Hey guys,
Can this be done direct from an automation and could someone please share a code example?
Thanks!
Hey guys,
Thanks!
Pleaae open a separate topic, tell us your goal, post your current code and we’ll be able to help you.
Hello Noahma,
For some reason this does not work for me. Running the automation does not even turn the light on. I have a light strip to my aquarium with a cheap controller. More details about the light and set up here: How to access Lights.py in Virtual Box
When creating the automation, the strip doesn’t turn on however, when I use “wake the aquarium night light” from Google home it works.
I have built the exact same automation with you… Is it possible that in some lights it works and others not?
Thank you
Better open a new thread and post your automation properly formatted there. Without seeing your code it’s impossible to help.
Hi Burningstone,
As per your suggestion, i have raised a new topic here: Replicate Google Home Wake/Sleep lights with HA not working
Sorry I missed your post. I don’t check the forums all too often. It looks like you have the issue solved though?
BTW, which lights are you using for your Aquarium? Curious as I have a fully planted freshwater tank and am always interested in ways to automate the system more lol
Yes I did solve it by installing the Assistant_relay… So now I send text commands to Google home.
I have a cheap led from Amazon which was Bluetooth only but I bought a wifi controller… However, this is my night light… It is not for plant growth…
