How to find nearest time - value
Tags: #<Tag:0x00007fc4167784b8>
Hey folks. Im woriking on a blueprint, which should allow to define a temperature profile for whole day.
One defines time to be triggered and the temperature to be set at the triggered time.
This part seems to work.
So, let asume, I have a flag, to disable or enable the temperature profile (for example in dependency on occupation of the room). So, if the flag changes, I would like to set the last temperature which would be set at the last closest time, if the profile would be active.
The idea is to compare the current time with all stored time-values and set temperature of the last closest time. Especially to the midnight I don’t get the idea, how to handle this.
Here ist the whole blueprint
blueprint:
  name: Set thermostat temperature at specific time
  description: Sets a climate entity to a specifc temperature at a set time everyday.
  domain: automation
  input:
    climate_entity:
      description: Climate entity which will get the temperature update
      selector:
        entity:
          domain: climate
    active_flag:
      description: Input boolean flag when the automation is active
      selector:
        entity:
          domain: input_boolean
    active_when:
      name: Active when flag is equal to
      description: Selection if automation is active at ON or OFF value of the flag
      selector:
        select:
          options:
            - 'on'
            - 'off'
    set_last_temperature_flag:
      name: Set last temperature
      description: Set last temperature
      selector:
        entity:
    time_to_set_1:
      default:
      description: When should the temperature be set
      selector:
        time: {}
    temp_to_set_1:
      description: Temperature to set on defined time
      default: 19.5
      selector:
        number:
          min: 10.0
          max: 30.0
          unit_of_measurement: degrees
          step: 0.5
          mode: slider
    time_to_set_2:
      default:
      selector:
        time: {}
    temp_to_set_2:
      default: 19.5
      selector:
        number:
          min: 10.0
          max: 30.0
          step: 0.5
          mode: slider
    time_to_set_3:
      default:
      selector:
        time: {}
    temp_to_set_3:
      default: 19.5
      selector:
        number:
          min: 10.0
          max: 30.0
          step: 0.5
          mode: slider
    time_to_set_4:
      default:
      selector:
        time: {}
    temp_to_set_4:
      default: 19.5
      selector:
        number:
          min: 10.0
          max: 30.0
          step: 0.5
          mode: slider
    time_to_set_5:
      default:
      selector:
        time: {}
    temp_to_set_5:
      default: 19.5
      selector:
        number:
          min: 10.0
          max: 30.0
          step: 0.5
          mode: slider
    time_to_set_6:
      default:
      selector:
        time: {}
    temp_to_set_6:
      default: 19.5
      selector:
        number:
          min: 10.0
          max: 30.0
          step: 0.5
          mode: slider
    time_to_set_7:
      default:
      selector:
        time: {}
    temp_to_set_7:
      default: 19.5
      selector:
        number:
          min: 10.0
          max: 30.0
          step: 0.5
          mode: slider
    time_to_set_8:
      default:
      selector:
        time: {}
    temp_to_set_8:
      default: 19.5
      selector:
        number:
          min: 10.0
          max: 30.0
          step: 0.5
          mode: slider
    time_to_set_9:
      default:
      selector:
        time: {}
    temp_to_set_9:
      default: 19.5
      selector:
        number:
          min: 10.0
          max: 30.0
          step: 0.5
          mode: slider
    time_to_set_10:
      default:
      selector:
        time: {}
    temp_to_set_10:
      default: 19.5
      selector:
        number:
          min: 10.0
          max: 30.0
          step: 0.5
          mode: slider
- platform: state
  entity_id: !input set_last_temperature_flag
  to: "on"
- platform: time
  at: !input 'time_to_set_1'
- platform: time
  at: !input 'time_to_set_2'
- platform: time
  at: !input 'time_to_set_3'
- platform: time
  at: !input 'time_to_set_4'
- platform: time
  at: !input 'time_to_set_5'
- platform: time
  at: !input 'time_to_set_6'
- platform: time
  at: !input 'time_to_set_7'
- platform: time
  at: !input 'time_to_set_8'
- platform: time
  at: !input 'time_to_set_9'
- platform: time
  at: !input 'time_to_set_10'
condition:
  - condition: state
    entity_id: !input active_flag
    state: !input 'active_when'
- choose:
    - conditions:
        - condition: trigger
      sequence:
        - service: climate.set_temperature
          entity_id: !input 'climate_entity'
            # find current temperature to set: TODO
            temperature: 15.5
    - conditions:
      sequence:
            temperature: !input 'temp_to_set_1'
    - conditions:
      sequence:
            temperature: !input 'temp_to_set_2'
    - conditions:
      sequence:
            temperature: !input 'temp_to_set_3'
    - conditions:
      sequence:
            temperature: !input 'temp_to_set_4'
    - conditions:
      sequence:
            temperature: !input 'temp_to_set_5'
    - conditions:
      sequence:
            temperature: !input 'temp_to_set_6'
    - conditions:
      sequence:
            temperature: !input 'temp_to_set_7'
    - conditions:
      sequence:
            temperature: !input 'temp_to_set_8'
    - conditions:
      sequence:
            temperature: !input 'temp_to_set_9'
    - conditions:
      sequence:
            temperature: !input 'temp_to_set_10'
  default: []
mode: queued
and the part I have problems with, is this one:
    - conditions:
      sequence:
            temperature: 15.5
For example:
If I have a non active profile like this
and “set last temperature” - flag is triggered at 10 pm, I would like to set 21°C, as it would be set at 7 pm.
Any ideas, hints or may be similar examples ?
Cheers.
the first draft with hard coded times looks like this.
{% set time_to_set_1 = strptime('19:00:01', "%H:%M:%S") %}
{% set time_to_set_2 = strptime('22:00:34', "%H:%M:%S") %}
{% set time_to_set_3 = strptime('23:10:00', "%H:%M:%S") %}
{% set time_to_set_4 = strptime('23:50:30', "%H:%M:%S") %}
{% set time_to_set_5 = strptime('00:00:00', "%H:%M:%S") %}
{% set temp_to_set_1 = 15 %}
{% set temp_to_set_2 = 16 %}
{% set temp_to_set_3 = 17 %}
{% set temp_to_set_4 = 18 %}
{% set temp_to_set_5 = 19 %}
{% set all_values = [[time_to_set_4, temp_to_set_4],[time_to_set_3, temp_to_set_3],[time_to_set_2, temp_to_set_2],[time_to_set_1, temp_to_set_1]] %}
{% set result = namespace(time_curr = strptime( (((as_timestamp(now()) | int ) | timestamp_custom("%H:%M:%S")) | string), "%H:%M:%S"), temp_last = all_values[all_values|length()-1][1]) %}
{# loop from last time of the day, till first set time #}
{% for curr_values  in all_values -%}
  {% if  curr_values[0] < result.time_curr -%}
    {# we found previous closest time to now() #}
    {# store the temperature #}
    {% set result.temp_last = curr_values[1] -%}
    {# break the loop #}
    {% set result.time_curr = strptime('00:00:00', "%H:%M:%S") -%}
  {% endif %}
{% endfor %}
{{result.temp_last}}
Next, I have to think how to deal with “not set values / empty” values
I’ve managed it here
