Hey - I have the SALUS ST898ZB Thermostat connected via zigbee,
Wondering what entitiy I could use to read the current and set temperature?
I see this in home assistant.
And the Entity ID is climate.salus_st898zb_thermostat
Thanks in advance
Thanks in advance
Set thermostat state attribute as a sensor
Check the link above.
under developer tools / states you will be able to find a list of the attributes you can use.
