I need help about RFXTRX integration and configuration.
I explain my configuration
I’ve bought a USB Rfxcom device
I’ve plugged it on my HomeAssisant
I’ve added Rfxtrx integration, setup it and choose automatic added for new devices
I push the on and off button on the remote for each switch and in the home-assistant.log I see the new device and it’s automaticly added.
But unfortunnatly I don’t understand (correctly I think also) how to set-up my HA
Please find the log
On action
2021-03-24 19:54:19 INFO (MainThread) [homeassistant.components.rfxtrx.switch] Added switch (Device ID: 150551 Class: LightingDevice Sub: 0, Event: 09130000150551016070)
2021-03-24 19:54:19 INFO (MainThread) [homeassistant.components.rfxtrx.sensor] Added sensor (Device ID: 150551 Class: LightingDevice Sub: 0, Event: 09130000150551016070)
2021-03-24 19:54:19 INFO (MainThread) [homeassistant.components.rfxtrx.binary_sensor] Added binary sensor (Device ID: 150551 Class: LightingDevice Sub: 0 Event: 09130000150551016070)
2021-03-24 19:54:19 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new switch.rfxtrx entity: switch.pt2262_150551
2021-03-24 19:54:19 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.rfxtrx entity: sensor.pt2262_150551_rssi_numeric
2021-03-24 19:54:19 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.rfxtrx entity: binary_sensor.pt2262_150551
Off Action
2021-03-24 19:55:01 DEBUG (Thread-2105) [RFXtrx] Recv: 0x09 0x13 0x00 0x02 0x15 0x05 0x54 0x01 0x5e 0x70
2021-03-24 19:55:01 INFO (MainThread) [homeassistant.components.rfxtrx.switch] Added switch (Device ID: 150554 Class: LightingDevice Sub: 0, Event: 09130002150554015e70)
2021-03-24 19:55:01 INFO (MainThread) [homeassistant.components.rfxtrx.sensor] Added sensor (Device ID: 150554 Class: LightingDevice Sub: 0, Event: 09130002150554015e70)
2021-03-24 19:55:01 INFO (MainThread) [homeassistant.components.rfxtrx.binary_sensor] Added binary sensor (Device ID: 150554 Class: LightingDevice Sub: 0 Event: 09130002150554015e70)
2021-03-24 19:55:01 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new switch.rfxtrx entity: switch.pt2262_150554
2021-03-24 19:55:01 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.rfxtrx entity: sensor.pt2262_150554_rssi_numeric
2021-03-24 19:55:01 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.rfxtrx entity: binary_sensor.pt2262_150554
2021-03-24 19:55:01 DEBUG (Thread-2105) [RFXtrx] Recv: 0x09 0x13 0x00 0x03 0x15 0x15 0x5f 0x01 0x60 0x70
Could you help me ?
I’ve try this configuration but it’s doesn’t work
rfxtrx:
device: /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A11SEQM8-if00-port0
debug: true
automatic_add: true
devices:
150551:
data_bits: 4
command_on: 0x1
command_off: 0x4
My Config
HA Core : 2021.3.4
RfxCom USB
