I updated to the latest version of software and the thermostat is not updating the mode when it has been turned on at the panel though it says it’s heating.
I investigated to see if updates the app if I am standing at the panel with the app open, and it does.
It was working fine before the update. Does anybody know what might be the issue?
I don’t know if was ever working. I thought it worked but maybe I hadn’t tried the combination of turning it on at the panel and seeing if it updated the ios app which it doesn’t. The heating changes from idle but the mode switch doesn’t move to heat.
I just bought this T6 and the Home Assistant green and I’m just getting this behavior where it says it’s heating but the mode switches off.
You have to have it set up to run through Zwave. This mode is not enabled out of the box, you have to manually enable it.
If you’re running off battery, the battery will die very quickly. Make sure the batteries haven’t died.
When it’s run off battery, it goes into LSS mode. Meaning it may have it’s own internal polling frequency and it may not update live based on your inputs.
I’d wager he’s running off battery and it’s behaving different for you, me, and him. I also have this device and it’s working fine. Meaning it has to be his setup. This narrows it down to:
Not included correctly
Zwave isn’t enabled
On battery and OP isn’t waiting for the network to receive pressed updates (which depends on it’s sleep cycle).
I have the attached list of devices running fine on zwave. It’s the mode switch does not update on the ios app if I turn the T6 on at the panel.
I have a c-wire. It’s not on battery.
It’s not running on battery.
@busman I am not sure that the mode switch was mode switch was properly switching to the correct mode before when turning the furnace on manually at the panel. If we can drop that one and maybe focus on what might be the issue.
Can it be the ZWA-2 adapter not receiving, or maybe receiving it and not doing anything with an update of the mode when operated from the panel?
It seems to be working now. I must say it’s intermittent. Weird. I wonder what is causing the system to intermittently report the mode change? I will try and get the debugs when it doesn’t work and post back here. Thanks for the help.
I would watch those Z wave logs. See if there’s an error when you press the button on the thermostat. If nothing shows up, I’d be tempted to exclude it and re-include it.
