everything look ok, as it should be( in the console ) … beside “method: disabled” … should be auto
This happend most likely during installation, where he had not enabled it in VB
So yes, maybe a restart wil fix it, or he have to enable it through the console …the procedure we were about to, after colecting relevant info
PS not a restart, but a reboot … have to reboot the VB, (where the setting to define the state of network-interface is, so it can be applied to OS/interface
hopefully not, it’s HA’s “internal” network, workstation should not be there
But a cause could be as u mention (missing drivers) thou a doubt it, as it’s seems like a very common card(virtual) … it’s windows card, configured in windows
I do have internet conexión directly through the ethernet cable connected to the router and the conexión from the routher comes through a switch. I disable the WIFI.
I have internet conexión in my computer, on the phones and everything else. The internet in the router seems to be ok.
I will try with ubuntu and let you know if I can get it. Thanks
The reason for trying an Ubuntu was to see if the error is in the VirtualBox setup or in the HA setup.
I have seen VM hosts having trouble with NIC in bridge mode, because the driver used on the physical network did not allow promicious mode.
I have heard of HA installations where the NGINX setup has been corrupt.
And I have seen setup where NGINX and the VirtualBox use the same subnet, causing routing to fail.
A normal desktop Ubuntu could rule some of these out, because the diagnostic tools are better.
yes, but as it was obvious that he got no ip, and interface was disabled ( most likely because he enabled wifi during setup, and then changed to Ethernet, it would still remain disabled, and unavailable , unless a reboot could fix that, which it didn’t … there are this way, or just try reinstall, cording to recommended details
PS: i don’t use VB my self, for about the reasons you mention , VMware have been my faitful choice for decades
Edit: or ssh, which i think we should exclude
