How to deal with non-SSL Panel iframe pages inside SSL Hass.io environment?
Sorry, typo, AMD64 was intended. Since it happened multiple times it was probably Autocorrupt & I didn’t notice.
You did, but you referenced an entire manual in a statement saying “they do more” & “supervisor supervises” & gave a link that said
Add-ons for Home Assistant allow the user to extend the functionality around Home Assistant. This can be running an application that Home Assistant can integrate with (like an MQTT broker) or to share the configuration via Samba for easy editing from other computers. Add-ons can be configured via the Supervisor panel in Home Assistant.
Under the hood, add-ons are container images published to a container registry like GitHub container registry and Docker Hub. Developers can create GitHub repositories that contain multiple add-ons for easy sharing with the community
Then had a tutorial on making an add-on…
All that in response to “Why not have an add-on repo”… Which didn’t really answer the question.
In another forum I was pretty much told that Ingress (& config/build formatting) is almost solely what separates Supervisor from Docker. & specifically that that Frigate Proxy is utilizing Ingress & when I mentioned someone modifying it to use for a different URL was told essentially that they were just using Ingress from the container.
I’ll look more into it once my next billing cycle starts (as I’m already over my monthly cap this month). But how I do that, or if I will actually be able to with my modest skills, is still TBD. I may try to make an independent supervisor stack to run in regular docker & use a Portainer-like manager so it can run any add-on for a Docker HA, or it was suggested possibly making a Dockerized Ingress agent that could be slapped over a regular Docker Container & essentially give them the thing they lack from a HA side while retaining their superiority otherwise, then all other configuration will just have to be done manually &, so I’m told, it will make the Supervisor unnecessary.
I’m not sure which direction I’ll go, but most likely whichever seems easier or has the least steps requiring things I’m not skilled at. Either way I’ll share the results as either should be appropriate for this thread’s goals
Not sure how I missed this, because I responded right below it. But this user has an ingress proxy written as well, @LostOnline
Thanks. That should be helpful if I take that path. But it’s, again, an add-on, so it will still have to be dockerized, but it’s definitely nice to have a cleaner source to reference
@LostOnline you may wish to read this thread Is it possible to convert an addon for HA OS to run in a standalone container for HA as a docker?
This was sounding promising but I can’t get it working. I just end up with a blank screen after clicking ‘open wen ui’
addon log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: Frigate Proxy
 Proxy addon for Frigate
 Add-on version: 1.3
 You are running the latest version of this add-on.
 System: Home Assistant OS 9.4  (amd64 / generic-x86-64)
 Home Assistant Core: 2022.12.8
 Home Assistant Supervisor: 2022.12.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[14:38:37] INFO: Starting NGinx...
Also, it seems to not be using any resources…
I actually dug into this as well, ever since I migrated to a Docker installation and…actually have found the way to make it work using nginx proxy manager (either add on, or seperate docker). Here is how it works:
In NGINXProxy manager, you start with creating your proxy host as explained in the installation guide here:
After that, you need to create a rule for the location you want to access through https. So go to the “advanced” tab of your proxy host and enter a custom location with this code:
location /panelname/ {
    rewrite /panelname/(.*) /$1  break;
    proxy_pass  http://local-ip:port;
So this basically creates a rule, which forwards all requests to: https://yourdomain.duckdns.org/panelname to your network internal (non secure) http adress. But…since it goes through NGINX it is served as a secure site to the outside world.
Then, in your configuration.yaml you enter the panel_iframe like such.
panel_iframe:
  panelname:
    title: "Panel Name"
    url: "https://yourdomain.duckdns.org/panelname"
    icon: mdi:docker
    require_admin: true
I have got most things working flawlessly like this, just have a tiny issue left with the Duplicati container in my case, but most things like Zigbee2MQTT, Portainer, Configurator, Vaultwarden etc work flawlessly like this and I can access everything externally.
Hope this helps someone…
Hi, I also migrated my installation to docker standalone installation. Can you please share you config, ie. docker-compose file for nginx or give some additional info how you set this up.
Edit: Got it, it does work great. Maybe I latter wrote some my config just for people to find it.
This my docker-compose.yml file for nginx
  nginx:
    container_name: nginx_proxy
    image: 'jc21/nginx-proxy-manager:latest'
    restart: unless-stopped
    ports:
      - '80:80'
      - '81:81'
      - '443:443'
    volumes:
      - /opt/nginx/data:/data
      - /opt/letsencrypt:/etc/letsencrypt
I use dynu for my domain. Set up for ssl is really easy. Just grab ssl key from site and and replace token in a line
dns_dynu_auth_token = YOUR_DYNU_AUTH_TOKEN
I tried to open z2m over nabu casa using iframe and it does work. This is great, this is the thing I wanted to do for a few weeks. Some setups are more complex that others but this setup mention by @Remko is easy and this work great.
Thank you for sharing.
Hi. I applied your code and it is working with esphome and portainer but for frigate container it is not. Could you please help me to solve it? Thank you.
I used this code in Advanced tab
location /frigate/ {
    rewrite /frigate/(.*) /$1  break;
    proxy_pass  http://10.20.30.105:5000;
And this in HA configuration.yaml
  #frigate iframe
  frigate:
    title: frigate
    icon: mdi:webcam
    url: https://hass.local/frigate
    require_admin: true
Hi. I did managed to solve it using this help
This is working code in advanced tab for frigate container
USE IT ONLY ON YOUR LOCAL SERVER.
IT OPENS FRIGATE WITHOUT LOGIN TO HA
    proxy_set_header Host $host;
    proxy_set_header X-Ingress-Path "/frigate";
    proxy_set_header X-Forwarded-Scheme $scheme;
    proxy_set_header X-Forwarded-Proto $scheme;
    proxy_set_header X-Forwarded-For $remote_addr;
    proxy_http_version 1.1;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection "upgrade";
HA configuration remains the same (see previous post)
This totally works- BUT anyone on the planet can go to
https://yourhomeassistantname.duckdns.org/panelname
and have full access because you’ve served it. Yes, it’s https: so nobody in the middle can interpret it, but whoever is attached can control whatever was served. Try it by opening a browser that isn’t logged into your instance of HA- put that in the browser. Which you may not care if it’s just your holiday lights or something.
Also, for anyone trying to do this with Logitech Media Server, it won’t work (something about local files).
They still need to login to Home Assistant
True, and I only serve some pages which require a separate login so could be fine.
@DavidFW1960 : no this is not true. The pages are served separate from Homeassistant and can be opened without even accessing homeassistant.
Yeah @fmon is damn correct. I found out it today also. I may browse my frigate instance even without login into HA. Thats really bad. USE IT ONLY ON YOUR LOCAL SERVER.
So @fmon and @Remko how to solve this?
Create authentication for the separate containers. For example Portainer or Z2MQTT are easy, they allow you to define a separate login. I don’t expose frigate to the outside, rarely need that webpage, the integration offers all I need.
Accessing that I do just in my internal network with a bookmark in my browser to the local ip:port
And do you use for sth your proposed sollution?
sth? I don’t know what you mean here…
If you use your solution for something?
I would say name the panel a very long string of random characters similar to a client secret but I think that unless you have cutting-edge encryption running the headers are unencrypted even with https: and might be intercepted.
So I guess we try what @Remko said
I currently have the setup so that I can access my zigbee2mqtt page on a different location with an additional auth token. It’s working in a new tab, but not in the iframe inside home assistant. I believe it has something to do with displaying the alert popup where you have to enter the auth token but I might be wrong, I just don’t see my zigbee2mqtt page, just a plain white page.
Do you know how to manage the separate page with authentication in the iframe tab?
If you are in a HA-Core setup and use the addon, you can also access the zigbee2mqtt addon from the sidebar. So somehow they also managed to integrate this, even with HA authentication.
Is there anything I can do to access my docker containers from within ha remotely and not expose the containers to anyone? Didn’t find anything but maybe Ive overseen something?
