How to do automation: publish mqtt message on shutdown / disconnect / restart
Mqtt configuration:
mqtt:
  broker: ip
  birth_message:
    topic: 'service/irbridge1/service/connection'
    payload: '1'
    retain: True
  will_message:
    payload: '0'
    retain: True
I notices on restart or shutdown it does not update with the will_message, so i tried this:
  - id: mqtt_on_exit
      platform: event
      event_type: homeassistant_stop
      service: mqtt.publish
        payload: '0'
        retain: True
and this:
  - id: mqtt_on_exit
      platform: homeassistant
      event: shutdown
        payload: '0'
        retain: True
This does not seem to work, either way.
Please point me in the right direction.
Thank you kindly
I use something like this
automation restart:
  alias: HA started
  initial_state: 'on'
    platform: state
    entity_id: automation.restart
    to: 'on'
    - service: mqtt.publish
        payload: '0'
        retain: True
    - service: automation.turn_off
Tried with entity_id: automation.stop / .shutdown and it doesn’t seem to work (config check failure).
I need to catch the stop/restart event when triggered from “outside” home assistant - like when the machine is rebooted.
