I was using life360 with smartthings when I connected my smartthings to home Assistant using the new official way. Then I went into smartthings to remove most of the components there and only left my zigbee contact sensors I had on there. However in home Assistant I still see my life360 entities on the integrations page under smartthings. I don’t see an option to remove them only to rename the entities.
Can anyone tell me how to do this?
I have already tried to restart it and no cigar. The artifacts are still present for some reason.
Hey guys wondering if anyone can help clear this up. I can go in and delete them from the customizations page but it tell me that those entities have to be removed from the integrations page which there I can’t see how to delete the entity individually. I only see how to delete the whole integration
There may be a better way, but I search for the device in core.device_registry and core.entity_registry files (located in the .storage folder) and deleted old smarthings items from each file. After a restart they were gone from the UI.
Be sure to backup those files before modifying. I’m pretty sure a mistake in there will make for a bad day.
I would like to ride on this open thread. I have a Tradfri Remote previously on Smartthings which i have removed it succesfully on ST platform and right now i have paired with on ZHA using Conbee 2.
I noticethe button is not triggering my light and have been trying to debug and i still see this entry listed in HA.
I tried remove the following code below from the /.storage/core.device_registry and reboot HA. but the entry still appears. Can advise on how this should be done to remove this Device from HA.
+1
I am trying to move devices (mostly z wave) from SmartThings to Home Assistant while using the ST integration to show the devices in Home Assistant. When I move a device to HA, I have duplicate entities if I use the same name.
Deleting device references in 2 files should do it according to tgis reddit thread:
I had the same issue during the transition and just opted to nuke the integration altogether which also required deleting a .smartthings folder or something along those lines… but this was a year ago so things may have changed.
