How to automatically reload integration on a schedule?
Is there a simple way to force an integration to reload on regular schedule, for example every night at 2 am?
Use an automation something like this (assuming it is an integration setup in the UI).
description: "Reload xxx integration @ 2am"
mode: single
  - platform: time
    at: "02:00:00"
condition: []
  - service: homeassistant.reload_config_entry
      entry_id: ad7f562e4ef537e1bf858335aae4002e
The config entry id is found in config/.storage/core.config_entries for the one you want to reload.
You can also get entry_id using the config_entry_id filter.
Thank y’all!
is this write in to automations.yaml ?
i was edit to every 3 hours instead of time
the code below correct ?
  • description: “Reload Tuya integration @ 3hours”
    mode: single
    • platform: time_pattern
      hours: “/3”
      condition:
    • service: homeassistant.reload_config_entry
      entry_id: 635ee76a799ddf6fb8e8a6efe0852786
- description: "Reload Tuya integration @ 3hours"
  mode: single
   - platform: time_pattern
     hours: "/1"
  condition: []
It also makes sense to reload the integration in case that entity or entities from that integration become unavailable:
alias: Restart TuyaLocal integration
description: TuyaLocal integration reload in case of error.
  - platform: state
    entity_id:
      - switch.tuyalocal_toaster
    to: unavailable
    for:
      hours: 0
      minutes: 0
      seconds: 30
condition: [ ]
      entry_id: GUID from config/.storage/core.config_entries
mode: single
If you format your code correctly people would get even more help from your post :slight_smile:
Folks,
Was following along in this thread, but got really lost with locating the entry_id and hope one of you kind souls can help me.
No idea where this goes… anyone?
I cannot find the config/.storage directory anywhere?
All help greatly appreciated :yum:
The following service call, to reload an integration, requires that you provide it with the integration’s entry_id.
There are several ways to find an integration’s entry_id. One way is to use the config_entry_id filter. As per its documentation, it requires that you supply it with the entity_id of any entity that belongs to the integration.
    entry_id: "{{ config_entry_id('sensor.whatever') }}"
Have you found the configuration.yaml file? The .storage directory is a hidden sub-directory of the directory containing the configuration.yaml file.
Thanks for the help, managed to find it and identified the entry id.
Great, thanks. Sometimes TuyaLocal devices become unavailable, can skip automations and lose data before noticing.
Took me a minute to understand, as I was looking for an integration id to restart the integration.
Confirmed that If you just use an entry_id it will restart the associated integration.
I wanted to use this when my blinds integration went offline for all blinds.
So using just one blind entry will trigger the integration restart to fix all blinds in the integration.
Works well. Thank you
Apologies for replying on an old thread but I’ve been searching for the last few hours for a way to reload (only) a HACS integration (wyzesense) that doesn’t create any of its own entities and it instead updates some binary_sensor entities. Any hints? Thanks
Was looking to do the same thing, but on a button not an automation. Here’s a quick config, in case someone comes looking for the same thing :
show_name: true
show_icon: true
type: button
name: Reload Blink Cams
icon: mdi:cctv
hold_action:
  action: perform-action
  perform_action: homeassistant.reload_config_entry
  target: {}
    entry_id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
theme: Mushroom Shadow
If you want an easier way of getting all your integration ids, then run this script. It will save a text file in your /config folder. Needless to say, you will save this code as, say, extract_entry_ids.py in the /config location. Then run python3 /config/extract_entry_ids.py
import json
import os
config_entries_path = "/config/.storage/core.config_entries"
output_file_path = "/config/integration_ids.txt"
def extract_integration_ids(input_path, output_path):
    try:
        # Read the core.config_entries file
        with open(input_path, "r") as file:
            data = json.load(file)
        entries = data.get("data", {}).get("entries", [])
        output_lines = []
        for entry in entries:
            title = entry.get("title", "Unknown")
            entry_id = entry.get("entry_id", "Unknown")
            output_lines.append((title, entry_id))
        sorted_lines = sorted(output_lines, key=lambda x: x[0].lower())
        formatted_lines = [f"{title}: {entry_id}" for title, entry_id in sorted_lines]
        with open(output_path, "w") as output_file:
            output_file.write("\n".join(formatted_lines))
        print(f"Integration IDs have been successfully written to {output_path}.")
    except Exception as e:
        print(f"An error occurred: {e}")
extract_integration_ids(config_entries_path, output_file_path)
Here is a way to determine entry ID if you are logged in at home assistant by SSH:
jq '.data.entries | [.[] | {domain: .domain, entry_id: .entry_id}]' /config/.storage/core.config_entries
I’m using JSON field „domain“ instead of „title“ as title is often empty but domain is not. This command returns a list like that:
    "domain": "sun",
    "entry_id": "01JGA42XEBS95P1MVHDGHSQEB2"
    "domain": "hassio",
    "entry_id": "01JGA42XHVGW129NV7WY8MMG1E"
    "domain": "go2rtc",
    "entry_id": "01JGA42XHV43FF1R6FX0QEE4Z6"
    "domain": "met",
    "entry_id": "01JGA5VNT9J5AJFHP9KFKDQAZ6"
    "domain": "ipp",
    "entry_id": "01JGA6XB7KDKNDWCNE0ZWKH65M"
    "domain": "dlna_dmr",
    "entry_id": "01JGA6XFD8YK1DKX65WEZC3C4P"
    "domain": "ipp",
    "entry_id": "01JGAACGPA5XAYKQ41ED4QT84F"
    "domain": "unifi",
    "entry_id": "01JGHP0RGX9S5AQFGNHSQXMTNB"
    "domain": "hacs",
    "entry_id": "01JGQXX64Y68Q3SNZMM2WNVJGH"
    "domain": "tuya",
    "entry_id": "01JGR2BSB593P9B3VJRHV7FG4X"
    "domain": "localtuya",
    "entry_id": "01JGSEFW6H4GM4BHRNDTTGX98A"
    "domain": "roborock",
    "entry_id": "01JGWJC1P0TFSN0YDZCE82ZJ6A"
    "domain": "gardena_smart_system",
    "entry_id": "01JGWP4CQZ3Z1SNM57D3E423ZW"
    "domain": "home_connect",
    "entry_id": "01JGWSXNH4KZWEYH0TS1YAZMA3"
    "domain": "shelly",
    "entry_id": "01JHW7EC9X2A2508VNM8G7YD8A"
    "domain": "shelly",
    "entry_id": "01JHWEN0M0Y1KE9G0YM0CJVJBK"
    "domain": "shelly",
    "entry_id": "01JHWF9N2XKXBK9T3X499PPM5T"
    "domain": "shelly",
    "entry_id": "01JHWGB0JD2VZ49E7H1PW0F4DD"
    "domain": "shelly",
    "entry_id": "01JHWGZKTR3C9DDB2M3R2J0VGJ"
    "domain": "shelly",
    "entry_id": "01JHWHREJY98JSQCC26TGN20D9"
    "domain": "shelly",
    "entry_id": "01JHWKHEJNW0CBJY9TRJCQTWBE"
    "domain": "shelly",
    "entry_id": "01JHWMCJ7Z7MZ44G6PWD3YWATX"
    "domain": "samsungtv",
    "entry_id": "01JKGQ3G78924QD2WZ06JD79B4"
    "entry_id": "01JKGS37QX80D56SV3TK9NT65X"
    "entry_id": "01JKGSE3T1DK1AY652R8WAS22J"
    "domain": "librelink",
    "entry_id": "01JKVQF0732WAFTMA5W51MBJWZ"
    "domain": "fritz",
    "entry_id": "01JKZP1R35E7MATG23W3X262M9"
    "domain": "bring",
    "entry_id": "01JMPJT1C38HM4VP7FQ1GKF52C"
    "domain": "thread",
    "entry_id": "01JMPSN2S42QV0BR8YJCCXVSSP"
    "domain": "mobile_app",
    "entry_id": "01JMPSP5PKJEWTWEFRZJ15N0SE"
If you found the Integration you would like to reload then use this command. It‘s a sample for roborock. Please replace domain search string „roborock“ with the one you need:
jq -r '.data.entries.[] | select(.domain == "roborock") | .entry_id' /config/.storage/core.config_entries
This returns one entry ID or many entry IDs without quotes.
If you get more than one entry ID make sure to reload all of them.
Then paste entry ID in an automation like this. It‘s one I use for reloading Roborock Integration when etities got unavailable:
alias: Roborock Geräte neu laden
description: ""
triggers:
  - trigger: time_pattern
    minutes: /10
conditions:
  - condition: or
    conditions:
      - condition: state
        entity_id: sensor.rocky_eg_dock_fehler
        state: unavailable
      - condition: state
        entity_id: sensor.rocky_og_dock_fehler
        state: unavailable
      - condition: state
        entity_id: sensor.rocky_dg_dock_fehler
        state: unavailable
actions:
  - action: homeassistant.reload_config_entry
      entry_id: 01JGWJC1P0TFSN0YDZCE82ZJ6A
mode: single
Alternatively you can auto determine entry_id in automation:
description: ""
triggers:
    minutes: /10
conditions:
  - condition: or
    conditions:
      - condition: state
        state: unavailable
      - condition: state
        state: unavailable
      - condition: state
        state: unavailable
actions:
      entry_id: "{{ config_entry_id('sensor.rocky_eg_dock_fehler') }}"
mode: single
Correct. That was suggested 8 months ago.
The use of config_entry_id was suggested earlier, in the third post (May 2023).
That‘s correct. I just wanted to show both options are valid. I can remove alternative if you like.
