I’ve recently purchased a Xiaomi gateway and have it up and running but am struggling to get it to connected to Home Assistant running on HassOS 1.10.
I can see it searching for the gateway but its not finding it:
INFO (SyncWorker_5) [homeassistant.components.xiaomi_aqara] Discovering Xiaomi Gateways (Try 1)
INFO (SyncWorker_5) [homeassistant.components.xiaomi_aqara] Discovering Xiaomi Gateways (Try 10)
ERROR (SyncWorker_5) [homeassistant.components.xiaomi_aqara] No gateway discovered
ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi_aqara: Component failed to initialize.
I’ve enabled LAN on the Mi Home app, tried lots of config including IP, with the key without the key etc, factory reset the gateway and started again, disabled and re-enabled my router firewall and pretty much every thing in the troubleshooting guide here:
But it all seems to come down to the use of: --net=host
I’ve tried to add docker-compose.yml file in the config directory with network mode set to host:
But I’m not sure if its being picked up, would HassOS pick this up and should it be in the config directory? If not is there any other way to set --net=host, I’ve seen talk of setting it in the docker run command but tbh don’t know where to start with that.
Thanks for posting this update! Was it a pain to get the key? Can you point me to the guide you used to retrieve it? It was a nightmare getting the Xiaomi vacuum key, and I’m not sure if I want to go down that road again…
For ages it’s been fine, but recently it’s temperamental. It works in Mi Home app but in HA, when I restart, it just tells me the config is incorrect. Even when I haven’t changed it at all.
Happened the other day, stopped working, I was pulling my hair out. Must have restarted 10 times, changed the config, added the host, MAC etc to config.yaml. Changed the key in Mi Home, and nothing worked.
Then it just suddenly did start working again. Today I restarted for a different reason and it’s giving me the configuration error again.
