There were several times when I wanted to have say, input_number with a range from 0 to 100 and initial value of 50.
If I put initial: 50 in that entity’s config, it will be 50 on every HA restart.
If I don’t use initial, it will be either the last recorded state or min value (if the entity is new)
And there is possibility that if something goes wrong with the recorder/HA restart, I’ll end up with something different to 50 as a state of my entity (min value?) if I understand HA docs correctly.
The thing is I want to benefit from the recorder’s capability of storing values so one should not tweak everything after every HA restart, but I also don’t want to have the minimum value as initial/default state.
It seems like a lack of extra config variable, or I’m over-complicating things and there is a nicer approach?
Well, I think that’s the problem in the approach some HA developers have to the initial_state, been there at least once.
There are 2 different aspects of an entity: initial state of an entity and ability to restore it after restart. Do you agree?
And I’m currently demonstrating that it’s just impossible to configure these 2 different sides with only one binary setting.
If we keep initial_state as a value that one wants to see by when an entity is created/intact, and use something named say, default to fall back if HA cannot restore the last recorded state of that entity, I presume it will do the job.
may sound silly but why would HA not be able to restore a state?
If you really want to set such a safety, then I would recommend creating a template sensor that would like like this: {% if states("sensor.sensor_name") == "unknown" %}50{% else %}{{states("sensor.sensor_name")}}{% endif %}
I think I saw it several times - database corruption or some HA tantrum, don’t know. And it’s especially highlighted in the documentation, so it’s very well possible.
I think your template_sensor approach wouldn’t work because of == "unknown" bit as HA will most likely initialise that input_number with min value. Please read carefully my initial post, it’s not about sensors.
Good morning everyone,
I wanted to inform you that in these two weeks I have completely rethought and redone the code of my repository, which allows the activation of a switch according to your habits.
Still the project is under development and if you want to help me in some way, I would be really happy!
Some news:
Compatible with influxDB !
If influxDB is not available, use the HASS history
All objects are managed by Pandas frames
The day of the week, the season, the quarter, the beginning and the end of the month are taken into account.
Situations are generated through an internal patternMarching and are integrated in a heuristic way.
much more!
What’s next:
Approach with a MachineLearning (perhaps scikitLearn) for data model creation, learning, and prediction.
Identification of new events in live
Probability and event management
much more!
If you have practice with Pyton and want to help, I would be very happy!
Otherwise, if you want, you can buy me a beer
