@Tysonpower, I just ordered a RS485 Bridge for my Promatic 4. The new garage door will be installed soon, so with this item I can controle my door via Home Assistant en HomeKit!
2 question:
Is there any difference between the standard firmware (MQTT) or ESPHome? Or do they have provide the same information to HA?
When I check you GitHub I see the sensor BME280 5V on the picture, but the power support will be 3.3V, I guess. The 3.3V version looks different; it has 6 pins instead of 4
Functional improvement in esphome as far as I know are
Binary sensor for the option Relay of the UAP HCP
The light is implemented as light instead of a switch
A button for the impulse function.
Half and Vent are available as button or switch depending your preference.
the vent position is not anymore determined by an hardcoded 4% value but by the status sent by the motor.
By the way you can also integrate your esphome device with MQTT just add the component. Esphome is a framework to create your firmware where you can combine the components you need. So if you want to use an CO2 sensor instead you just can add a component and build your custom firmware. This component approach is the main advantage. As dev you don’t have to care about network, hardware, sensor, mqtt, … , implementations. Just focus on the main functionality emulating the UAP HCP. As user you can adjust your firmware based on your hardware and needs.
The BME280 exist also in 3.3v variant. Tyson’s board have only 3.3v on board.
Esphome yes there are some more functionality. Esphome looks a bit odd when you start as you have to create a Yaml to compile your firmware but you can just combine it with other esphome component, automation,…
For the board maybe @Tysonpower has added a 5v rail in the newer board revision or the 5v sensor works also on 3.3v. The 6 pin sensor will fit as you only need vcc, gnd, SCL and SDA
Hallo,
ich habe Hörmann SupraMatic E Serie 4, mit Innentaster IT 3b-1.
ich habe mir Home Assistant eingerichtet und mittlerweile auch ein Wand Tablet, bin aber trotzdem kein profi. ich habe nur Wlan in der Garage.
was muss ich machen damit das mit dem “DIY Hörmann MQTT Adapter - ESP32-S3 Dev Board” funktioniert.
vielen lieben dank
Ich habe gerade eben eine Bestellung aufgegeben. ich hoffe ich bekomme es hin auch mit ihrer Anleitung und würde mich freuen wenn hinterher alles läuft. ich hoffe auch über keine Probleme wo man das Tor nicht mehr auf bekommt. aber dafür habe ich 2 not Entriegelung und Zugang zum Sicherungskasten habe ich auch noch
Did anyone here manage to connect Hörmann Liftronic 700-2 ?
Plugging into SBUS does not work directly. After initiating discovery mode on the motor (DIN switch5 on/off), the board powers for a short while, but then the discovery fails.
I got the board from @Tysonpower and recently changed the venting position on my Supramatic 4.
When I click on the “Vent” button it now shows it as “Door partially open” instead of “Venting” which I believe it did before.
I assume you use the Original MQTT Firmware of the project. There the value is hardcoded that Vent is at 4%. your new Vent position ist 7% therefore it’s not displaying as venting. Also your switch ist not active. You can try the esphome port there I changed the coding to read the actual venting status. Else you can also try by replacing the hardcoded value 0x08 by 0X0E and compile a new firmware.
I’m trying to emulate the DEA 12 with esphome, but I’m not sure how to find the leads that need to be pulled low to turn on the light, open the door, etc.
