You have two options: Power the device with USB or batteries. If you use batteries the watermeter pushes 4 times a day to the HomeWizard cloud, it is not possible to add the device to Home Assistant.
If power the device via USB you can integrate the watermeter in HA, it refreshes every 5 seconds. No hub needed.
Well⦠I donāt have it yet. I can buy one with a discount, therefore I would like to know upfront if itās compatible with my watermeter. But I guess some versions are supported, so I can take the riskā¦
Is it possible to access watermeter data from server? I can not use USB because there is no power supply, but i wpuld like to still import data to HA (not with local API).
I have bought a watermeter from Homewizard but no matter what I do I canāt get it connected to the App. I already tried all the troubleshooting steps:
Disabling 5 GHz
Disabling mobile data
Even disabled my mesh, to only have a single WiFi provider
Disabled all DNS filtering rules
The device connected succesfully to Wifi a few times (can see itās IP adress in my router), but still the App tells me that setup failed. I also had the constant breathing green light.
After trying it da dozen times, it wonāt connect to any Wifi anymore. Not even a mobile hotspot on a second phone, itās always blinking green and then red.
I already reached out to the helpdesk but didnāt get an answer from them. Is there a way to completely reset the watermeter and delete any saved Wifi credentials? Also is there another way to enable local API than using the App?
Ok, for whatever reason, after the like 46743 try it suddenly worked. Itās connected now for 4 hours and works perfectly. I did not change anything it just connected as it should and appeared in the iOS App. Local API activated and it worked in HA as it should.
But thanks for your help anyway! Iāll remember the reset button if needed.
A bit offtopic maybe, because the integrated HomeWizard plugin in Home Assistant canāt do this as far as I know.
I donāt have any utility power at my watermeter location, so I use batteries and I upload waterusage 4 times a day to the Homewizard cloud. Iām trying to find a way to pull the waterusage from the cloud API and store it into Home Assistant. Does anyone know about such integration (preferably via HACS)? If not, does anyone have documentation about The Homewizard cloud API or reversed engineered it?
Hope there will be a way to do this. Other option I see will be a hardware mod to make it a BLE device. Iām also open for other suggestions, even for other devices that last a long time with batteries and can be integrated into Home Assistant.
