I would like to know how to manually apply mods as noted here:
Using ZWave to MQTT on Home Assistant.
Thanks muchly in advance to anyone who can offer any help.
That commit is for OZW. You are using ZwaveJs. Hence that commit cannot be applied.
Thanks Pete.
Any clues as to how the described resolution can be equivalently applied within ZWaveJS?
I basically just have 4x TKB TSM-02 I need to get working natively with Home Assistant.
Using ZWaveJS to MQTT only because it looked the optimal option to enable automation using Node RED.
Worked ok with Homeseer so thought would be good to migrate over to Home Assistant and have generally have had good standard of outcomes - overall managed to get more of my stuff into Home Assistant than I had working in Homeseer, but alas Z-Wave stuff on my criticals list and just these four sensors Iāve not been able to get playing with HA to complete the job.
Desperately donāt want to have to keep running Homeseer just to provide any support for just this remaining handful of devices.
Since Iām relatively new to Home Assistant, hoping someone can point me in the right direction as to how to crack this nut.
A place to start is getting the device debug info from zwavejs2mqtt and describing what is working and not working in your setup
Hi Pete,
Apologies for the delay in reply.
Very much appreciate any and all help and guidance that youāre able to give.
Excluded, reset and re-included node.
Device Debug info below.
The entities created in Home Assistant look broadly to be as expected, however none of the sensor values are ever updating.
Kind regards,
John.
"id": 53,
"name": "",
"loc": "",
"values": [
"id": "53-32-0-currentValue",
"nodeId": 53,
"commandClass": 32,
"commandClassName": "Basic",
"endpoint": 0,
"property": "currentValue",
"propertyName": "currentValue",
"type": "number",
"readable": true,
"writeable": false,
"label": "Current value",
"stateless": false,
"commandClassVersion": 1,
"min": 0,
"max": 99,
"list": false,
"value": 0,
"isCurrentValue": true,
"targetValue": "32-0-targetValue",
"lastUpdate": 1656823005740,
"newValue": 0
"id": "53-32-0-targetValue",
"nodeId": 53,
"commandClass": 32,
"endpoint": 0,
"property": "targetValue",
"propertyName": "targetValue",
"type": "number",
"readable": true,
"writeable": true,
"label": "Target value",
"stateless": false,
"min": 0,
"max": 99,
"list": false,
"lastUpdate": 1656819961631
"id": "53-48-0-Tamper",
"nodeId": 53,
"commandClass": 48,
"commandClassName": "Binary Sensor",
"endpoint": 0,
"property": "Tamper",
"propertyName": "Tamper",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Tamper",
"ccSpecific": {
"sensorType": 8
"stateless": false,
"commandClassVersion": 2,
"list": false,
"value": false,
"lastUpdate": 1656819961632,
"newValue": false
"id": "53-48-0-Door/Window",
"nodeId": 53,
"commandClass": 48,
"endpoint": 0,
"property": "Door/Window",
"propertyName": "Door/Window",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Door/Window",
"ccSpecific": {
"sensorType": 10
"stateless": false,
"list": false,
"value": true,
"lastUpdate": 1656819961634,
"newValue": true
"id": "53-48-0-Motion",
"nodeId": 53,
"commandClass": 48,
"endpoint": 0,
"property": "Motion",
"propertyName": "Motion",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Motion",
"ccSpecific": {
"sensorType": 12
"stateless": false,
"list": false,
"value": false,
"lastUpdate": 1656819961636,
"newValue": false
"id": "53-49-0-Air temperature",
"nodeId": 53,
"commandClass": 49,
"commandClassName": "Multilevel Sensor",
"endpoint": 0,
"property": "Air temperature",
"propertyName": "Air temperature",
"type": "number",
"readable": true,
"writeable": false,
"label": "Air temperature",
"ccSpecific": {
"sensorType": 1,
"scale": 0
"stateless": false,
"commandClassVersion": 5,
"unit": "Ā°C",
"list": false,
"value": 19,
"lastUpdate": 1656819961637,
"newValue": 19
"id": "53-49-0-Illuminance",
"nodeId": 53,
"commandClass": 49,
"endpoint": 0,
"property": "Illuminance",
"propertyName": "Illuminance",
"type": "number",
"readable": true,
"writeable": false,
"label": "Illuminance",
"ccSpecific": {
"sensorType": 3,
"scale": 0
"stateless": false,
"unit": "%",
"list": false,
"value": 93,
"lastUpdate": 1656819961639,
"newValue": 93
"id": "53-112-0-2",
"nodeId": 53,
"commandClass": 112,
"commandClassName": "Configuration",
"endpoint": 0,
"property": 2,
"propertyName": "Basic Set Level",
"type": "number",
"readable": true,
"writeable": true,
"description": "Allowable range: 0-99, 255",
"label": "Basic Set Level",
"default": 255,
"stateless": false,
"min": 0,
"max": 255,
"list": false,
"value": 255,
"lastUpdate": 1656822881507,
"newValue": 255
"id": "53-112-0-3",
"nodeId": 53,
"endpoint": 0,
"property": 3,
"propertyName": "PIR Sensitivity",
"type": "number",
"readable": true,
"writeable": true,
"label": "PIR Sensitivity",
"default": 70,
"stateless": false,
"min": 0,
"max": 99,
"list": false,
"value": 99,
"lastUpdate": 1656819961643,
"newValue": 99
"id": "53-112-0-4",
"nodeId": 53,
"endpoint": 0,
"property": 4,
"propertyName": "Light Threshold",
"type": "number",
"readable": true,
"writeable": true,
"label": "Light Threshold",
"default": 100,
"stateless": false,
"min": 0,
"max": 100,
"list": false,
"value": 0,
"lastUpdate": 1656821868173,
"newValue": 0
"id": "53-112-0-5",
"nodeId": 53,
"endpoint": 0,
"property": 5,
"propertyName": "Operation Mode",
"type": "number",
"readable": true,
"writeable": true,
"label": "Operation Mode",
"default": 0,
"stateless": false,
"min": 0,
"max": 127,
"list": false,
"value": 8,
"lastUpdate": 1656822881918,
"newValue": 8
"id": "53-112-0-6",
"nodeId": 53,
"endpoint": 0,
"property": 6,
"propertyName": "Multi-Sensor Function Switch",
"type": "number",
"readable": true,
"writeable": true,
"label": "Multi-Sensor Function Switch",
"default": 4,
"stateless": false,
"min": 0,
"max": 127,
"list": false,
"value": 48,
"lastUpdate": 1656822882530,
"newValue": 48
"id": "53-112-0-8",
"nodeId": 53,
"endpoint": 0,
"property": 8,
"propertyName": "PIR Re-Detect Interval Time",
"type": "number",
"readable": true,
"writeable": true,
"label": "PIR Re-Detect Interval Time",
"default": 3,
"stateless": false,
"min": 3,
"max": 127,
"list": false,
"value": 3,
"lastUpdate": 1656819961649,
"newValue": 3
"id": "53-112-0-9",
"nodeId": 53,
"endpoint": 0,
"property": 9,
"propertyName": "Turn Off Light Time",
"type": "number",
"readable": true,
"writeable": true,
"label": "Turn Off Light Time",
"default": 4,
"stateless": false,
"min": 4,
"max": 127,
"list": false,
"value": 4,
"lastUpdate": 1656821868780,
"newValue": 4
"id": "53-112-0-10",
"nodeId": 53,
"endpoint": 0,
"property": 10,
"propertyName": "Auto Report Battery Time",
"type": "number",
"readable": true,
"writeable": true,
"label": "Auto Report Battery Time",
"default": 12,
"stateless": false,
"min": 1,
"max": 127,
"list": false,
"value": 12,
"lastUpdate": 1656819961653,
"newValue": 12
"id": "53-112-0-11",
"nodeId": 53,
"endpoint": 0,
"property": 11,
"propertyName": "Auto Report Door/Window State Time",
"type": "number",
"readable": true,
"writeable": true,
"label": "Auto Report Door/Window State Time",
"default": 12,
"stateless": false,
"min": 1,
"max": 127,
"list": false,
"value": 12,
"lastUpdate": 1656819961654,
"newValue": 12
"id": "53-112-0-12",
"nodeId": 53,
"endpoint": 0,
"property": 12,
"propertyName": "Auto Report Illumination Time",
"type": "number",
"readable": true,
"writeable": true,
"label": "Auto Report Illumination Time",
"default": 12,
"stateless": false,
"min": 1,
"max": 127,
"list": false,
"value": 12,
"lastUpdate": 1656819961656,
"newValue": 12
"id": "53-112-0-13",
"nodeId": 53,
"endpoint": 0,
"property": 13,
"propertyName": "Auto Report Temperature Time",
"type": "number",
"readable": true,
"writeable": true,
"label": "Auto Report Temperature Time",
"default": 12,
"stateless": false,
"min": 1,
"max": 127,
"list": false,
"value": 12,
"lastUpdate": 1656819961657,
"newValue": 12
"id": "53-114-0-manufacturerId",
"nodeId": 53,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"endpoint": 0,
"property": "manufacturerId",
"propertyName": "manufacturerId",
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 280,
"lastUpdate": 1656819961659,
"newValue": 280
"id": "53-114-0-productType",
"nodeId": 53,
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 2,
"lastUpdate": 1656819961661,
"newValue": 2
"id": "53-114-0-productId",
"nodeId": 53,
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 2,
"lastUpdate": 1656819961662,
"newValue": 2
"id": "53-128-0-level",
"nodeId": 53,
"commandClass": 128,
"commandClassName": "Battery",
"endpoint": 0,
"property": "level",
"propertyName": "level",
"type": "number",
"readable": true,
"writeable": false,
"label": "Battery level",
"stateless": false,
"min": 0,
"max": 100,
"unit": "%",
"list": false,
"value": 100,
"lastUpdate": 1656819961664,
"newValue": 100
"id": "53-128-0-isLow",
"nodeId": 53,
"endpoint": 0,
"property": "isLow",
"propertyName": "isLow",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Low battery level",
"stateless": false,
"list": false,
"value": false,
"lastUpdate": 1656819961665,
"newValue": false
"id": "53-132-0-wakeUpInterval",
"nodeId": 53,
"commandClass": 132,
"commandClassName": "Wake Up",
"endpoint": 0,
"property": "wakeUpInterval",
"propertyName": "wakeUpInterval",
"type": "number",
"readable": false,
"writeable": true,
"label": "Wake Up interval",
"default": 86400,
"stateless": false,
"min": 1800,
"max": 432000,
"step": 1800,
"list": false,
"value": 86400,
"lastUpdate": 1656819961682,
"newValue": 86400
"id": "53-132-0-controllerNodeId",
"nodeId": 53,
"endpoint": 0,
"property": "controllerNodeId",
"propertyName": "controllerNodeId",
"type": "any",
"readable": true,
"writeable": false,
"label": "Node ID of the controller",
"stateless": false,
"list": false,
"value": 1,
"lastUpdate": 1656819961685,
"newValue": 1
"id": "53-134-0-libraryType",
"nodeId": 53,
"commandClass": 134,
"commandClassName": "Version",
"endpoint": 0,
"property": "libraryType",
"propertyName": "libraryType",
"type": "number",
"readable": true,
"writeable": false,
"label": "Library type",
"stateless": false,
"list": true,
"states": [
"text": "Unknown",
"value": 0
"text": "Static Controller",
"value": 1
"text": "Controller",
"value": 2
"text": "Enhanced Slave",
"value": 3
"text": "Slave",
"value": 4
"text": "Installer",
"value": 5
"text": "Routing Slave",
"value": 6
"text": "Bridge Controller",
"value": 7
"text": "Device under Test",
"value": 8
"text": "N/A",
"value": 9
"text": "AV Remote",
"value": 10
"text": "AV Device",
"value": 11
"value": 6,
"lastUpdate": 1656819961687,
"newValue": 6
"id": "53-134-0-protocolVersion",
"nodeId": 53,
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version",
"stateless": false,
"list": false,
"value": "3.41",
"lastUpdate": 1656819961689,
"newValue": "3.41"
"id": "53-134-0-firmwareVersions",
"nodeId": 53,
"endpoint": 0,
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"type": "string[]",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions",
"stateless": false,
"list": false,
"value": [
"1.0"
"lastUpdate": 1656819961691,
"newValue": [
"1.0"
"groups": [
"text": "Light Control",
"endpoint": 0,
"value": 1,
"maxNodes": 7,
"isLifeline": false,
"multiChannel": false
"text": "Reports",
"endpoint": 0,
"value": 2,
"maxNodes": 7,
"isLifeline": true,
"neighbors": [],
"ready": true,
"available": true,
"hassDevices": {},
"failed": false,
"inited": true,
"eventsQueue": [
"time": "2022-07-03T03:45:58.301Z",
"event": "value added",
"args": [
"endpoint": 0,
"newValue": 2,
"time": "2022-07-03T03:45:58.451Z",
"args": [
"endpoint": 0,
"newValue": 6,
"time": "2022-07-03T03:45:58.453Z",
"args": [
"endpoint": 0,
"newValue": "3.41",
"time": "2022-07-03T03:45:58.456Z",
"args": [
"endpoint": 0,
"newValue": [
"1.0"
"time": "2022-07-03T03:45:59.355Z",
"args": [
"endpoint": 0,
"newValue": 100,
"time": "2022-07-03T03:45:59.357Z",
"args": [
"endpoint": 0,
"newValue": false,
"time": "2022-07-03T03:45:59.803Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 99,
"time": "2022-07-03T03:45:59.966Z",
"args": [
"commandClass": 48,
"endpoint": 0,
"newValue": false,
"time": "2022-07-03T03:46:00.038Z",
"args": [
"commandClass": 48,
"endpoint": 0,
"newValue": true,
"time": "2022-07-03T03:46:00.111Z",
"args": [
"commandClass": 48,
"endpoint": 0,
"newValue": false,
"time": "2022-07-03T03:46:00.412Z",
"args": [
"property": 2,
"newValue": 255,
"time": "2022-07-03T03:46:00.492Z",
"args": [
"property": 3,
"newValue": 99,
"time": "2022-07-03T03:46:00.562Z",
"args": [
"property": 4,
"newValue": 99,
"time": "2022-07-03T03:46:00.629Z",
"args": [
"property": 5,
"newValue": 0,
"time": "2022-07-03T03:46:00.697Z",
"args": [
"property": 6,
"newValue": 61,
"time": "2022-07-03T03:46:00.790Z",
"args": [
"property": 8,
"newValue": 3,
"time": "2022-07-03T03:46:00.867Z",
"args": [
"property": 9,
"newValue": 4,
"time": "2022-07-03T03:46:00.937Z",
"args": [
"property": 10,
"newValue": 12,
"time": "2022-07-03T03:46:01.024Z",
"args": [
"property": 11,
"newValue": 12,
"time": "2022-07-03T03:46:01.100Z",
"args": [
"property": 12,
"newValue": 12,
"time": "2022-07-03T03:46:01.197Z",
"args": [
"property": 13,
"newValue": 12,
"time": "2022-07-03T03:46:01.487Z",
"args": [
"commandClass": 49,
"endpoint": 0,
"newValue": 19,
"time": "2022-07-03T03:46:01.573Z",
"args": [
"commandClass": 49,
"endpoint": 0,
"newValue": 93,
"time": "2022-07-03T03:46:01.586Z",
"event": "interview stage completed",
"args": [
"CommandClasses"
"time": "2022-07-03T03:46:01.592Z",
"args": [
"OverwriteConfig"
"time": "2022-07-03T03:46:01.596Z",
"args": [
"Complete"
"time": "2022-07-03T03:46:01.698Z",
"event": "ready",
"args": []
"time": "2022-07-03T03:46:01.719Z",
"event": "interview completed",
"args": []
"time": "2022-07-03T03:46:02.847Z",
"event": "sleep",
"args": [
2
"time": "2022-07-03T03:46:28.692Z",
"event": "value updated",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 99,
"time": "2022-07-03T03:47:24.299Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T03:51:34.456Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T03:52:12.623Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T03:52:55.715Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T03:53:30.510Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T03:57:22.899Z",
"event": "wake up",
"args": [
1
"time": "2022-07-03T03:57:23.998Z",
"event": "sleep",
"args": [
2
"time": "2022-07-03T03:58:24.806Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T03:58:57.385Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T03:59:28.841Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:00:07.458Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:00:25.594Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:02:11.944Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:02:38.590Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:04:32.005Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:04:40.794Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:06:13.116Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:06:25.561Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:06:59.805Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:07:43.737Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:08:17.528Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:08:33.979Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:09:35.328Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:09:59.130Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:10:37.540Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:11:28.955Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:12:03.130Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:13:10.766Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:13:44.251Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:14:46.653Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:15:25.369Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:16:13.045Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:16:51.005Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"time": "2022-07-03T04:17:32.186Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:17:46.829Z",
"event": "wake up",
"args": [
1
"time": "2022-07-03T04:17:46.978Z",
"args": [
"endpoint": 0,
"property": 4,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 100,
"default": 100,
"format": 0,
"allowManualEntry": true,
"isFromConfig": true
"value": 99,
"newValue": 0,
"prevValue": 99
"time": "2022-07-03T04:17:47.032Z",
"args": [
"endpoint": 0,
"property": 4,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 100,
"default": 100,
"format": 0,
"value": 99,
"newValue": 0,
"prevValue": 0
"time": "2022-07-03T04:17:47.142Z",
"args": [
"endpoint": 0,
"property": 5,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 0,
"format": 0,
"value": 0,
"newValue": 2,
"prevValue": 0
"time": "2022-07-03T04:17:47.249Z",
"args": [
"endpoint": 0,
"property": 5,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 0,
"format": 0,
"value": 0,
"newValue": 8,
"prevValue": 2
"time": "2022-07-03T04:17:47.449Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 61,
"newValue": 55,
"prevValue": 61
"time": "2022-07-03T04:17:47.525Z",
"args": [
"endpoint": 0,
"property": 9,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 4,
"max": 127,
"default": 4,
"format": 0,
"value": 4,
"newValue": 4,
"prevValue": 4
"time": "2022-07-03T04:17:48.175Z",
"args": [
"property": 4,
"newValue": 0,
"prevValue": 0,
"time": "2022-07-03T04:17:48.383Z",
"args": [
"property": 5,
"newValue": 8,
"prevValue": 8,
"time": "2022-07-03T04:17:48.591Z",
"args": [
"property": 6,
"newValue": 55,
"prevValue": 55,
"time": "2022-07-03T04:17:48.782Z",
"args": [
"property": 9,
"newValue": 4,
"prevValue": 4,
"time": "2022-07-03T04:17:49.871Z",
"event": "sleep",
"args": [
2
"time": "2022-07-03T04:34:39.634Z",
"event": "wake up",
"args": [
1
"time": "2022-07-03T04:34:39.769Z",
"args": [
"endpoint": 0,
"property": 2,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 255,
"default": 255,
"format": 1,
"value": 255,
"newValue": 0,
"prevValue": 255
"time": "2022-07-03T04:34:39.978Z",
"args": [
"endpoint": 0,
"property": 5,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 0,
"format": 0,
"value": 8,
"newValue": 4,
"prevValue": 8
"time": "2022-07-03T04:34:40.143Z",
"args": [
"endpoint": 0,
"property": 5,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 0,
"format": 0,
"value": 8,
"newValue": 48,
"prevValue": 4
"time": "2022-07-03T04:34:40.307Z",
"args": [
"endpoint": 0,
"property": 5,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 0,
"format": 0,
"value": 8,
"newValue": 8,
"prevValue": 48
"time": "2022-07-03T04:34:40.449Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 55,
"newValue": 8,
"prevValue": 55
"time": "2022-07-03T04:34:40.565Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 55,
"newValue": 4,
"prevValue": 8
"time": "2022-07-03T04:34:40.691Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 55,
"newValue": 48,
"prevValue": 4
"time": "2022-07-03T04:34:40.740Z",
"args": [
"endpoint": 0,
"property": 5,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 0,
"format": 0,
"value": 8,
"newValue": 0,
"prevValue": 8
"time": "2022-07-03T04:34:40.862Z",
"args": [
"endpoint": 0,
"property": 5,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 0,
"format": 0,
"value": 8,
"newValue": 8,
"prevValue": 0
"time": "2022-07-03T04:34:40.910Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 55,
"newValue": 8,
"prevValue": 48
"time": "2022-07-03T04:34:40.978Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 55,
"newValue": 84,
"prevValue": 8
"time": "2022-07-03T04:34:41.041Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 55,
"newValue": 48,
"prevValue": 84
"time": "2022-07-03T04:34:41.193Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 55,
"newValue": 4,
"prevValue": 48
"time": "2022-07-03T04:34:41.308Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 55,
"newValue": 45,
"prevValue": 4
"time": "2022-07-03T04:34:41.354Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 55,
"newValue": 48,
"prevValue": 45
"time": "2022-07-03T04:34:41.413Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 55,
"newValue": 48,
"prevValue": 48
"time": "2022-07-03T04:34:41.459Z",
"args": [
"endpoint": 0,
"property": 6,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 127,
"default": 4,
"format": 0,
"value": 55,
"newValue": 48,
"prevValue": 48
"time": "2022-07-03T04:34:41.509Z",
"args": [
"property": 2,
"newValue": 255,
"prevValue": 0,
"time": "2022-07-03T04:34:41.920Z",
"args": [
"property": 5,
"newValue": 8,
"prevValue": 8,
"time": "2022-07-03T04:34:42.533Z",
"args": [
"property": 6,
"newValue": 48,
"prevValue": 48,
"time": "2022-07-03T04:34:43.613Z",
"event": "sleep",
"args": [
2
"time": "2022-07-03T04:36:03.117Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 255,
"prevValue": 255,
"time": "2022-07-03T04:36:45.741Z",
"args": [
"commandClass": 32,
"endpoint": 0,
"newValue": 0,
"prevValue": 255,
"hexId": "0x0118-0x0002-0x0002",
"dbLink": "https://devices.zwave-js.io/?jumpTo=0x0118:0x0002:0x0002:0.0",
"manufacturerId": 280,
"productId": 2,
"productType": 2,
"deviceConfig": {
"filename": "/data/db/devices/0x0118/tsm02.json",
"isEmbedded": true,
"manufacturer": "TKB Home",
"label": "TSM02",
"description": "Slim Multi-Sensor",
"devices": [
"productType": 2,
"productId": 2
"firmwareVersion": {
"min": "0.0",
"max": "255.255"
"associations": {},
"paramInformation": {
"_map": {}
"productLabel": "TSM02",
"productDescription": "Slim Multi-Sensor",
"firmwareVersion": "1.0",
"protocolVersion": 3,
"nodeType": 1,
"endpointsCount": 0,
"endpointIndizes": [],
"isSecure": false,
"security": "None",
"supportsSecurity": false,
"supportsBeaming": true,
"isControllerNode": false,
"isListening": false,
"isFrequentListening": false,
"isRouting": true,
"keepAwake": false,
"maxDataRate": 100000,
"deviceClass": {
"basic": 4,
"generic": 32,
"specific": 1
"deviceId": "280-2-2",
"status": "Asleep",
"interviewStage": "Complete",
"statistics": {
"commandsTX": 77,
"commandsRX": 86,
"commandsDroppedRX": 0,
"commandsDroppedTX": 0,
"timeoutResponse": 0,
"rtt": 40.9,
"rssi": -51,
"lwr": {
"protocolDataRate": 3,
"repeaters": [],
"rssi": -55,
"repeaterRSSI": []
"nlwr": {
"repeaters": [
32
"rssi": -40,
"repeaterRSSI": [
127
"lastActive": 1656823005734,
"minBatteryLevel": 100,
"batteryLevels": [
100
"_name": "NodeID_53"
I donāt know how to interpret those files, we will need someone with expertise.
Go into the device configuration in HA are there disabled entities? If so try enabling those, restart and see if any of those update.
Looks like your āBasicā sensor is updating from 0 ā 255 and 255 ā 0.
Based on the manual it looks like you want the āOperation Modeā configuration value to be set to 0 rather than 8 like you currently have it.
Hi firstof9,
Thank you for your suggestion, but Iām afraid that this did not appear to have any effect after applying the device configuration parameter (5) change you suggested.
That was only set to 8 as I desire temperature in Celsius.
Iām not seeming to be getting any motion or door contact sensor state changes through to Home Assistant.
Your assistance is most appreciated.
Kind regards,
John.
Youāll need to check the driver logs to see whatās reporting.
https://zwave-js.github.io/node-zwave-js/#/troubleshooting/index?id=rule-1-use-the-driver-log-luke
Hi firstof9,
Ok, enabled Debug logging and had a few goes at opening closing magnetic contact sensor and trying to trigger motion detection:
2022-07-09T00:08:34.791Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T00:39:28.326Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T00:40:13.749Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T02:02:07.556Z DRIVER Dropping message because it could not be deserialized: BinarySwitchCCSet: dese
rialization not implemented (ZW0320)
2022-07-09T02:23:52.403Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T02:31:11.862Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T02:53:57.743Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T02:54:31.245Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T03:03:17.243Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T03:36:33.799Z CNTRLR Ā« [Node 2022-07-09T03:38:05.951Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T04:21:55.963Z CNTRLR [Node 053] Embedded device config loaded
2022-07-09T04:21:55.967Z DRIVER Restoring the network from cache was successful!
2022-07-09T04:21:56.750Z CNTRLR [Node 053] The node is asleep.
2022-07-09T04:21:56.800Z CNTRLR [Node 053] The node is ready to be used
2022-07-09T04:23:20.337Z DRIVER Ā« [Node 053] [REQ] [ApplicationCommand]
āā[BasicCCSet]
target value: 255
2022-07-09T04:23:20.340Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T04:23:20.341Z CNTRLR [Node 053] [~] [Basic] currentValue: 0 => 255 [Endpoint 0]
2022-07-09T04:23:31.483Z SERIAL Ā« 0x010b0004000603300300bb007d (13 bytes)
2022-07-09T04:28:01.292Z DRIVER Ā« [Node 053] [REQ] [ApplicationCommand]
āā[BasicCCSet]
target value: 255
2022-07-09T04:28:01.295Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T04:28:01.297Z CNTRLR [Node 053] [~] [Basic] currentValue: 0 => 255 [Endpoint 0]
2022-07-09T04:28:24.864Z DRIVER Ā« [Node 053] [REQ] [ApplicationCommand]
āā[BasicCCSet]
target value: 0
2022-07-09T04:28:24.867Z CNTRLR [Node 053] treating BasicCC::Set as a report
2022-07-09T04:28:24.868Z CNTRLR [Node 053] [~] [Basic] currentValue: 255 => 0 [Endpoint 0]`Preformatted text
Not sure 100% of the above all are regarding Node 53 specifically though.
So itās reporting, @freshcoast may have more insight. The device may need some special flag in zwavejs I donāt know for sure.
Well, according to all the driver databases, that looks right. OZW, OpenHAB and Z-Wave JS all associate automatically with Group 2. The user manual provided by OpenHAB disagrees though.
Does your paper manual show the same thing? That description is literally the opposite of the driver database entries, and your log agrees with the manual. You could try changing the association to āLight Controlā (Group 1) instead of āReportā (Group 2). Changing associations requires manually waking up the device: āIf the user want to wake-up the device immediately, please remove the front cover, and press the tamper key once. The device will wake-up 10 seconds.ā
Actually, I just checked Open Z-Waveās configuration, referenced by OP. In OZW this device is identified as a TSP01 (they share the same IDs). The Group configuration there is Group 1 for Reports, and Group 2 for Light Control, which matches the manual and is backwards from Z-Wave JS. OZW auto-associates both groups (Group 1 by default, Group 2 by config file), which means it would receive Group 1 reports (Binary Sensor). So Iām fairly certain it was working there, and Z-Wave JS (and OpenHAB) have it wrong. Not really sure what the purpose of auto-associating Group 2 by default is for.
Thanks freshcoast and firstof9 - we are most definitely making some progress!
I did as you suggested and tried changing the Association:
Now at least the Door/Window sensor responds and is reporting as expected and Iām also getting a temperature report at the same time.
That said, Iām not appearing to get Illuminance reports at the same time, as I would have expected;
I canāt seem to get the tamper switch to reset from true/tampered;
But most importantly, the motion sensor is permanently stuck at true/detected and neither the last two show any signs of life in History.
Hereās the full hard copy manual that I have:
Your help is indeed most sincerely appreciated!
Iāve just set up my TSM02 today using zwavejs2mqtt
Try setting parameter 7 to 26
It fixed the motion reporting for me!
