How do I change the category of a Zigbee device?
I managed to succesfully pair a CentraLite 4257050-RZHAC smart plug. Unfortunately it came in as a light, and as such is in the master light list.
I’m a total Home Assistant newbie, is there a way to change the device category to a switch or plug or am I stuck with it as a light?
Thanks!
You’ll need to tell us what sort of zigbee integration you are using.
I’m sorry, I don’t fully understand the question, so I’ll just describe my setup.
I am using a GoControl CECOMINOD016164 HUSBZB-1 with Z-Wave Plus and Zigbee controllers connected to a raspberry pi running Hass.io.
I added the Zigbee device to my network using the web interface, it added succesfully and can turn on/off when commanded.
Attached is a photo of the device in Home Assistant, you can see that it is registered as a light.
Would you mind to share how you pair this switch?
I have same switch and using cc2538+cc2592 module running zigbee2mqtt (z2m)
but z2m never see this centralite switch
I press switch on/off button while plugin to the wall, within a second i hear clicking sound and light on the switch start to blinking, but still no pairing happen
