’s. So, why is this throwing me all these bunch of stuff I never selected to appear?
The smoke alarms don’t show. The Broadlink RM4 Pro temperature and humidity show as “no response” as well.
Any hints appreciated, thank you!
EDITS: text styling and some corrections
