How could I commission a Matter device to Home Assistant without Google?
I am interested in adding Matter devices to my Home Assistant setup.
I noticed that there are two supported commissioning flows: using an iOS device with the Home Assistant Companion app, and using an Android device with the Home Assistant Companion app installed from the Play Store (not F-Droid), with any custom Matter device registered in the Google developer console, presumably to a Google account that is logged in on the device. It also seemed to imply that one would need the Google Home app installed.
Is there a way to do Matter commissioning, especially for custom devices, using an AOSP Android host without Google proprietary components or a logged-in Google account to attach custom devices to?
Or is there a way to do commissioning from a laptop?
I don’t want to start buying into an ecosystem without the ability to administer it without the permission of any one or two companies.
I wrote myself a little python script to add Matter devices by code via Websocket.
I followed the instructions from: https://community.home-assistant.io/t/power-plugs-cant-connect-to-thread-network-skyconnect-thread-matter/638332/11?u=bltzbrg
i got it. my device is now available in homeassistant. I used the matter web-ui in homeassistant like u can see at the end of the post here:
“Commissioning is also possible through the Matter Server add-on Web UI.”
so no need for android device at all and also no need for external scripts etc.
