How to dim Bedside lamp with Xiaomi button?
I am trying to set the brightness change of the xiaomi lamp with the wireless button.
I want to set continuously brightness change from actual state to max then jump to minimal brightness (if maximum is achieved) and so on…
Xiaomi button have “hold” state and “long_click_release” which can be used for this - “hold” trigger continuously change brightness and “long_click_release” stops.
Anyone can help me with this? Language syntax and scripting of HA is a little magic for me now. There is no documentation and support in my native language, either (Polish)
Already i have this code in automation.yaml
  • alias: Inc/Dec brightness of the gateway light
    platform: event
    event_type: click
    event_data:
    entity_id: binary_sensor.switch_158d0001dc44c4
    click_type: hold
    platform: event
    event_type: click
    event_data:
    entity_id: binary_sensor.switch_158d0001dc4519
    click_type: hold
    service: light.turn_on
    entity_id: light.yeelight_bedside_7811dc90cd74
    data_template:
    transition: ‘1’
    brightness: >
    {% set n = states.light.yeelight_bedside_7811dc90cd74.attributes.brightness + 25 %}
    {% if n > 255 %}
    10
    {% else %}
    {{ n | int }}
    {% endif %}
Works fine but brightness changes only one step at the time.
You need to create:
-script with brightness control which calls itself during the time the button is being pressed.
-input_boolean to control wether to increase or decrease brightness
You can find more information and details in this forum post.
I’ve read whole thread about this, but it is very complicated to understand for me.
I’ve created some configuration:
(automations.yaml)
- alias: Zmiana jasnosci lampki
  - platform: event
    event_type: click
    event_data:
      click_type: long_click_press
  - platform: event
    event_type: click
    event_data:
   - service: script.turn_on
     entity_id: script.zmien_jasnosc
- alias: Zmiana jasnosci lampki off
  - platform: state
    to: 'off'
  - platform: state
    to: 'off'
   - service: script.turn_off
Scripts.yaml
zmien_jasnosc:
    sequence:
    - condition: state
      state: 'on'
    - service: light.turn_on
      data_template:
       transition: '1'
       brightness: >-
        {% if n > 255 %}
          10
        {% else %}
         {{ n | int }}
        {% endif %}
Unfortunately it didn’t worked.
To keep things simple, I suggest that you try with following data _template inside your scripts:
Brighten :
brightness: '{{states.light.yeelight_bedside_7811dc90cd74.attributes.brightness + 10}
Dim:
brightness: '{{states.light.yeelight_bedside_7811dc90cd74.attributes.brightness - 10}}
and use a 2nd script to dim the light.
In total, I use 2 scripts , 4 automations and 1 input_boolean to dim/brighten 1 or more lights.
Here’s my configuration:
configuration.yaml:
input_boolean:
  light1_dim:
    initial: off
automations.yaml:
- alias: Light1 brighten on
  initial_state: 'on'
  - platform: event
    event_type: click
    event_data:
      entity_id: binary_sensor.switch_158d0001a5d08e
  condition:
    condition: and
    conditions:
    - condition: state
      entity_id: input_boolean.light1_dim
      state: 'off'
    - condition: state
      entity_id: light.light1
      state: 'on'
    entity_id: script.1511118763251
- alias: Light1 brighten off - bool on
  initial_state: 'on'
  - platform: state
    to: 'off'
  condition:
    condition: and
    conditions:
    - condition: state
      state: 'off'
    - condition: state
      state: 'on'
- alias: Light1 dim on
  initial_state: 'on'
  - platform: event
    event_type: click
    event_data:
  condition:
    condition: and
    conditions:
    - condition: state
      state: 'on'
    - condition: state
      state: 'on'
    entity_id: script.1511119598248
- alias: Light1 brighten off - bool off
  initial_state: 'on'
  - platform: state
    to: 'off'
  condition:
    condition: and
    conditions:
    - condition: state
      state: 'on'
    - condition: state
      state: 'on'
  - service: input_boolean.turn_off
scripts.yaml:
'1511119598248':
  alias: dim_light1
  sequence:
  - condition: state
    state: 'on'
    data_template:
      brightness: '{{states.light.light1.attributes.brightness - 10}}'
'1511118763251':
  alias: brighten_light1
  sequence:
  - condition: state
    state: 'off'
    data_template:
      brightness: '{{states.light.light1.attributes.brightness + 10}}'
You can also apply this set of scripts/automations to rise or lower the Volume of a TV (with a Broadlink IR Emitter for example) with the Xiaomi Switches.
Above lines in my script was unnecessary.
Unfortunately with my script or yours scripts I’ve got “Qoute Exceed, flood protection” from bedside lamp in my logs And lamp stops responding. Then I added delay 00:01 at the end of script.
Now dimming ligth works like a charm but a little slow. Is it possible to delay 0.3 s instead of 1 s?
Frankly speaking creating recurrention in HA is really unfriendly.
Yes, 0.3s delay is possible :
- delay:
    # supports milliseconds, seconds, minutes, hours, days
    milliseconds: 300
Thank you. Now its perfect :slight_smile:
For those interested I’ve created a version that works with the Zigbee2MQTT version using the Xiaomi round button, using the above.
input_boolean:
  light1_dim:
    initial: off
automation:
  - id: button_round_single
    initial_state: 'on'
    alias: Toggle lamp with button click
      platform: mqtt
      topic: 'zigbee2mqtt/Xiaomi round button'
    condition:
      condition: state
      entity_id: sensor.xiaomi_round
      state: 'single'
      - service_template: >
           {%- if is_state('light.tvlampmqtt', 'off') -%}
             light.turn_on
           {%- else -%}
             light.turn_off
           {%- endif %}
        entity_id: light.tvlampmqtt
    initial_state: 'on'
      platform: mqtt
    condition:
      condition: and
      conditions:
      - condition: state
        state: 'long'
      - condition: state
        state: 'off'
      - condition: state
        state: 'on'
    initial_state: 'on'
      platform: mqtt
    condition:
      condition: and
      conditions:
      - condition: state
        state: 'long_release'
      - condition: state
        state: 'off'
      - condition: state
        state: 'on'
    initial_state: 'on'
      platform: mqtt
    condition:
      condition: and
      conditions:
      - condition: state
        state: 'long'
      - condition: state
        state: 'on'
      - condition: state
        state: 'on'
    initial_state: 'on'
      platform: mqtt
    condition:
      condition: and
      conditions:
      - condition: state
      - condition: state
        state: 'on'
      - condition: state
        state: 'on'
script:
  '1511119598248':
    alias: dim_light1
    sequence:
    - condition: state
      state: 'on'
      data_template:
        brightness: '{{states.light.tvlampmqtt.attributes.brightness - 10}}'
    - delay:
       milliseconds: 300
  '1511118763251':
    sequence:
    - condition: state
      state: 'off'
      data_template:
        brightness: '{{states.light.tvlampmqtt.attributes.brightness + 10}}'
    - delay:
        milliseconds: 300
For anyone interested in here. I have created an AppDaemon app to overcome this issue. You can easily configure a controller with a light or media player (through zigbee2mqtt, deconz and zha) and have all the needed functionality and more. You can check the documentation in here and the topic in the community forum in here.
If you have any question, you can just ask me :slight_smile:
Here’s one I’m using at the moment.
# Lighting Automation - Kid bedside light brightness toggle
   - alias: 'Kid bedside brightness toggle'
       platform: state
       entity_id: sensor.0x00158d00027cd9c5_click
       to: 'double'
       entity_id: light.kid_bedside_light
       data_template:
         transition: 1
         brightness: >
             {% set suggested = states.light.kid_bedside_light.attributes.brightness | int + 30 %}
             {% if suggested < 240 %}
             {{ suggested }}
             {% else %}
             30
             {% endif %}
