How do I reboot host via SSH?
After some configuration changes, I get “502: Bad Gateway” displayed for the Hass.io panel. I am able to SSH in, but CLI is not working and I want to try restarting the Raspberry Pi next. I don’t have physical access to pull the plug at the moment.
Like I said, I can SSH in, but I get this trying to use the CLI:
core-ssh:~# hassio
/usr/bin/hassio: line 6: cannot create temp file for here-document: Read-only file system
I tried to use other commands, but here are the results:
core-ssh:~# docker
-ash: docker: not found
core-ssh:~# sudo shutdown -r now
-ash: sudo: not found
Thanks for any help.
You don’t need sudo as you’re already root (signified by the # symbol), shutdown -r now should work.
Thanks.
Doesn’t work though, it seems that I get the “-ash: command: not found” for most commands:
core-ssh:# shutdown -r now
-ash: shutdown: not found
because you are in the SSH Add-on and not the host SSH session.
Just tested on mine, the following worked:
reboot now
:slight_smile:
I am SSH-ing directly from my own machine. Hassio 0.62 and SSH plugin version 3.2.
Still, this command inside the SSH Add-on does not work:
core-ssh:~# reboot now
-ash: reboot: not found
because you NEED to be in the host SSH session…you can’t control the HOST from the docker container running the SSH add-on
Ok, makes sense. I’ll try to get access to the host next. Thanks.
This thread helped clear things up for me:
and
What I want to do is not possible until I have physical access to set up host SSH.
Thanks for the replies.
hassio homeassistant restart
He wants to reboot the host, so from SSH he wants
hassio host reboot
so you CAN control the host from the SSH add-on using that command? That’s cool
You can !
From SSH if you type just
hassio
it will list all your options :slight_smile:
Yes, but in my case, the Cli is dead… without SSH access directly to the host I cannot reboot the device, docker or Hass.io without physically pulling the plug.
core-ssh:~# hassio host reboot
API error:
core-ssh:~# hassio
I have access to Home Assistant in the browser, but anything related specifically to Hass.io, like the panel etc. is dead.
You can’t SSH in to the rpi from the command line on your PC / laptop ?
Just re-read your OP. Your not on the same LAN as the rpi ?
I’m not on the same LAN - I use port forwarding - I do not have VPN setup.
So, is the SSH Add-on on port 22 by default and the host SSH is on port 22222? I’m wondering if I could just forward that port and that would work. Not sure about the authorized keys however.
Nevermind, the RPI refuses a connection on 22222.
Have you put your SSH keys on the SD card?
Yes 22. Connect on 22 and type reboot
/sbin/reboot now worked for me.
Thanks took me forever to find this answer!! Whys it not documented? Some basic instructions for beginners would really help.
