How much history is stored and how can we limit it?
I do not see any setting where I could set how much storage do I allow for data collection. And also I don’t know what is the default?
Is there a way to limit the amount of storage it can use?
It is this setting in the recorder integration: https://www.home-assistant.io/integrations/recorder/#purge_keep_days it lists the default as 10 days.
You can also limit the amount of data stored by excluding entities you are not interested in the history of.
First of all thank you very much @tom_l !
Now I have follow-up questions:
  • “purging” removes all data or just the ones which are over the “keep_days” threshold?
  • Is there any way I can limit based on the disk space? (e.g. keep any days that can fit into 1GB of disk space)
  • How can I check how much space is used by my settings? (which folders/files to look for?)
Just the data older than the keep_days value.
No.
If you are using the default recorder database, check the size of config/home-assistant_v2.db
If you want to add a sensor to do this see: Add "file size" sensor to the System Monitor - #6 by duceduc
