This may seem like a dumb question, but no answer discovered so far, so maybe it’s actually a dumb shortcoming in HA. How can one dismiss a persistent notification from the UI? There doesn’t seem to be way. There is a “dismiss notification” service, but you would need to know the numeric ID of the notification, and there’s already an unanswered feature request to add “all notifications”.
This is a notification from the Homekit control integration telling me that it detected an unpaired Homekit device, prompting me to pair it. I don’t want to pair it, and the notification doesn’t want to go away until I successfully pair it.
I know that it’s likely to recur, and there are a bunch of posts on how to try to block it from recurring, but my problem is that I can’t dismiss it at all. It just sits there with a notification icon that can’t be dismissed, demanding an action I can’t do.
I don’t think it is a dumb question at all, as I could only find the answer to it with some experimenting The id of this notification is config_entry_discovery
I created a simple automation to dismiss this notification and haven’t seen it ever since.
In the notification pane at the bottom left side of the window there is a “dismiss” button that should get rid of it.
It will still come back again later because HA keeps discovering your un-paired stuff tho.
And that’s the issue I’d like a solution for…I’d like the ability to dismiss a notification for pairing a discovered device that (semi-)permanently will ignore that specific un-paired but discovered device. That would allow us to ignore that one device but still be able to continue discovering other devices in the same integration.
I recall there was a discussion in the Architecture repo (I think) about the need to acknowledge and decline to use a discovered device. I think the sticking point was deciding for how long should the “I decline” directive should persist … because there may come a time when you do want to use it. I get the feeling nothing ever got implemented and the it just keeps reporting re-discovered devices.
I suppose one possible (bandaid) workaround is to create an automation that is triggered by a persistent_notification for discovered devices … and then call persistent_notification.dismiss to delete it. So the moment the discovery process notifies you about discovering X, the automation dismisses the notification.
I’m not sure how easy it is to accurately identify the notifications concerning discovered devices. Hopefully there’s something consistent in the title that can be used for a string-match.
I’d be interested in this too. My HA keeps “discovering” my router, and wants me to configure it as a new integration. I tried that once. It filled up my home-assistant_v2.db file so quickly I had to remove it.
I’d love to tell the notification to go away permanently. If I ever changed my mind, I could just go into Configuration / Integrations anyway.
I see what you mean. Yes there is a Dismiss when you open the specific notification with most notifications. Not on this one to set up a newly discovered Homekit device. It cannot be dismissed.
It does go away if I unplug the Homekit device so that it’s not available to discover, and then restart Home Assistant. Only to return when I plug the device back in.
Pardon my ignorance but I have next to nothing that is automatically discovered. I did experiment recently with LIFX and, when discovered, a popup message appeared in the center of the screen asking if I wished to configure it. Is that what you are seeing? Or does it appear exactly like a persistent notification but without the Dismiss button?
Screen shots attached. The top is the notification I get. When I click on it, I get the prompt box in the middle of the screen asking me to enter the HomeKit code. It will not accept the code because the device is already paired elsewhere. It will not accept a blank or an invalid code. If the prompt is closed, the notification remains. There is no way to remove the notification except to enter a valid code and have it accepted.
The notification’s presence is indicated in the traditional way (orange bubble containing the number of unread notifications) but, beyond that, it doesn’t behave like a standard persistent notification (i.e. it’s popup dialog box with no ability to truly dismiss it). Interesting.
When I let HA discover my router (TP-Link Archer C1200) it started recording all kinds of real-time network statistics. Bytes in/out, packets in/out, and tons of other things. Interesting but nothing I really need on an ongoing basis, and the database was at 3G+ and still growing when I deleted both the integration, and the database. Since then it’s been stable at a few hundred KB.
Maybe it is a bug in the discovery of the integration or configurator for that integration.
I’ve had a few devices discovered for ESPHome and I was able to dismiss them without needing to configure them so it should be the usual functionality.
I have a very similar problem with my Lutron Caseta bridge. It keeps getting detected as a Homekit device even though it’s already set up.
What I did to stop this was prevent the zeroconf: integration from loading. If you are using default_config zeroconf automatically loads. Disable default_config and manually put in all the other integrations except for zeroconf and I also don’t bother loading ssdp: as I don’t use any devices that it discovers.
This should stop your notifications. But you have to remember to re-enable zeroconf if you add a new device and want to discover it.
