My deCONZ setup used to work but doesnt now.
Error:
device state timeout ignored in state 2
Gateway info
Firmware: Not connected
I found the instructions to update the firmware, but I’m unable to follow the steps because it says “command not found” after many of the steps.
I am assuming that the Terminal tab in HA is where I enter these commands.
I was not able to copy the terminal text of when I followed the instructions in the firmware update guide, but I took a screenshot.
I have spent many hours reading and trying to get deCONZ working, please let me know what I am missing or what steps to try next.
This person had a similar issue to mine, and said they were able to fix it by updating the firmware. I am hoping to do that also, but apparently need help.
Screenshot of attempt to update firmware (following instructions) in Terminal.
SETUP INFO
I am using
Conbee II USB stick (in HA Pi)
Deconz 6.10.0
Phoscon-GW172.30.33.1
HA Core 2021.10.6
OS 6.5
in deCONZ integration, I have my device selected as “/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2190867-if00”
USB stick is plugged into an extension cable to avoid interference.
I have not added
dtoverlay=pi3-miniuart-bt
or made any other edits to the config.txt because I cannot access that file and don’t fully understand the command anyways. deCONZ used to work before and I had not edited that file.
In deCONZ the Xiaomi and IKEA switches and sensors are not working.
