Hi there,
I finally implemented the slowpwm PID following the great example of mcarter14777:
Now my wish is to automate a temperature ramp for increasing and decreasing temperature.
I have found only the light transition.
Is there a way (I am sure there are many) to create a program for the setpoint temperature, for instance: goes from ambient temperature to 65°C 1 deg/minute, stay there for 6 hours and then let it cool at 2°C/minute?
Best it would be if the program is editable before run from the frontend: increase and decrease ramp, stationary temperature, time for stationary temperature.
The code for the slowpwm PID, basically cut and paste from the mcarter14777.
It runs on an esp32 that drives directly a 50A SSR. The load is around 10A.
esphome:
platform: ESP32
board: esp-wrover-kit
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "b8f1c9c3cf3b466ceea07e8afe4fad04"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Pidslowpwm Fallback Hotspot"
password: "zpo00ha4Gyi6"
captive_portal:
#https://community.home-assistant.io/t/diy-electric-grill-powered-by-esphome/232710
### Pull time from Home Assistant because everything needs a clock on it ###
time:
- platform: homeassistant
spi:
miso_pin: GPIO19
mosi_pin: GPIO23
clk_pin: GPIO18
switch:
### Switches for Setting and Getting PID Values in Home Assistant ###
turn_on_action:
- climate.pid.set_control_parameters:
kp: !lambda
return id(p_coefficient).state;
ki: !lambda
return id(i_coefficient).state;
kd: !lambda
return id(d_coefficient).state;
name: "Get PID Values"
turn_on_action:
- homeassistant.service:
service: input_number.set_value
entity_id: input_number.p_coefficient
value: !lambda return id(kp).state;
entity_id: input_number.i_coefficient
value: !lambda return id(ki).state;
entity_id: input_number.d_coefficient
value: !lambda return id(kd).state;
### Switch to reset integral term for PID calculation ###
name: "Reset Integral"
turn_on_action:
- climate.pid.reset_integral_term: pid_climate
### PID Loop ###
climate:
- platform: pid
visual:
min_temperature: 0 °C
max_temperature: 350 °C
temperature_step: 0.1 °C
sensor: pt100
default_target_temperature: 0°C
heat_output: heater
control_parameters:
kp: 0.001
ki: 0.00003
kd: 0.1
min_integral: 0
max_integral: 0.5
### Slow PWM for PID Output ###
output:
- platform: slow_pwm
pin: GPIO22
period: 3s
### Sensors to Read PID information into Home Assistant ###
- platform: pid
type: RESULT
- platform: pid
name: "PID Integral Term"
type: INTEGRAL
- platform: pid
name: "PID Derivative Term"
type: DERIVATIVE
- platform: pid
name: "PID Proportional"
type: PROPORTIONAL
- platform: pid
name: "PID P Coefficient"
type: KP
- platform: pid
name: "PID I Coefficient"
type: KI
- platform: pid
name: "PID D Coefficient"
type: KD
- platform: pid
type: HEAT
### Sensors to read input numbers for PID tuning in Home Assistant ###
name: "P Coefficient"
name: "I Coefficient"
name: "D Coefficient"
- platform: max31865
reference_resistance: 430 Ω
rtd_nominal_resistance: 100 Ω
rtd_wires: 3
cs_pin: GPIO04
