How can I set network=host in HASS.io. According to this post
https://community.home-assistant.io/t/xiaomi-gateway-on-hassos/71809
According to above post, I already create docker-compose.yml like this one below but I don’t know the way to activate this config file. Does reboot server in HASS.io menu enough to activate it. If not, please kindly explain step to run command line. I already install SSH addon and I run command line via OSx’s terminal.
version: '3'
services:
homeassistant:
container_name: home-assistant
image: homeassistant/home-assistant
volumes:
- /config:/config
- /etc/localtime:/etc/localtime:ro
restart: always
network_mode: host
