maurizio53
(Maurizio Fabiani)
November 12, 2021, 5:35pm
1
Is there a guide step by step or some documentation about how to eliminate completely every setting about duckdns, to switch completely to the NabuCasa cloud?
tom_l
November 13, 2021, 3:51am
2
Not that I found.
I just created a community guide:
This assumes no reverse proxy is being used:
Stop and then delete the DuckDNS addon.
Remove your port forwarding rules from your router. Then check that they are really gone. I can not stress this enough. I changed a running config in my router but forgot to save it. This led to the port forwarding being reinstated after a router reboot, which led to people still trying (unsuccessfully) to attack the open port.
Remove the two ssl lines from under http: in configuration.yaml
http:
ssl_certi…
Steverc
(Steve Cook)
July 7, 2023, 4:05am
3
Be sure to clear your browser history also or some addons won’t work.
