Thanks for your advices.
I wiped the device with dd (very long time …), then flashed again with yellow installer : same behaviour. Impossible to boot with the NVME installed on the board and also imposible to boot with the NVME SSD in the USB Dock. (used as an USB stick ).
After that, I made several tries :
With Raspberry Pi Imager :
- I Installed directly HAOS 9.2 on the SSD : No Boot !
- I installed the « yellow installer » on the SSD : The boot was successufull
- I installed directly Raspberry PI OS Lite on the SSD : The boot was successufull
- I installed directly HAOS 9.2 on a normal USB stick (not the SSD) : No boot !
For the moment my conclusion is that the current HAOS image provided by the Raspberry PI imager and by the yellow installer is not good and unbootable !
But in this case i would not be alone to have problems …
One thing is sure. The partitions installed by the Imager using HAOS or OS Lite are very differents, compared with the command « parted » :
HAOS image
Modèle: CT250P2S SD8 (scsi)
Disque /dev/sde : 250GB
Taille des secteurs (logiques/physiques): 512B/512B
Table de partitions : gpt
Drapeaux de disque : pmbr_boot
Numéro Début Fin Taille Système de fichiers Nom Fanions
1 1049kB 34,6MB 33,6MB fat16 hassos-boot msftres
2 34,6MB 59,8MB 25,2MB hassos-kernel0
3 59,8MB 328MB 268MB hassos-system0
4 328MB 353MB 25,2MB hassos-kernel1
5 353MB 622MB 268MB hassos-system1
6 622MB 630MB 8389kB hassos-bootstate
7 630MB 731MB 101MB ext4 hassos-overlay
8 731MB 2073MB 1342MB ext4 hassos-data
OS LITE image
Disque /dev/sdd : 250GB
Table de partitions : msdos
Numéro Début Fin Taille Type Système de fichiers Fanions
1 4194kB 273MB 268MB primary fat32 lba
2 273MB 250GB 250GB primary ext4
