Murada99
(JoeM)
March 10, 2021, 3:44pm
1
Hi all,
Already spent a lot of time looking in the docs but without success.
I don’t know if anyone can help you but since the last HA updates the RFXcom integration no longer works.
Entities and devices (lights) are created but when I try to use them the RFXcom lights flash but nothing happens.
My RFXCOM works fine with the RFXmngr when I try to send the code.
HA version is 2021.3.2
The RFXcom is version RFXtrx433XL
In the log file, I have the following:
When usind the remote :
2021-03-10 16:26:29 DEBUG (Thread-31) [RFXtrx] Recv: 0x09 0x13 0x00 0x0b 0x65 0x76 0x02 0x01 0xb0 0x70
When sending with HA;
2021-03-10 16:29:24 DEBUG (SyncWorker_8) [RFXtrx] Send: 0x09 0x13 0x00 0x00 0x00 0x00 0x01 0x01 0xb1 0x00 2021-03-10 16:29:25 DEBUG (Thread-31) [RFXtrx] Recv: 0x04 0x02 0x01 0x00 0x00
I already deleted and reinstall the RFXtrx integration but without success.
Why it doesn’t work anymore ?
Received data is: 0913000B657602010070
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 11
Code = 657602 decimal:6649346
S1- S24 = 0110 0101 0111 0110 0000 0010
Pulse = 256 usec
But you transmit: 0913000000000101B100
subtype = PT2262
Sequence nbr = 0
Code = 000001 decimal:1
S1- S24 = 0000 0000 0000 0000 0000 0001
Pulse = 433 usec
0402010000
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 0
response = ACK, data correct transmitted
Murada99
(JoeM)
March 11, 2021, 10:30am
3
Thanks for the reply, but I don’t understand why this is modified. The device is created with the following HA integration: https://www.home-assistant.io/integrations/rfxtrx
But when I try to use it, the code sent is wrong. Where can I find the registered code created by the HA integration?
Murada99
(JoeM)
March 11, 2021, 2:13pm
4
It’s interesting how you get this information from debugging.
How do you get this result?
Thanks for your help.
Murada99
(JoeM)
March 11, 2021, 3:34pm
5
This seems an issue with the update to 2021.2.0.
opened 06:35PM - 04 Feb 21 UTC
The problem
Functionality working in 2021.1.5 and stopped working after upgrade to 2021.2.0
Downgrade via snapshot restored functionality
RFX devices detected as PT-2262 cannot...
integration: rfxtrx
Murada99
(JoeM)
March 23, 2021, 5:32pm
6
Hi all,
Spending a long time to understand this but is quiet easy.and I want to share this.
First set the debug in the configuration.yaml file
logger:
default: error
logs:
RFXtrx: debug
When you press the remote, you will see in the “home-assistant.log” the following:
This means that the following data is received: 0913000B657602010070 (retrieve all “0x”)
Now, just call the service rfxtrx.send with this data:
- type: 'custom:button-card'
icon: 'mdi:light-switch'
tap_action:
action: call-service
service: rfxtrx.send
service_data:
event: 0913000B657602010070
Note that the data string is also visible (without 0x) in RFXmngr for receive and transmit commands.
Murada99
(JoeM)
March 25, 2021, 12:55pm
8
Hi b_weijenberg,
Indeed at the top right of the date.
25-03-21 01:49:00:509= 0913000B657602010070
subtype = PT2262
Sequence nbr = 2
Pulse = 432 usec
Signal level = 6 -72dBm
