Ok, first you need to install the custom button card: Lovelace: Button card
You will also need the custom:hui-element card, 🔹 hui-element - Use built-in elements in the wrong place this allows us to use things like horizontal stacks in entities cards.
Then at the top of the raw edit mode paste these button templates:
button_card_templates:
icon_button:
aspect_ratio: 4/3
color_type: icon
hold_action:
action: none
layout: vertical
show_label: false
show_name: false
show_state: false
styles:
card:
- border-radius: 10px
- border: solid 1px var(--primary-color)
- box-shadow: none
- padding: 6px 6px
- margin: 0px 0px
- '--paper-card-background-color': 'rgba(0, 0, 0, 0)'
icon:
- width: 28px
name:
- justify-self: middle
- align-self: end
- font-size: 14px
- padding: 0px 0px
- color: var(--secondary-text-color)
tap_action:
action: call-service
menu_button:
aspect_ratio: 4/3
color_type: icon
hold_action:
action: none
layout: vertical
show_label: false
show_name: true
show_state: false
styles:
card:
- box-shadow: none
- padding: 6px 6px
- margin: 0px 0px
icon:
- width: 28px
name:
- align-self: end
- font-size: 14px
- padding: 0px 0px
tap_action:
We can then use the templates to build our remotes. These are just a bunch of buttons in horizontal stacks in an entities card. The advantage of the entities card (rather than a vertical stack) is that it can have a title and has a border. e.g. my TV remote card:
entities:
- card_type: horizontal-stack
cards:
- entity: script.lounge_tv_on
tap_action:
service: script.lounge_tv_on
template: menu_button
type: 'custom:button-card'
- entity: script.lounge_tv_off
tap_action:
service: script.lounge_tv_off
- entity: script.lounge_tv_input_tv
tap_action:
service: script.lounge_tv_input_tv
- entity: script.lounge_tv_input_kodi
icon: 'mdi:kodi'
tap_action:
service: script.lounge_tv_input_kodi
type: 'custom:hui-element'
cards:
- entity: script.lounge_tv_play
tap_action:
service: script.lounge_tv_play
template: icon_button
- entity: script.lounge_tv_pause
tap_action:
service: script.lounge_tv_pause
- entity: script.lounge_tv_stop
tap_action:
service: script.lounge_tv_stop
- entity: script.lounge_tv_rec
styles:
icon:
- color: red
tap_action:
service: script.lounge_tv_rec
cards:
- entity: script.lounge_tv_menu
tap_action:
service: script.lounge_tv_menu
- entity: script.lounge_tv_rewind
tap_action:
service: script.lounge_tv_rewind
- entity: script.lounge_tv_ffwd
tap_action:
service: script.lounge_tv_ffwd
- entity: script.lounge_tv_ch_up
tap_action:
service: script.lounge_tv_ch_up
cards:
- entity: script.lounge_tv_option
tap_action:
service: script.lounge_tv_option
- entity: script.lounge_tv_skip_back
tap_action:
service: script.lounge_tv_skip_back
- entity: script.lounge_tv_skip_fwd
tap_action:
service: script.lounge_tv_skip_fwd
- entity: script.lounge_tv_last_ch
tap_action:
service: script.lounge_tv_last_ch
cards:
- entity: script.lounge_tv_guide
tap_action:
service: script.lounge_tv_guide
- entity: script.lounge_tv_info
icon: 'mdi:information-outline'
tap_action:
service: script.lounge_tv_info
- entity: script.lounge_tv_up
icon: 'mdi:arrow-up-bold'
styles:
card:
- background: var(--secondary-background-color-alpha)
tap_action:
service: script.lounge_tv_up
- entity: script.lounge_tv_ch_dn
tap_action:
service: script.lounge_tv_ch_dn
cards:
- entity: script.lounge_tv_media
icon: 'mdi:folder-multiple-image'
tap_action:
service: script.lounge_tv_media
- entity: script.lounge_tv_left
icon: 'mdi:arrow-left-bold'
styles:
card:
tap_action:
service: script.lounge_tv_left
- entity: script.lounge_tv_ok
tap_action:
service: script.lounge_tv_ok
- entity: script.lounge_tv_right
icon: 'mdi:arrow-right-bold'
styles:
card:
tap_action:
service: script.lounge_tv_right
cards:
- entity: script.lounge_tv_www
tap_action:
service: script.lounge_tv_www
- entity: script.lounge_tv_return
tap_action:
service: script.lounge_tv_return
- entity: script.lounge_tv_down
icon: 'mdi:arrow-down-bold'
styles:
card:
tap_action:
service: script.lounge_tv_down
- entity: script.lounge_tv_exit
tap_action:
service: script.lounge_tv_exit
cards:
- entity: script.lounge_tv_red
styles:
icon:
- color: red
tap_action:
service: script.lounge_tv_red
- entity: script.lounge_tv_green
styles:
icon:
- color: '#00ff00'
tap_action:
service: script.lounge_tv_green
- entity: script.lounge_tv_yellow
styles:
icon:
- color: yellow
tap_action:
service: script.lounge_tv_yellow
- entity: script.lounge_tv_blue
styles:
icon:
- color: blue
tap_action:
service: script.lounge_tv_blue
show_header_toggle: false
title: TV Remote
type: entities
In my case the scripts the buttons call send IR commands to an iTach but the process is similar for the RM (or any other method that can be scripted). Here are a few example scripts:
lounge_tv_down:
service: remote.send_command
entity_id: remote.lounge_tv
command: "Down"
lounge_tv_exit:
command: "Exit"
lounge_tv_ffwd:
command: "FFwd"
Note that there is no icon specified anywhere. This is because the previous method I used had the icons assigned to scripts in customize:
script.lounge_tv_down:
icon: mdi:arrow-down-bold-circle
friendly_name: Down
script.lounge_tv_exit:
icon: mdi:backspace
friendly_name: Exit
script.lounge_tv_ffwd:
icon: mdi:fast-forward
You don’t have to do it this way. Yo can specify an icon in the button card. e.g. here’s the card for the Kodi remote that does not use customize for the icons:
entities:
cards:
- entity: script.lounge_kodi_input_home
icon: 'mdi:home'
tap_action:
service: script.lounge_kodi_input_home
- entity: script.lounge_kodi_input_contectx_menu
icon: 'mdi:menu'
tap_action:
service: script.lounge_kodi_input_contectx_menu
- entity: script.lounge_kodi_input_up
styles:
card:
tap_action:
service: script.lounge_kodi_input_up
- entity: script.lounge_kodi_input_info
tap_action:
service: script.lounge_kodi_input_info
cards:
- entity: script.lounge_kodi_player_play_pause
icon: 'mdi:play-pause'
tap_action:
service: script.lounge_kodi_player_play_pause
- entity: script.lounge_kodi_input_left
styles:
card:
tap_action:
service: script.lounge_kodi_input_left
- entity: script.lounge_kodi_input_select
icon: 'mdi:check-circle-outline'
tap_action:
service: script.lounge_kodi_input_select
- entity: script.lounge_kodi_input_right
styles:
card:
tap_action:
service: script.lounge_kodi_input_right
cards:
- entity: script.lounge_kodi_player_stop
icon: 'mdi:stop'
tap_action:
service: script.lounge_kodi_player_stop
- entity: script.lounge_kodi_input_back
icon: 'mdi:backburger'
tap_action:
service: script.lounge_kodi_input_back
- entity: script.lounge_kodi_input_down
styles:
card:
tap_action:
service: script.lounge_kodi_input_down
- entity: script.lounge_kodi_input_next_subtitle
icon: 'mdi:subtitles-outline'
tap_action:
service: script.lounge_kodi_input_next_subtitle
cards:
- entity: script.lounge_kodi_player_rewind
icon: 'mdi:rewind'
tap_action:
service: script.lounge_kodi_player_rewind
- entity: script.lounge_kodi_player_fast_fwd
icon: 'mdi:fast-forward'
tap_action:
service: script.lounge_kodi_player_fast_fwd
- entity: script.lounge_kodi_player_skip_back
icon: 'mdi:skip-previous'
tap_action:
service: script.lounge_kodi_player_skip_back
- entity: script.lounge_kodi_player_skip_fwd
icon: 'mdi:skip-next'
tap_action:
service: script.lounge_kodi_player_skip_fwd
cards:
- entity: script.lounge_kodi_player_skip_back_30
icon: 'mdi:rewind-30'
tap_action:
service: script.lounge_kodi_player_skip_back_30
- entity: script.lounge_kodi_player_skip_back_10
icon: 'mdi:rewind-10'
tap_action:
service: script.lounge_kodi_player_skip_back_10
- entity: script.lounge_kodi_player_skip_fwd_10
icon: 'mdi:fast-forward-10'
tap_action:
service: script.lounge_kodi_player_skip_fwd_10
- entity: script.lounge_kodi_player_skip_fwd_30
icon: 'mdi:fast-forward-30'
tap_action:
service: script.lounge_kodi_player_skip_fwd_30
- artwork: full-cover
entity: media_player.lounge_osmc_kodi
group: true
hide:
artwork: false
controls: true
icon: true
power: true
power_state: true
source: true
volume: true
icon: 'mdi:kodi'
info: scroll
type: 'custom:mini-media-player'
title: Kodi Remote
type: entities
Also:
Rimmer: “Mr. Flibble’s very cross. What are we going to do with them Mr. Flibble?”
Rimmer: “We can’t possibly do that! Who’d clear up the mess?”
