How to disable wifi and bluetooth on new hass.io installation?
Never mind, I found it. For some reason I thought it would automount, then I opened up disks and looked at the SD card, found all the partitions, and mounted the boot partition. Config.txt is right there. Thank you.
Is there an updated way to disable the radios or is the following information correct?
