I have an automation/script that keeps my living room light at a measured light level. I’m trying to clean it up by making a single sensor that has several attributes instead of several helper sensors. This is my new sensor:
Take a look at the documentation on how to create attributes for your sensors. You are using the old method of template sensors, the new method wouldn’t have a value_template or attribute_template.
Thanks for the insight of where my issue is, but I can not get that to work at all. I even copy from the Template → YAML configuration example to replace my sensors.yaml file and all I get is:
Invalid config for ‘sensors’ in configuration.yaml line 18
where line 18 is ‘sensors: !include sensors.yaml’
guess I’ll just leave it alone - it works.
Alright - trying to do this.
I want to make sure I understand this:
my new sensor will be located and called
[from the configuration.yaml file location]/entities/templates/sensors/my_1st_sensor.yaml
and
[from the configuration.yaml file location]/entities/templates/sensors/my_2nd_sensor.yaml
the things that are currently in my template.yaml will be
[from the configuration.yaml file location]/entities/templates/sensors/old.yaml
at least until I get around to cleaning them up.
Is this the right idea?
Unless I’m missing something, the path you’re headed down will result in a template sensor whose attributes are just copies of a bunch of input_number helpers’ states. If you want to skip the middleman and delete all those input number helpers, and have your automation put values directly into those attributes, you’re going to need a trigger-based template sensor that uses a custom event as a trigger.
You’ll want the new format, so that effort wasn’t all for naught, but you’ll have to change it a bit further. The documentation for the trigger-based template variants is just a little further down on the same template page linked earlier in this thread.
Thank you. That is what the original question was actually looking for. As for the sensor move from old to new format - it is a fight. Still working that.
Making progress - need a little more assistants
my sensor is now:
- sensor:
- name: Office PID
unique_id: koko_auto_0003
state: >
{% set feedback = states('sensor.office_lighting_illuminance') | int %}
{% set kp = state_attr('sensor.living_room_pid','P' ) | float | default(2) %}
{% set ki = state_attr('sensor.living_room_pid','I') | float | default(0.0) %}
{% set kd = state_attr('sensor.living_room_pid','D') | float | default(0.0) %}
{% set sp = state_attr('sensor.living_room_pid','Set_point') | int | default(800) %}
{% set lst_input = state_attr('sensor.living_room_pid','last_input') | int | default(810) %}
{% set lst_error = state_attr('sensor.living_room_pid','last_error') | int | default(10.0) %}
{% set error = (sp - feedback) | int %}
{% set delta_error = (error - lst_error) | float %}
{% set nwtime = now().timestamp() %}
{% set lsttime = as_timestamp(states.sensor.living_room_pid.last_changed) %}
{% set delta_time = (nwtime-lsttime) %}
{% set disp = ((kp*error)+(ki*error*delta_error)+(kd*delta_error/delta_time)) | float %}
{{disp}}
attributes:
P: >
{% set disp = 0.015 |float(3) %}
{{ disp }}
I: >
{% set disp = 0.0 |float(3) %}
{{ disp }}
D: >
{% set disp = 0.01 |float(3) %}
{{ disp }}
Set_point: >
{% set disp = 800 |int %}
{{ disp }}
last_error: >
{% set disp = (sp - feedback) | int %}
{{ disp }}
last_input: >
{% set disp = states('sensor.office_lighting_illuminance') | int %}
{{ disp }}
I will be setting the P I and D by going into Developer tools - this is working since it has a unique_id.
I will be setting the set point by automation based on time and request.
Otherwise I would like it to reference itself for the information that is currently coming from ‘living_room_pdi’
How do I get this sensor located in the template: !include_dir_merge_list → [path]/office_pid.yaml to reference itself?
I’ve tried replacing
state_attr(‘sensor.living_room_pid’,‘P’ )
with
state_attr(‘sensor.office_pid’,‘P’ )
and
this.attribute.P
… (several other attempts)
I’m not exactly sure what you are asking on this. Are you saying you want to use the value of the P attribute within the same sensor P exists in? If so then. you set up a variable and let P and whatever you want reference that.
What it is:
On a cloudy day it feels like I have to get up and turn the light on and off based on the clouds and adjust the light because of to much glare or need a little more general light. This is to stop me from having to get up and down for light purposes.
I already have it running (but will change to the new code) in the entertainment area (which is my living room) with movement lux setting, general tv setting and movie setting. The neat thing about it is I use to run the light around 60% - immediately by just maintaining a reasonable lux level I found the lights running about 30%. So it is energy efficient as well.
This is the operating code:
It took two new sensors to do it: (plus the light illuminance commercial sensor)
office_adjustment.yaml
- sensor:
- name: Office Adjustment
unique_id: koko_auto_0004
state: >
{% set kp = state_attr('sensor.office_pid','P' ) | float | default(2) %}
{% set ki = state_attr('sensor.office_pid','I') | float | default(0.0) %}
{% set kd = state_attr('sensor.office_pid','D') | float | default(0.0) %}
{% set sp = states('sensor.office_pid') | int | default(800) %}
{% set lst_input = state_attr('sensor.office_pid','last_input') | int | default(810) %}
{% set lst_error = state_attr('sensor.office_pid','last_error') | int | default(10.0) %}
{% set lsttime = as_timestamp(states.sensor.office_pid.last_changed) %}
{{disp}}
and
office_pid.yaml
- sensor:
- name: Office PID
state: >
{{ states('input_number.office_lux_set_point') | int }}
attributes:
P: >
{{ disp }}
I: >
{{ disp }}
D: >
{{ disp }}
last_error: >
{{ disp }}
last_input: >
{{ disp }}
As with all my stuff it will be upgraded again over time…
Any ideas on how I could have coded it better or even additions to put into it are welcome.
Future add will be to add lux control control by when the switch is manually dimmed or brighten it will use the new room lux level as the control set point.
