How can repeat this automation?
hello i have this automation
- alias: 'Porta casa de banho'
    platform: state
    entity_id: binary_sensor.porta_casa_de_banho
    state: 'on'
    for:
      seconds: 20
    - service: shell_command.play_wc
What can I do to make this automation repeat every 20 seconds?
thanks
Like this
automation:
      platform: state
      state: 'on'
      for:
        seconds: 20
      - service: script.stuff
script:
  stuff:
    sequence:
      - service: script.stuff_loop
  stuff_loop:
    sequence:
      - delay:
          seconds: 20
Although this might not what you actually want…this loops until forever! If you only want it to loop as long as the state persists you might want to add a condition to those scripts like this:
automation:
      platform: state
      state: 'on'
      for:
        seconds: 20
script:
  stuff:
    sequence:
      - condition: state
        state: 'on'
  stuff_loop:
    sequence:
      - condition: state
        state: 'on'
      - delay:
          seconds: 20
Or you could add an automation to kill those scripts off when the state changes to off like this:
automation:
      platform: state
      state: 'on'
      for:
        seconds: 20
 - alias: 'Porta casa de banho NOT'
      platform: state
      state: 'off'
      - service: script.turn_off
          entity_id: script.stuff
          entity_id: script.stuff_loop
script:
  stuff:
    sequence:
  stuff_loop:
    sequence:
      - delay:
          seconds: 20
Might want to check out this if it suffices to have a notification https://home-assistant.io/components/alert/.
~Cheers
Thank you so much for yours knowledges. do you have ghitub for me to see your stuff?
No sorry I don’t have my config on github. It wouldn’t be impressive anyways as I don’t have that much set up myself :slight_smile:
If you have any questions or need help with so!merging feel free to ask.
~Cheers
@PhyberApex hello again, i get home now and i did some tests:
on this case:
automation:
  • alias: ‘Porta casa de banho’
    platform: state
    state: ‘on’
    for:
    seconds: 20
    • service: script.stuff
It should not be like this
  • service: script.turn_on
    entitidy id: script.stuff
i did that changes and i dont hear the soud. this line not show me on .log
17-02-22 13:07:41 INFO (MainThread) [homeassistant.core] Bus:Handling Event call_service[L]: service_call_id=3050659088-1, service_data=, service=play_wc, domain=shell_command
and if i run my code:
    platform: state
    state: ‘on’
    for:
    seconds: 20
    • service: shell_command.play_wc
show me.
You don’t need that change you can call scripts directly. Your change should not work.
~Cheers
if a call script directly like this;
-service: script.stuff
give this error:
17-02-22 13:25:09 INFO (MainThread) [homeassistant.components.automation] Executing Porta casa de banho aberta
17-02-22 13:25:09 INFO (MainThread) [homeassistant.core] Bus:Handling <Event logbook_entry[L]: message=has been triggered, domain=automation, entity_id=automation.porta_casa_de_banho_aberta, name=Porta casa de banho aberta>
17-02-22 13:25:09 INFO (MainThread) [homeassistant.helpers.script] Script Porta casa de banho aberta: Running script
17-02-22 13:25:09 INFO (MainThread) [homeassistant.helpers.script] Script Porta casa de banho aberta: Executing step call service
17-02-22 13:25:09 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_call_id=3050388752-1, service_data=, domain=script, service=stuff>
17-02-22 13:25:09 WARNING (MainThread) [homeassistant.core] Unable to find service script/stuff
i think that problem is on SERVICES:
when i click DOMAIN after SERVICES should not be appears “stuff”???
Yes it should be there do you have the script section of what I posted in your config? Is the script component loaded up in your logfile?
~Cheers
@PhyberApex
17-02-22 20:44:52 INFO (MainThread) [homeassistant.bootstrap] Setting up script
17-02-22 20:44:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=script, service=turn_on>
17-02-22 20:44:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=script, service=turn_off>
17-02-22 20:44:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=script, service=toggle>
17-02-22 20:44:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=script>
script.stuff no
Just to make sure you have that script in your configuration right? And you did a restart after yes?
~Cheers
@PhyberApex
configuration.yaml
script: !include_dir_merge_list includes/scripts
automation !include_dir_merge_list includes/automation
shell_command: !include includes/shell_command.yaml
inside folder includes/scripts
i have two scripts.
stuff.yaml
sequence:
    - condition: state
      state: 'on'
stuff_loop.yaml:
sequence:
- condition: state
  state: 'on'
  - delay:
    seconds: 20
inside folder automation
portacasadebanho,yaml
    platform: state
    state: ‘on’
    for:
    seconds: 20
shell_command.yaml
play_wc: sudo omxplayer /sons/wc.mp3
and yes i restarted always when i change something.
17-02-22 23:10:08 WARNING (MainThread) [homeassistant.core] Unable to find service script/stuff
any ideas?
if i change this:
    platform: state
    state: 'on'
    for:
      seconds: 20
for this:
    platform: state
    state: ‘on’
    for:
    seconds: 20
shows me:
17-02-22 23:17:32 INFO (MainThread) [homeassistant.components.automation] Executing Porta casa de banho
17-02-22 23:17:32 INFO (MainThread) [homeassistant.core] Bus:Handling <Event logbook_entry[L]: message=has been triggered, entity_id=automation.porta_casa_de_banho, name=Porta casa de banho, domain=automation>
17-02-22 23:17:32 INFO (MainThread) [homeassistant.helpers.script] Script Porta casa de banho: Running script
17-02-22 23:17:32 INFO (MainThread) [homeassistant.helpers.script] Script Porta casa de banho: Executing step call service
17-02-22 23:17:32 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=entity_id=['script.stuff'], service=turn_on, service_call_id=3050736912-1, domain=script>
17-02-22 23:17:32 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=3050736912-1>
but i cant hear mp3 sound
Could you try without the include? Just put it directly in your configuration.yaml.
~Cheers
@PhyberApex yes now it works, Why does not my way work?
Hey try changing
to include_dir_named with your way. That’s how I did it.
~Cheers
Now it works very well.
it was hard. Lol
thank you so much for your patience.
hi eveybody
i use this configuration but i got only two notify
do you know the problem?
automation:
      - above: '1'
        entity_id: sensor.ovenoo
        platform: numeric_state
      - below: '50'
        for:
          seconds: 20
script:
   stuff:
    sequence:
      - service: notify.ios_vahids_iphone
          title: "Home Assistant Alert"
          message: "oven is on!"
  stuff_loop:
    sequence:
      - delay:
          seconds: 10
I have the exact same issue:
When switch.main_pump goes to ‘off’, it alerts twice.
When switch.main pump goes to ‘on’ I get the restarted message.
Toggling again gets two more alerts.
My expection is that the script would repeat until switch.main_pump goes to ‘off’.
Automation:
- alias: 'Main pump stopped alert'
    platform: state
    entity_id: switch.main_pump
    to: 'off'
    for:
      seconds: 5
    - service: script.main_pump_alert
- alias: 'Main pump running again'
    platform: state
    to: 'on'
    - service: notify.ALL_DEVICES
        title: "Koi pond..."
        message: "...main pump has restarted"
        entity_id: script.main_pump_alert
        entity_id: script.main_pump_alert_loop
Scripts:
main_pump_alert:
    sequence:
          message: "...main pump has stopped"
      - service: script.main_pump_alert_loop
  main_pump_alert_loop:
    sequence:
      - delay:
          seconds: 5
Did you find a solution?
Found it!
The scripts have to be written thus:
  main_pump_alert:
    sequence:
      - service: script.turn_on
    sequence:
      - delay:
          seconds: 5
