How do I turn on the power and the delay light?
I have a KNX switch for a luminaire that turns on the power supply separately and the luminaire separately
how to realize this on Home Assistant, so that there is one switch that turns on both power and light and also I need a delay after the power supply for the command to turn on the luminaire to pass
Let’s say I control the luminaire in the following way
  light:
  - name: “Main light”
    address: “1/1/7”
    state_address: “1/1/8”
power on like this
  switch:
  - name: “Power for main light”
    address: “1/1/37”
    state_address: “1/1/38”
How and where to connect everything into one switch and add a delay ?
Am I right to use the switch type for power on ? or can it be light or something else ?
What about using a Template Switch
first ill create to script to turn on/off the Light
some like
script_on:
alias: Script ON
sequence:
  - action: light.turn_on
    metadata: {}
    data: {}
      entity_id: light.dinning
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
  - action: switch.turn_on
    metadata: {}
    data: {}
      entity_id: switch.alysha_lamp
the off bit
script_off:
alias: Script off
sequence:
  - action: light.turn_off
    metadata: {}
    data: {}
  - action: switch.turn_off
    metadata: {}
    data: {}
now the Template Switch
Join the 2 scripts
    switches:
      fan_switch:
        friendly_name: Main Light
        unique_id: 8c318522-ada5-47b5-b6b5-3c2159cd87dd
        value_template: '{{ is_state("switch.power_for_main_light", "on") }}'
        turn_on:
          action: script.turn_on
            entity_id: script.script_on
        turn_off:
            entity_id: script.script_off
I’m old school Like writing in yaml
but with some reading you should be able to do it in the GUI
Sorry for the delay, I couldn’t figure it all out at once.
I was unable to run the scripts from your example (I changed the names to my own, of course), but it ran like this
bedroom_deltalight_on:
  alias: Вкл Шайбы спальня
  sequence:
    metadata: {}
    data: {}
      entity_id: light.pitanie_shaiby_v_spalne
  - delay: '00:00:05'
    metadata: {}
    data: {}
      entity_id: light.shaiby_v_spalne_mdt
  description: ''
bedroom_deltalight_off:
  alias: Выкл Шайбы спальня
  sequence:
    metadata: {}
    data: {}
  - delay: '00:00:05'
    metadata: {}
    data: {}
  description: ''
Template Switch I created in the visual editor and it works correctly, I also like to write everything in code but I can not find where to store its code, in which yaml file to look for it ?
With out see the code in the template switch it going to be hard to see what wrong
Off top of head think it could be the value_template that is what controls the switch weather it’s on /off
Where in HA can I find the code for Template Switch ? I haven’t figured it out yet
ok in my config file
I have a line
switch: !include switches.yaml
This is where i have all my switches
then in side that file
I have Platform of templates
    switches:
      fan_switch:
        turn_on:
        turn_off:
JUst look in Helpers
look like you can do it there
I just leant something LOL
