Anybody knows how to add an Aqara Hub M3 into Home Assistant?
I am struggling with that and didn’t find any way to do it. It is paired with Home Kit, but impossible with Home Assistant.
Running HA on Synology docker.
There’s a thread about this.
Hi, apparently that hub is not easy to setup straightforward.
Have you read that thread referenced by @jackjourneyman
I have the aqara e1 hub. I use the HA HomeKit Device integration.
You will need to delete the hub from whatever HomeKit app (Apple Home?) it is currently paired with, then HA discovery should find the hub.
I may have missed the important one, but I didn’t find any thread that I can handle.
That works. But now the M3 is gone from HomeKit. As I am struggling a lot with HA, I need to keep HomeKit for now.
You will need an additional integration then.
I don’t use HomeKit outside of HA, so l can’t help with any specifics though.
