Here is HomeOS. (finally)
I rewrite the entire code to simplify the sharing of the code. Still not perfect but getting there.
And I completely change my approach to Home Assistant installation, now everything run into separate container, welcome to almost High Availability
I'm running Home Assistant in a docker container on a NAS DS920+.
The Wall Mount tablet is a FireHD 10 from amazon running Fully Kiosk Browser.
I think you referring to sensor.montreal_icon_code.
If that’s the case, it’s a sensor provided by the Montreal environment canada integration. (Weather integration)
Hello Avenger11,
I have a problem with the card person on the right. I have no blur effect on the background. the card also does not take the foreground image.
can you help me ?
Hi, im new to this and do really like your dashboard, and tried to install it on a new HA installation, but just got an error, have installede all of the custom things from HACS, but i think i am doing it wrong… I cannot find a guide on how to import a dashboard…
I’ve been looking at your beautiful dashboard and I’m planning to use it myself. I’ve already added the following folders to my config folder: www, thema, popup, custom_module_card, custom_icons, and custom_card_templates. However, I’m still getting this message. I don’t quite understand what’s going wrong. I hope you can help me?
@Montreal666@Jarne_Roussard I’m currently changing the way the code was split, it will be easier to share. I started create a more extensive documentation for integration, starting by the weather card.
Can you try it out and let me know what are the issues ?
this is a fantastic design I would like to use it with my HA installation. You said you are still working on the code to make an import easier. Can you tell me a release date? Can‘t wait
