I use HomematicIP to control my heating system with wall-mounted thermostats and thermostatic radiator valves (TRVs). Homematic supports linking these devices with window/door sensors, so that the set temperature is reduced when the window is opened. As I already had wired window alarm sensors connected to HA via MQTT, I was unwilling to go to the trouble and expense of adding about 30 additional sensors to all my windows.
I adapted this blueprint some time ago from another one that was posted here, but now I have forgotten who created it! So this is not all my own work, and if the original author contacts me, I will credit him/her here.
This blueprint was adapted from @SmartLiving.Rocks Blueprint Window open, climate off
I use Groups in HomeMatic to link my devices, so I recommend that you control the room temperature using the relevant group climate device.
Any suggestions for improvements are most welcome!
blueprint:
name: Window Open, Notify HomeMatic CCU
description:
An automation blueprint that reduces the set temperature of your climate
device or group if a window sensor is open for more than the preset wait time.
It uses the Homematic window sensor channel to set the temperature to the "Open-window
temperature" set in the device configuration. You should set the "Mode for temperature
fall detection" to Inactive to avoid conflicts. It waits until the window is closed
again in order to restore the climate entity temperature. It has an optional blocking
entity to prevent the automation running unnecessarily, for example during the
Summer season.
domain: automation
input:
window_entity:
description: The window sensor that will control the climate entity.
selector:
entity:
domain: binary_sensor
device_class: window
open_delay:
name: Windows Open Wait Time
description: Time to delay after window opens before notifying HomeMatic.
default: 30
selector:
number:
min: 0.0
max: 600.0
unit_of_measurement: seconds
mode: slider
step: 1.0
blocking_entity:
name: (OPTIONAL) Blocking Entity
description: If this entity's state is on, it will prevent the automation from running. E.g. summer mode or away mode.
default:
selector:
entity:
domain: input_boolean
climate_entity:
description: The climate entity that is controlled by the window sensor.
selector:
entity:
domain: climate
source_url: https://gist.github.com/sotatech/500b53ee64ca5ad5299c22cde47407ed
variables:
blocking_entity: !input blocking_entity
climate_target: !input climate_entity
climate_id: '{{ state_attr( climate_target, "id") }}'
open_delay: !input open_delay
- platform: state
entity_id: !input "window_entity"
to: "on"
for: !input "open_delay"
condition:
- condition: template
value_template: "{{ (blocking_entity == none) or (states[blocking_entity].state == 'off') }}"
- service: homematic.set_device_value
address: "{{ climate_id }}"
channel: 1
param: "WINDOW_STATE"
value: 1
- wait_for_trigger:
- platform: state
to: "off"
continue_on_timeout: false
channel: 1
value: 0
mode: restart
max_exceeded: silent
