Here is my openwrt version.
[email protected]:~# uname -a
Linux OpenWrt 4.14.221 #0 SMP Mon Feb 15 15:22:37 2021 x86_64 GNU/Linux
The python version:
[email protected]:~# python3
Python 3.7.10 (default, May 28 2021, 13:26:31)
[GCC 7.5.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
Let 's install homeassistant.
[email protected]:~# python3 -m pip install homeassistant
Collecting homeassistant
Using cached homeassistant-2021.1.5-py3-none-any.whl (10.2 MB)
Collecting voluptuous==0.12.1
Downloading voluptuous-0.12.1-py3-none-any.whl (29 kB)
Collecting pyyaml==5.3.1
Using cached PyYAML-5.3.1.tar.gz (269 kB)
Collecting pip<20.3,>=8.0.3
Using cached pip-20.2.4-py2.py3-none-any.whl (1.5 MB)
Collecting cryptography==3.2
Using cached cryptography-3.2.tar.gz (540 kB)
Installing build dependencies ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /tmp/pip-standalone-pip-l9ejx5j5/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-9u9mzgse/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.8,!=1.11.3; platform_python_implementation != '"'"'PyPy'"'"''
cwd: None
Complete output (110 lines):
Collecting setuptools>=40.6.0
Using cached setuptools-57.0.0-py3-none-any.whl (821 kB)
Collecting wheel
Using cached wheel-0.36.2-py2.py3-none-any.whl (35 kB)
Collecting cffi!=1.11.3,>=1.8
Using cached cffi-1.14.5.tar.gz (475 kB)
Collecting pycparser
Using cached pycparser-2.20-py2.py3-none-any.whl (112 kB)
Building wheels for collected packages: cffi
Building wheel for cffi (setup.py): started
Building wheel for cffi (setup.py): finished with status 'error'
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-mzqd7ikc/cffi_3e5974005d6f4e32a42ba117208ca900/setup.py'"'"'; __file__='"'"'/tmp/pip-install-mzqd7ikc/cffi_3e5974005d6f4e32a42ba117208ca900/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-8opitqj2
cwd: /tmp/pip-install-mzqd7ikc/cffi_3e5974005d6f4e32a42ba117208ca900/
Complete output (41 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.7
creating build/lib.linux-x86_64-3.7/cffi
copying cffi/verifier.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/vengine_gen.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/recompiler.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/pkgconfig.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/model.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/lock.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/ffiplatform.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/error.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/cparser.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/commontypes.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/api.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/__init__.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/_cffi_include.h -> build/lib.linux-x86_64-3.7/cffi
copying cffi/parse_c_type.h -> build/lib.linux-x86_64-3.7/cffi
copying cffi/_embedding.h -> build/lib.linux-x86_64-3.7/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-x86_64-3.7/cffi
warning: build_py: byte-compiling is disabled, skipping.
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-x86_64-3.7
creating build/temp.linux-x86_64-3.7/c
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -Os -pipe -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -iremap/builder/shared-workdir/build/sdk/build_dir/target-x86_64_musl/Python-3.7.10:Python-3.7.10 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -Os -pipe -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -iremap/builder/shared-workdir/build/sdk/build_dir/target-x86_64_musl/Python-3.7.10:Python-3.7.10 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -DNDEBUG -fno-inline -Os -pipe -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -iremap/builder/shared-workdir/build/sdk/build_dir/target-x86_64_musl/Python-3.7.10:Python-3.7.10 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -DNDEBUG -fno-inline -I/builder/shared-workdir/build/sdk/staging_dir/target-x86_64_musl/usr/include -I/builder/shared-workdir/build/sdk/staging_dir/target-x86_64_musl/include -I/builder/shared-workdir/build/sdk/staging_dir/toolchain-x86_64_gcc-7.5.0_musl/usr/include -I/builder/shared-workdir/build/sdk/staging_dir/toolchain-x86_64_gcc-7.5.0_musl/include/fortify -I/builder/shared-workdir/build/sdk/staging_dir/toolchain-x86_64_gcc-7.5.0_musl/include -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python3.7 -c c/_cffi_backend.c -o build/temp.linux-x86_64-3.7/c/_cffi_backend.o
c/_cffi_backend.c: In function 'fb_prepare_cif':
c/_cffi_backend.c:5887:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (status == -1) {
gcc -shared -L/builder/shared-workdir/build/sdk/staging_dir/target-x86_64_musl/usr/lib -L/builder/shared-workdir/build/sdk/staging_dir/target-x86_64_musl/lib -L/builder/shared-workdir/build/sdk/staging_dir/toolchain-x86_64_gcc-7.5.0_musl/usr/lib -L/builder/shared-workdir/build/sdk/staging_dir/toolchain-x86_64_gcc-7.5.0_musl/lib -znow -zrelro -L/builder/shared-workdir/build/sdk/build_dir/target-x86_64_musl/Python-3.7.10 -L/builder/shared-workdir/build/sdk/staging_dir/target-x86_64_musl/usr/lib -L/builder/shared-workdir/build/sdk/staging_dir/target-x86_64_musl/lib -L/builder/shared-workdir/build/sdk/staging_dir/toolchain-x86_64_gcc-7.5.0_musl/usr/lib -L/builder/shared-workdir/build/sdk/staging_dir/toolchain-x86_64_gcc-7.5.0_musl/lib -znow -zrelro -L/builder/shared-workdir/build/sdk/build_dir/target-x86_64_musl/Python-3.7.10 build/temp.linux-x86_64-3.7/c/_cffi_backend.o -L/usr/lib -lffi -lpython3.7 -o build/lib.linux-x86_64-3.7/_cffi_backend.cpython-37.so
/usr/bin/ld: cannot find -lffi
collect2: error: ld returned 1 exit status
error: command 'gcc' failed with exit status 1
ERROR: Failed building wheel for cffi
Running setup.py clean for cffi
Failed to build cffi
Installing collected packages: pycparser, wheel, setuptools, cffi
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'error'
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-mzqd7ikc/cffi_3e5974005d6f4e32a42ba117208ca900/setup.py'"'"'; __file__='"'"'/tmp/pip-install-mzqd7ikc/cffi_3e5974005d6f4e32a42ba117208ca900/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-mp68j1b4/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-9u9mzgse/overlay --compile --install-headers /tmp/pip-build-env-9u9mzgse/overlay/include/python3.7/cffi
running install
running build
running build_py
creating build
running build_ext
if (status == -1) {
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-mzqd7ikc/cffi_3e5974005d6f4e32a42ba117208ca900/setup.py'"'"'; __file__='"'"'/tmp/pip-install-mzqd7ikc/cffi_3e5974005d6f4e32a42ba117208ca900/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-mp68j1b4/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-9u9mzgse/overlay --compile --install-headers /tmp/pip-build-env-9u9mzgse/overlay/include/python3.7/cffi Check the logs for full command output.
WARNING: Discarding https://files.pythonhosted.org/packages/1c/15/aceb9a2535c9fa805316b49e42fde0a83d1a0492b4e3608a4a5dc9b04b46/cryptography-3.2.tar.gz#sha256=e4789b84f8dedf190148441f7c5bfe7244782d9cbb194a36e17b91e7d3e1cca9 (from https://pypi.org/simple/cryptography/) (requires-python:>=2.7,!=3.0.*,!=3.1.*,!=3.2.*,!=3.3.*,!=3.4.*). Command errored out with exit status 1: /usr/bin/python3 /tmp/pip-standalone-pip-l9ejx5j5/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-9u9mzgse/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.8,!=1.11.3; platform_python_implementation != '"'"'PyPy'"'"'' Check the logs for full command output.
How to fix it?
