I’mm trying control my AC in simple way so, that when ever electricity price goes above today’s average electricity price, the AC will be set 1 degree lower. When ever the electricity price goes lower than average price for the day, temperature will set one degree higher.
I have automation entries which work when I set above: 8 and below 8. But when I try to use: above: “{{ float(state_attr(‘sensor.nordpool_kwh_fi_eur_3_10_024’, ‘average’)) }}” I get error message: “Automation with alias ‘If spot price above 8 cents set heat 1C lower’ failed to setup triggers and has been disabled: expected float for dictionary value @ data[‘above’]. Got None”
I have tried with without float and use different syntax but I always get same error.
My entries (which work otherwise when I set above:8 | below: 8):
# If SPOT price is lowish we can increase heating by 1C during day time
- id: hallway_ac_fan_low_spot
alias: If spot price below 7 cents increase heat
description: 'With low price increase heat by 1'
- platform: numeric_state
entity_id: sensor.nordpool_kwh_fi_eur_3_10_024
below: "{{ state_attr('sensor.nordpool_kwh_fi_eur_3_10_024', 'average') }}"
entity_id: sensor.ac_12488762_outdoor_temperature
below: 2
condition:
condition: and
conditions:
- condition: time
after: '10:00'
before: '17:00'
- service: climate.set_temperature
temperature: "{{ state_attr('climate.ac_12494102', 'temperature') + 1 }}" # Increase temperature by 1 degree
entity_id: climate.ac_12494102
mode: single
# If SPOT price is above average we can decrease heating by 1C during day time
- id: hallway_ac_fan_expensive_spot
alias: If spot price above 7 cents set heat 1C lower
description: ''
above: "{{ state_attr('sensor.nordpool_kwh_fi_eur_3_10_024', 'average') }}"
condition:
condition: and
conditions:
- condition: time
after: '10:00'
before: '17:00'
temperature: "{{ state_attr('climate.ac_12494102', 'temperature') - 1 }}" # Decrease temperature by 1 degree
mode: single
# If SPOT price is below average we can increase heating by 1C during day time
alias: If spot price below average increase heat
below: sensor.energy_spot_average_price
below: 2
condition:
condition: and
conditions:
- condition: time
after: '08:00'
before: '17:00'
mode: single
# If SPOT price is above average let's set heating 1C lower
alias: If spot price above average cents set heat 1C lower
description: ''
above: sensor.energy_spot_average_price
condition:
condition: and
conditions:
- condition: time
after: '08:00'
before: '22:00'
mode: single
That seems to work the way I wanted although I need to wait a bit longer. When setting the value for sensor.nordpool_kwh_fi_eur_3_10_024 manually through “Developer Tools” it does change the temperature the way I was expecting.
Real results I should get during the day, when the price drops below average and the back above average within next few hours.
Hourly spot prices for the next day are announced day before around 1pm CET. They don’t change after that so the average price stays constant throughout the day. The hourly price obviously changes every hour but follows the prices which were published day before.
In theory this should work and so it seems, but I need to see the changing in real life first, to be able to fully qualify.
For today it looks like this:
Average is 7.95c/kWh and current 8.55c/kWh. It will go below 7.95c/kWh at 12pm CET.
Replying to myself gain noting that the solution I implemented works as I expected and the temperature request wen fro 20C to 21C when sport price went less than the average:
Now I need to wait it works the other way around as well
Ok, now I have verified everything works for both increasing the temperature when prices exceeds the average and decreasing the temperature when price goes under the average.
If the outside temperature fluctuates around 2°C your set temperature will rise every time the temperature crosses below 2°C. Left to its own devices, this pair of automations will increase the set temperature without bounds. You should probably set a maximum and minimum in the conditions.
Explain the exact logic you want to use, because you also have time conditions in there.
Imagine you’re doing the job of the automation, and you can see the outside temperature, the current set temperature, and the electricity spot and average prices. When will you adjust the temperature in each direction?
So, I want the heat increase only to happen between the time constraints and when it’s less than 2 degrees outside.
Heat decrease I’m ok between time constraints but never more often than once after heat increase or once without heat increase. It would be good to have minimum there though as condition. For example 18C.
This could be tricky: what would trigger consecutive heat changes?
The totally untested version below should set the temperature to 21 if it’s cold, cheap and daytime; and 19 if any of those is no longer true. Will trigger off any change to any of the related entities.
- platform: state
entity_id:
- sensor.nordpool_kwh_fi_eur_3_10_024
- sensor.energy_spot_average_price
- sensor.ac_12488762_outdoor_temperature
- platform: time
at:
- "08:00"
- "22:00"
condition:
- or:
- and:
- alias: Cold and cheap and daytime so temp up
- condition: numeric_state
below: 2
- condition: time
after: "08:00"
before: "22:00"
- or:
- alias: Warm or expensive or night so temp down
above: 2
- condition: time
before: "08:00"
- condition: time
after: "22:00"
- variables:
down: >
{{ states('sensor.ac_12488762_outdoor_temperature')|float(0) > 2 or
states('sensor.nordpool_kwh_fi_eur_3_10_024')|float(0) >
states('sensor.energy_spot_average_price')|float(0) or
not(8 <= now().hour < 22) }}
temperature: "{{ 19 if down else 21 }}
