Hello someone managed to get the password for the vacuum cleaner Irobot Roomba Combo R113840. We can’t apply the usual procedure, because it doesn’t have a back dock button.
Hi, press button reset twice (short clicks).
Didn’t work
Which firmware does your R113840 have? Mine is on 4.3.2 and I had no luck yet:
Dez 03 11:31:32 home hass[43692]: 2022-12-03 11:31:32.736 ERROR (roombapy) [roombapy.remote_client] Can't connect to 192.168.20.66, error: [SSL: UNSAFE_LEGACY_RENEGOTIATION_DISABLED] unsafe legacy renegotiation disabled (_ssl.c:997)
Dez 03 11:31:32 home hass[43692]: 2022-12-03 11:31:32.742 ERROR (roombapy) [roombapy.remote_client] Can't connect to 192.168.20.66, error: [Errno 111] Connection refused
Dez 03 11:31:32 home hass[43692]: 2022-12-03 11:31:32.747 ERROR (roombapy) [roombapy.remote_client] Can't connect to 192.168.20.66, error: [Errno 111] Connection refused
Dez 03 11:31:32 home hass[43692]: 2022-12-03 11:31:32.749 ERROR (roombapy) [roombapy.remote_client] Unable to connect to 192.168.20.66
I’m wondering if initializing with initwifi.py script for doing the initial provisioning by kFYatek · Pull Request #108 · NickWaterton/Roomba980-Python · GitHub would help.
Hi again,
Does anyone successfully connected Roomba Combo R113840 to Home Assistant? I’ve tried using script from HERE, but no luck. Throwed Roomba back to Factory Settings and tried, but completely unable to get the password.
The manual says “hold Home button for few seconds”, but here is no Home button. Only “Clean” or “Reset”. Tried both, many config - holding, pressing few times - without success.
I would be grateful for any advise, how or if it is possible to pair Roomba Combo with HA.
Thank you
Hi, for me works two middle shorts clicks (2 sec) on reset button. Roomba beeps and Home Assistant retrieve password.
Hi! If this help, it worked for me with one ~5 seconds press on reset button.
Worked for me too, thanks!
Roomba combo 2022 SKU: r113840 4.3.10
