Homematic IP Local - Bind a custom Window sensor to thermostat
I made modified version of sota’s blueprint:
Many thanks for this.
My blueprint is working with the homematic ip local addon for the CCU. With this you are able to bind any binary_sensor to an homematic ip thermostat.
blueprint:
  name: Window Open, Notify HomeMatic IP Local CCU
  description:
    An automation blueprint that reduces the set temperature of your climate
    device or group if a window sensor is open for more than the preset wait time.
    It uses the Homematic window sensor channel to set the temperature to the "Open-window
    temperature" set in the device configuration. You should set the "Mode for temperature
    fall detection" to Inactive to avoid conflicts. It waits until the window is closed
    again in order to restore the climate entity temperature. It has an optional blocking
    entity to prevent the automation running unnecessarily, for example during the
    Summer season.
  domain: automation
  input:
    window_entity:
      description: The window sensor that will control the climate entity.
      selector:
        entity:
          domain: binary_sensor
          multiple: false
    open_delay:
      name: Windows Open Wait Time
      description: Time to delay after window opens before notifying HomeMatic.
      default: 30
      selector:
        number:
          min: 0.0
          max: 600.0
          unit_of_measurement: seconds
          mode: slider
          step: 1.0
    blocking_entity:
      name: (OPTIONAL) Blocking Entity
      description:
        If this entity's state is off, it will prevent the automation from
        running. E.g. summer mode or away mode.
      default:
      selector:
        entity:
          domain: input_boolean
          multiple: false
    climate_entity:
      description: The climate entity that is controlled by the window sensor.
      selector:
        entity:
          domain: climate
          multiple: false
  #source_url: https://gist.github.com/smoki3/9e38e03d6ae180326ab1c80282ec6d78
  #based on: https://gist.github.com/sotatech/500b53ee64ca5ad5299c22cde47407ed
variables:
  blocking_entity: !input blocking_entity
  climate_target: !input climate_entity
  climate_id: "{{ device_id(climate_target) }}"
  open_delay: !input open_delay
  - platform: state
    entity_id: !input window_entity
    to: "on"
    for: !input open_delay
condition:
  - condition: template
    value_template:
      "{{ (blocking_entity == none) or (states[blocking_entity].state
      == 'on') }}"
  - service: homematicip_local.set_device_value
      device_id: "{{ climate_id }}"
      channel: 1
      parameter: WINDOW_STATE
      value: "1"
      value_type: int
  - wait_for_trigger:
      - platform: state
        to: "off"
    continue_on_timeout: false
      channel: 1
      value: "0"
      value_type: int
mode: restart
max_exceeded: silent
should i connect this blueprint with the Homematic Heating group, or the wall thermostat in this heating group?
If set to heating group. Temp goes down, but no window open icon on the wall thermostat.
If set to wall thermostat, the icon is shown, but temp does not go down.
Also is there a way to prevent manual increase the temp after the window was opened?
I use HomeMatic Groups and it works fine - the temperature is changed and the open window icon appears on the thermostat. If you look on the CCU does the setting change there?
I recomment to connect the blueprint to the heating group.
The window open symbol appears on then on all devices in this group. (thermostat and wall thermostat)
You have to be patient. Homematic IP took some time to sent the commands to all devices. So try to open the window an wait 2 min. Then look in the CCU if the command has been sent so all devices without any error.
Thank you for the blueprint, works for me with aqara zigbee sensors.
Is it possible to set a delay after the window is closed, so the thermostat won’t set itself back after a few seconds?
My homematic ip thermostat usually waits a few minutes (because without window sensor, he probably has a fixed time when the “window open” has triggered)
I would like to set it to something like 3-4 Minutes, because after i ventilate my flat i would like to wait for the thermostat to adjust to the new room temperature, rather than setting itself back to like 22°C after he got 4°C cold air.
in the actual blueprint it is hardcoded with 5 seconds:
  - wait_for_trigger:
      - platform: state
        to: "off"
        for: 5
But I can implement also a slider for this
@onimoschta
I just pushed a new version. So could you please test if it is working?
Yes, after examining the code (im not really good with programming) i changed the 5 seconds manually, but your change with the slider works great! thank you.
After using this now for about 3 months i sometimes get a thermostat stuck in “window open” state.
Did you or somebody else also experience this?
It happens really rarely and i think it happens because of the internal “window_state open” within the thermostat itself, triggered by a slow drop in temperature (opening a window).
When the window is closed and the blueprint state change is about to happen while the thermostat internal state-change is about to trigger “window open”, it probably causes this problem. Usually it should revert back in about 10 minutes as if you had no window sensors, but it does not.
I had it a few times, only locally switching from auto to manual and back will resolve the issue (hope my explanation was somewhat understandable).
Hi , there is not much to configure in your blueprint, but doesnt work for me. Im not an programmer, can you tell me, what the failure means:
Thanks!
Hey… I’m using your blueprint to switch a thermostat with a shelly blu window sensor. my ccu is Raspberrymatic on HomeAssistant.
If the window is left open and temperature reduced to 12C, the heating profile overwrites the temperature as soon, as the setting in the profile activates a new temperature.
How can i solve this problem?
Greetings… :slight_smile:
Just in case anyone still searches for a solution: I enhanced this blueprint to not only set the WINDOW state but also to switch the Thermostat into manual mode (and back to automatic mode, if window is closed). Here is the code:
blueprint:
  description:
    temperature" set in the device configuration. Also MANUAL mode is enabled, as long as the window is open, to prevent a schedule from overwriting the temperature. You should set the "Mode for temperature
    again in order to restore the climate entity temperature after 5 seconds. It has an optional blocking
    Summer season.
  domain: automation
  input:
    window_entity:
      selector:
        entity:
          multiple: false
    open_delay:
      default: 30
      selector:
        number:
          min: 0.0
          max: 600.0
          mode: slider
          step: 1.0
    close_delay:
      name: Windows Close Wait Time
      description: Time to delay after window closed before notifying HomeMatic.
      default: 5
      selector:
        number:
          min: 0.0
          max: 600.0
          mode: slider
          step: 1.0
    blocking_entity:
      description:
      default:
      selector:
        entity:
          multiple: false
    climate_entity:
      selector:
        entity:
          domain: climate
          multiple: false
variables:
  close_delay: !input close_delay
  - platform: state
    to: "on"
condition:
    value_template:
      == 'on') }}"
      channel: 1
      parameter: CONTROL_MODE
      value: "1"
      value_type: int
      channel: 1
      value: "1"
      value_type: int
  - wait_for_trigger:
      - platform: state
        to: "off"
        for: !input close_delay
      channel: 1
      value: "0"
      value_type: int
      channel: 1
      value: "0"
      value_type: int
mode: restart
Great!!! Thank you very much for your efforts, this should solve my problem.
Is there a easy way to update the blueprint in my HA?
