How can I "un-brick" my LocalBytes PM Switch?
I have 2 of these switches. Following help I was given in this thread, I added a wifi: domain: to my yaml:
substitutions:
  friendly_name: Localbytes PM (Fridge/Freezer)
packages:
  #localbytes.plug-pm: github://LocalBytes/esphome-localbytes-plug/localbytes-plug-pm.yaml@main
  remote_package:
    url: https://github.com/MichaelMKKelly/localbytes-plug-pm
    ref: main
    file: localbytes-plug-pm.yaml
logger:
  level: debug
esphome:
  name_add_mac_suffix: false
  friendly_name: ${friendly_name}
api:
  encryption:
    key: 5tzsoUD9wTct8ZeOvOvh5el57RuZJvopZEk7EodKEWI=
wifi:
  ssid: !secret wifi_ssid
  domain: ".mydomain" #Added to address broken "View" button
… and flashed (OTA) the first PM Switch. All went fine. Job done!
Moving in the the second PM Switch, I repeated the above. However, when I went to flash (OTA), the ESPHome Addon reported that there was insufficient memory to upgrade. A bit of a surprise as Switch 1 had upgraded but not completely unexpected as I had come across occasions, when working close to a limit one compilation fits but another will not.
In addition I had read in other threads around these PM Switches that this had been noted by others and that the solutions was to “start again” with a “minimal” tasmota binary and follow that with the required binary.
So that is what I did. The “tasmota-minimal.bin” when across, and the switch rebooted and came back up as 192.168.4.1 as expected. However, I can not connect to the WiFi at that address. An nmap scan does not find any ports at all at 192.168.4.1 :cry:
That’s me out of ideas now! The next step, it to try and get the glued cover off. But I’m not hopeful I’ll find any useful access to a serial port to flash it that way.
Regards, Martin
I seem to remember there is a sequence of button pushes, 6? That resets the device to factory.
I guess I must not have got the right technique? Tried button presses - no luck.
And after reading the link you sent, it says 7 x power cycles - but again no luck.
There is also the caveat that the power cycle method only works IF “option 65 is set to 0”. And I have no idea if that was the case.
Any idea what feedback (led flashing?) I may get if I was successful?
Regards, M.
Tasmota-minimal is NOT FOR FIRST FLASHING. Tasmota-minimal is ONLY FOR UPDATING TASMOTA on a device that already has Tasmota configured.
Ah… Thank you. That explains why it is now a “brick”.
I know that these switches are not that expensive. But if possible, it would be interesting (to me) to know HOW to recover from this silly mistake.
Regards, M.
Sorry late to the party here, but I did the same.
I have unbricked it, by taking it to bits and soldering on some power/data leads and reflashing.
Prolly easier to buy a new one, but wheres the fun in that :slight_smile:
