### System Health details
### Checklist
- [X] I'm running the newest version of HACS <https://github.com/hacs/integration/releases/latest>
- [X] I have enabled debug logging for my installation.
- [X] I have filled out the issue template to the best of my ability.
- [X] I have read <https://hacs.xyz/docs/issues>
- [X] This issue is related to the backend (integration part) of HACS.
- [X] This issue only contains 1 issue (if you have multiple issues, open one issue for each issue).
### Describe the issue
owner of bpost hacs integration removed repository from github and hacs now request it to remove but this does not work (several attempt including HA restart), consequence is that update sensor is 'unknown'
### Reproduction steps
1.
2.
3.
### Debug logs
```text
2022-01-24 09:42:33 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration dwains_dashboard which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration samsungtv_tizen which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration automower which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration auto_backup which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration powercalc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration husqvarna_automower which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration sonos_alarm which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration cellar_tracker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration formulaone_api which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration monitor_docker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration afvalbeheer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration anniversary which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration deebot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration neerslag which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration battery_sim which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up recorder
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up http
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up system_log
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {'person', 'config', 'analytics', 'websocket_api', 'device_automation', 'system_log', 'search', 'frontend', 'cloud', 'http', 'onboarding', 'image', 'api', 'hassio', 'lovelace', 'webhook', 'auth'}
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up config
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up api
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up hassio
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up webhook
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up auth
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.1 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up search
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up image
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up analytics
2022-01-24 09:42:33 INFO (SyncWorker_0) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
2022-01-24 09:42:33 INFO (SyncWorker_0) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain analytics took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain image took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up person
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up cloud
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.2 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.helpers.storage] Migrating onboarding storage from 3.1 to 4.1
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds
2022-01-24 09:42:33 INFO (SyncWorker_5) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setting up frontend
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds
2022-01-24 09:42:33 INFO (MainThread) [homeassistant.components.http] Now listening on port 8123
2022-01-24 09:42:34 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.9 seconds
2022-01-24 09:42:34 INFO (MainThread) [snitun.utils.aiohttp_client] AioHTTP snitun client started on 127.0.0.1:58123
2022-01-24 09:42:35 INFO (MainThread) [snitun.utils.aiohttp_client] AioHTTP snitun client connected to: eu-central-1-1.ui.nabu.casa:443
2022-01-24 09:42:36 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139892347373744] Received invalid command: browser_mod/update
2022-01-24 09:42:39 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 6.4 seconds
2022-01-24 09:42:39 INFO (SyncWorker_5) [homeassistant.loader] Loaded ping from homeassistant.components.ping
2022-01-24 09:42:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded threshold from homeassistant.components.threshold
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'cellar_tracker', 'template', 'script', 'usb', 'verisure', 'husqvarna_automower', 'dlna_dmr', 'updater', 'ifttt', 'tts', 'monitor_docker', 'auto_backup', 'met', 'coronavirus', 'dhcp', 'cast', 'blueprint', 'sensor', 'notify', 'devolo_home_control', 'ipp', 'media_player', 'map', 'media_source', 'my', 'samsungtv', 'timer', 'counter', 'input_datetime', 'ring', 'automation', 'persistent_notification', 'camera', 'logbook', 'openuv', 'battery_sim', 'trace', 'history', 'system_health', 'ffmpeg', 'input_text', 'adguard', 'sun', 'zone', 'calendar', 'ios', 'speedtestdotnet', 'buienradar', 'sonos', 'input_select', 'google', 'input_boolean', 'network', 'influxdb', 'hacs', 'co2signal', 'mobile_app', 'zeroconf', 'local_ip', 'device_tracker', 'input_number', 'tuya', 'energy', 'binary_sensor', 'browser_mod', 'airvisual', 'scene', 'apple_tv', 'forecast_solar', 'icloud', 'hue', 'mqtt', 'switch', 'ssdp', 'group', 'neerslag', 'default_config', 'python_script', 'tag', 'utility_meter', 'devolo_home_network'}
2022-01-24 09:42:40 INFO (SyncWorker_0) [homeassistant.loader] Loaded systemmonitor from homeassistant.components.systemmonitor
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up cellar_tracker
2022-01-24 09:42:40 INFO (SyncWorker_3) [cellartracker.api] Connecting to https://www.cellartracker.com/xlquery.asp
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up updater
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up monitor_docker
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain monitor_docker took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up auto_backup
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain auto_backup took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up met
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain met took 0.0 seconds
2022-01-24 09:42:40 ERROR (Thread-3) [custom_components.monitor_docker.helpers] [Docker]: Can not connect to Docker API (Missing valid docker_host.Either DOCKER_HOST or local sockets are not available.)
File "/config/custom_components/monitor_docker/helpers.py", line 162, in __init__
self._api = aiodocker.Docker(url=url)
File "/usr/local/lib/python3.9/site-packages/aiodocker/docker.py", line 99, in __init__
raise ValueError(
ValueError: Missing valid docker_host.Either DOCKER_HOST or local sockets are not available.
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up coronavirus
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up dhcp
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up blueprint
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain blueprint took 0.0 seconds
2022-01-24 09:42:40 INFO (SyncWorker_1) [homeassistant.loader] Loaded smtp from homeassistant.components.smtp
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up media_player
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up map
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up media_source
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up my
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain my took 0.0 seconds
2022-01-24 09:42:40 INFO (SyncWorker_4) [homeassistant.util.package] Attempting install of wakeonlan==2.0.1
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up timer
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up counter
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up input_datetime
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up logbook
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up battery_sim
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain battery_sim took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up trace
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain trace took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up history
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up system_health
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up input_text
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up sun
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up zone
2022-01-24 09:42:40 INFO (SyncWorker_6) [homeassistant.loader] Loaded caldav from homeassistant.components.caldav
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up input_select
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up input_number
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up browser_mod
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain browser_mod took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up scene
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up group
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up neerslag
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain neerslag took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up tag
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.samsungtv_tizen
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [custom_components.auto_backup] Setting up Auto Backup config entry 06d35da972a53b89c48540af5ce7af05
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up notify
2022-01-24 09:42:40 INFO (SyncWorker_0) [custom_components.samsungtv_tizen.media_player] Samsung TV 192.168.0.172:8002 added as 'Samsung TV Remote'
2022-01-24 09:42:40 INFO (SyncWorker_1) [homeassistant.loader] Loaded light from homeassistant.components.light
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up switch
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.threshold
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up usb
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain usb took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up verisure
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain verisure took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up husqvarna_automower
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain husqvarna_automower took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up ifttt
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain ifttt took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.notify] Setting up notify.smtp
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain media_source took 0.4 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.4 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.4 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up energy
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain energy took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up ping
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.hassio
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up light
2022-01-24 09:42:40 INFO (MainThread) [custom_components.husqvarna_automower]
husqvarna_automower
Version: 2021.12.0
This is a custom integration!
If you have any issues with this you need to open an issue here:
https://github.com/Thomas55555/husqvarna_automower
2022-01-24 09:42:40 INFO (Thread-4) [homeassistant.components.mqtt] Connected to MQTT server core-mosquitto:1883 (0)
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.browser_mod
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.browser_mod
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain ping took 0.1 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.updater
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain light took 0.1 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain timer took 0.5 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain input_datetime took 0.5 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain tag took 0.5 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain input_text took 0.5 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.ping
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.5 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.light] Setting up light.browser_mod
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.5 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up template
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain template took 0.0 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain counter took 0.7 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.template
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.components.switch] Setting up switch.template
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.7 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 0.7 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 0.7 seconds
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
2022-01-24 09:42:40 INFO (MainThread) [homeassistant.setup] Setting up automation
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 0.7 seconds
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 0.0 seconds
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setting up script
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setup of domain coronavirus took 1.0 seconds
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.husqvarna_automower
2022-01-24 09:42:41 INFO (SyncWorker_3) [cellartracker.api] Successfully connected to https://www.cellartracker.com/xlquery.asp
2022-01-24 09:42:41 INFO (SyncWorker_5) [homeassistant.loader] Loaded vacuum from homeassistant.components.vacuum
2022-01-24 09:42:41 INFO (SyncWorker_5) [homeassistant.loader] Loaded select from homeassistant.components.select
2022-01-24 09:42:41 INFO (SyncWorker_5) [homeassistant.loader] Loaded number from homeassistant.components.number
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setting up vacuum
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setup of domain vacuum took 0.0 seconds
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setting up select
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setup of domain select took 0.0 seconds
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setting up number
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setup of domain number took 0.0 seconds
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setup of domain cellar_tracker took 1.2 seconds
2022-01-24 09:42:41 INFO (SyncWorker_1) [homeassistant.loader] Loaded weather from homeassistant.components.weather
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.components.vacuum] Setting up vacuum.husqvarna_automower
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.components.select] Setting up select.husqvarna_automower
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.components.number] Setting up number.husqvarna_automower
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 1.0 seconds
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setting up weather
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 0.0 seconds
2022-01-24 09:42:41 INFO (MainThread) [homeassistant.components.weather] Setting up weather.met
2022-01-24 09:42:41 INFO (MainThread) [aioautomower.session] Websocket (re)connected
2022-01-24 09:42:43 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.verisure
2022-01-24 09:42:43 INFO (MainThread) [homeassistant.components.switch] Setting up switch.verisure
2022-01-24 09:42:43 INFO (SyncWorker_5) [homeassistant.loader] Loaded alarm_control_panel from homeassistant.components.alarm_control_panel
2022-01-24 09:42:43 INFO (SyncWorker_5) [homeassistant.loader] Loaded lock from homeassistant.components.lock
2022-01-24 09:42:43 INFO (MainThread) [homeassistant.setup] Setting up alarm_control_panel
2022-01-24 09:42:43 INFO (MainThread) [homeassistant.setup] Setup of domain alarm_control_panel took 0.0 seconds
2022-01-24 09:42:43 INFO (MainThread) [homeassistant.setup] Setting up lock
2022-01-24 09:42:43 INFO (MainThread) [homeassistant.setup] Setup of domain lock took 0.0 seconds
2022-01-24 09:42:43 INFO (MainThread) [homeassistant.components.alarm_control_panel] Setting up alarm_control_panel.verisure
2022-01-24 09:42:43 INFO (MainThread) [homeassistant.components.lock] Setting up lock.verisure
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setting up openuv
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setup of domain openuv took 0.0 seconds
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setting up ffmpeg
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setting up adguard
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setup of domain adguard took 0.0 seconds
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setting up camera
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setting up speedtestdotnet
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setup of domain speedtestdotnet took 0.0 seconds
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setting up buienradar
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setup of domain buienradar took 0.0 seconds
2022-01-24 09:42:45 INFO (SyncWorker_7) [homeassistant.util.package] Attempting install of httplib2==0.19.0
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setup of domain camera took 0.0 seconds
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.setup] Setup of domain ffmpeg took 0.1 seconds
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.components.weather] Setting up weather.buienradar
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.components.camera] Setting up camera.browser_mod
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.components.camera] Setting up camera.verisure
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.components.camera] Setting up camera.buienradar
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.components.camera] Setting up camera.ffmpeg
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.components.switch] Setting up switch.adguard
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.openuv
2022-01-24 09:42:45 INFO (MainThread) [homeassistant.components.openuv] Skipping update due to missing data: from_time
2022-01-24 09:42:48 INFO (MainThread) [hass_nabucasa.iot] Connected
2022-01-24 09:42:48 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.cloud
2022-01-24 09:42:48 INFO (SyncWorker_2) [homeassistant.loader] Loaded stt from homeassistant.components.stt
2022-01-24 09:42:48 INFO (MainThread) [homeassistant.setup] Setting up stt
2022-01-24 09:42:48 INFO (MainThread) [homeassistant.setup] Setup of domain stt took 0.0 seconds
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up google
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up influxdb
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up co2signal
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain co2signal took 0.0 seconds
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up network
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain network took 0.0 seconds
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up airvisual
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain airvisual took 0.0 seconds
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up hacs
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain hacs took 0.0 seconds
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up forecast_solar
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain forecast_solar took 0.0 seconds
2022-01-24 09:42:49 INFO (MainThread) [keyring.backend] Loading Gnome
2022-01-24 09:42:49 INFO (MainThread) [keyring.backend] Loading Google
2022-01-24 09:42:49 INFO (MainThread) [keyring.backend] Loading Windows (alt)
2022-01-24 09:42:49 INFO (MainThread) [keyring.backend] Loading file
2022-01-24 09:42:49 INFO (MainThread) [keyring.backend] Loading keyczar
2022-01-24 09:42:49 INFO (MainThread) [keyring.backend] Loading multi
2022-01-24 09:42:49 INFO (MainThread) [keyring.backend] Loading pyfs
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up icloud
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain icloud took 0.0 seconds
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain influxdb took 0.1 seconds
2022-01-24 09:42:49 INFO (MainThread) [custom_components.hacs]
HACS (Home Assistant Community Store)
Version: 1.19.3
https://github.com/hacs/integration/issues
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up local_ip
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain local_ip took 0.0 seconds
2022-01-24 09:42:49 INFO (SyncWorker_3) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up python_script
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain google took 0.2 seconds
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up utility_meter
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up calendar
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain calendar took 0.0 seconds
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.components.calendar] Setting up calendar.caldav
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain python_script took 0.1 seconds
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.components.calendar] Setting up calendar.husqvarna_automower
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2022-01-24 09:42:49 INFO (SyncWorker_7) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.components.calendar] Setting up calendar.google
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setting up ipp
2022-01-24 09:42:49 INFO (MainThread) [homeassistant.setup] Setup of domain ipp took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up apple_tv
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain apple_tv took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up devolo_home_network
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain devolo_home_network took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up tts
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.3 seconds
2022-01-24 09:42:50 INFO (SyncWorker_0) [homeassistant.loader] Loaded fan from homeassistant.components.fan
2022-01-24 09:42:50 INFO (SyncWorker_0) [homeassistant.loader] Loaded integration from homeassistant.components.integration
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up ring
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain ring took 0.0 seconds
2022-01-24 09:42:50 INFO (SyncWorker_5) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] Configuration type: ConfigurationType.CONFIG_ENTRY
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up tuya
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain tuya took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up samsungtv
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain samsungtv took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up hue
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain hue took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.apple_tv
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.1 seconds
2022-01-24 09:42:50 INFO (SyncWorker_0) [homeassistant.loader] Loaded remote from homeassistant.components.remote
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up ios
2022-01-24 09:42:50 INFO (MainThread) [custom_components.hacs] Loaded 12 tasks
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] Scheduling HacsTask<check_ratelimit> to run every 1:00:00
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] Scheduling HacsTask<prosess_queue> to run every 0:10:00
2022-01-24 09:42:50 INFO (SyncWorker_3) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/calendar/v3/users/me/calendarList?alt=json
2022-01-24 09:42:50 INFO (MainThread) [custom_components.hacs] Stage changed: HacsStage.SETUP
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<activate_categories> Executing task
2022-01-24 09:42:50 INFO (MainThread) [custom_components.hacs] Enable category: integration
2022-01-24 09:42:50 INFO (MainThread) [custom_components.hacs] Enable category: plugin
2022-01-24 09:42:50 INFO (MainThread) [custom_components.hacs] Enable category: python_script
2022-01-24 09:42:50 INFO (MainThread) [custom_components.hacs] Enable category: theme
2022-01-24 09:42:50 INFO (MainThread) [custom_components.hacs] Enable category: appdaemon
2022-01-24 09:42:50 INFO (MainThread) [custom_components.hacs] Enable category: netdaemon
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<activate_categories> took 0.001 seconds to complete
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<setup_sensor> Executing task
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<setup_sensor> took 0.000 seconds to complete
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<setup_frontend> Executing task
2022-01-24 09:42:50 INFO (MainThread) [custom_components.hacs] HacsTask<setup_frontend> storage mode, cache for /hacsfiles/: True
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<setup_frontend> took 0.003 seconds to complete
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<setup_websocket_api> Executing task
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<setup_websocket_api> took 0.000 seconds to complete
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<clear_old_storage> Executing task
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<verify_api> Executing task
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<check_constrains> Executing task
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<restore_data> Executing task
2022-01-24 09:42:50 INFO (SyncWorker_2) [homeassistant.loader] Loaded fitbit from homeassistant.components.fitbit
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up remote
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain remote took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain ios took 0.2 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.samsungtv
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<clear_old_storage> took 0.058 seconds to complete
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<check_constrains> took 0.058 seconds to complete
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.remote] Setting up remote.apple_tv
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up devolo_home_control
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain devolo_home_control took 0.0 seconds
2022-01-24 09:42:50 INFO (SyncWorker_0) [homeassistant.loader] Loaded configurator from homeassistant.components.configurator
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.mobile_app
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.mobile_app
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.3 seconds
2022-01-24 09:42:50 INFO (SyncWorker_8) [homeassistant.loader] Loaded plex from homeassistant.components.plex
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.notify] Setting up notify.ios
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up dlna_dmr
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain dlna_dmr took 0.0 seconds
2022-01-24 09:42:50 INFO (SyncWorker_5) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/calendar/v3/calendars/steurs.eddy%40gmail.com/events?orderBy=startTime&singleEvents=true&maxResults=100&timeMin=2022-01-24T09%3A42%3A50.562502%2B01%3A00&alt=json
2022-01-24 09:42:50 INFO (SyncWorker_9) [homeassistant.loader] Loaded rest from homeassistant.components.rest
2022-01-24 09:42:50 INFO (MainThread) [custom_components.hacs] Restore started
2022-01-24 09:42:50 INFO (SyncWorker_9) [homeassistant.loader] Loaded sql from homeassistant.components.sql
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.dlna_dmr
2022-01-24 09:42:50 INFO (SyncWorker_9) [homeassistant.loader] Loaded command_line from homeassistant.components.command_line
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up sonos
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain sonos took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up cast
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain cast took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up sensor
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mqtt
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.anniversary
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.formulaone_api
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.systemmonitor
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.afvalbeheer
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.template
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.integration
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.influxdb
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.sql
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.command_line
2022-01-24 09:42:50 INFO (MainThread) [custom_components.hacs] Restore done
2022-01-24 09:42:50 DEBUG (MainThread) [custom_components.hacs] HacsTask<restore_data> took 0.458 seconds to complete
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up rest
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain rest took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hassio
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.browser_mod
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.neerslag
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.auto_backup
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.coronavirus
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.verisure
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.buienradar
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.adguard
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.openuv
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.speedtestdotnet
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.local_ip
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.co2signal
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mobile_app
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.ios
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.forecast_solar
2022-01-24 09:42:50 INFO (SyncWorker_3) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up fan
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain fan took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setting up configurator
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.setup] Setup of domain configurator took 0.0 seconds
2022-01-24 09:42:50 INFO (MainThread) [custom_components.neerslag.sensor] --<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<>>>>>>>>>--->>>>>>>>>>>>>>>>>>>>>>>>
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.sonos
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.switch] Setting up switch.sonos
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.sonos
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.number] Setting up number.sonos
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.sonos
2022-01-24 09:42:50 WARNING (MainThread) [homeassistant.components.systemmonitor.sensor] Cannot read CPU / processor temperature information
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rest
2022-01-24 09:42:50 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.formula_one_sensor (<class 'custom_components.formulaone_api.sensor.FormulaOneSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.battery_sim
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.energy
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.cellar_tracker
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.cast
2022-01-24 09:42:50 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.formula_one_sensor fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 487, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 691, in async_device_update
raise exc
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/config/custom_components/formulaone_api/sensor.py", line 237, in update
self.set_state()
File "/config/custom_components/formulaone_api/sensor.py", line 216, in set_state
all_attr = self.get_race_data()
File "/config/custom_components/formulaone_api/sensor.py", line 190, in get_race_data
races = f1.current_schedule().json
File "/config/custom_components/formulaone_api/sensor.py", line 81, in json
self._json = self.make_request(".json")
File "/config/custom_components/formulaone_api/sensor.py", line 70, in make_request
return requests.get(self.url, params=querystring)
File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 528, in request
prep = self.prepare_request(req)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 456, in prepare_request
p.prepare(
File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 316, in prepare
self.prepare_url(url, params)
File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 390, in prepare_url
raise MissingSchema(error)
requests.exceptions.MissingSchema: Invalid URL '.json': No schema supplied. Perhaps you meant http://.json?
2022-01-24 09:42:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.fitbit
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_albari_o (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.setup] Setup of automation is taking over 10 seconds.
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.camera] Setting up camera.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.fan] Setting up fan.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.light] Setting up light.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.number] Setting up number.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.scene] Setting up scene.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.select] Setting up select.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.switch] Setting up switch.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.vacuum] Setting up vacuum.tuya
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_alicante_bouschet (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 INFO (SyncWorker_12) [homeassistant.loader] Loaded button from homeassistant.components.button
2022-01-24 09:42:51 INFO (SyncWorker_12) [homeassistant.loader] Loaded climate from homeassistant.components.climate
2022-01-24 09:42:51 INFO (SyncWorker_12) [homeassistant.loader] Loaded cover from homeassistant.components.cover
2022-01-24 09:42:51 INFO (SyncWorker_12) [homeassistant.loader] Loaded humidifier from homeassistant.components.humidifier
2022-01-24 09:42:51 INFO (SyncWorker_10) [homeassistant.loader] Loaded siren from homeassistant.components.siren
2022-01-24 09:42:51 DEBUG (MainThread) [aiogithubapi] 'GitHubRateLimitResourcesModel' is missing key 'actions_runner_registration' for <class 'dict'>
2022-01-24 09:42:51 DEBUG (MainThread) [aiogithubapi] 'GitHubRateLimitResourcesModel' is missing key 'scim' for <class 'dict'>
2022-01-24 09:42:51 DEBUG (MainThread) [custom_components.hacs] HacsTask<verify_api> Can update 225 repositories
2022-01-24 09:42:51 DEBUG (MainThread) [custom_components.hacs] HacsTask<verify_api> took 0.809 seconds to complete
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setting up button
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setup of domain button took 0.0 seconds
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setting up climate
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setup of domain climate took 0.0 seconds
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setting up cover
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setup of domain cover took 0.0 seconds
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setting up humidifier
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setup of domain humidifier took 0.0 seconds
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setting up siren
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setup of domain siren took 0.0 seconds
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_carignan (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 INFO (MainThread) [custom_components.hacs] Stage changed: HacsStage.WAITING
2022-01-24 09:42:51 INFO (MainThread) [custom_components.hacs] Setup complete, waiting for Home Assistant before startup tasks starts
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.button] Setting up button.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.climate] Setting up climate.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.cover] Setting up cover.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.humidifier] Setting up humidifier.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.siren] Setting up siren.tuya
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 10.3 seconds
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_champagne_blend (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.light] Setting up light.hue
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.hue
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hue
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.scene] Setting up scene.hue
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.switch] Setting up switch.hue
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hacs
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_grenache_blend (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setting up default_config
2022-01-24 09:42:51 INFO (SyncWorker_10) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_malbec (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_marselan (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setting up stream
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.0 seconds
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.0 seconds
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_merlot (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_pinot_noir (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_port_blend (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_primitivo (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_red_rhone_blend (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_ros_blend (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_sauvignon (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_sauvignon_blanc (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_syrah (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_syrah_blend (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_s_millon (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_white_rhone_blend (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_varietal_zinfandel (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_country_argentina (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_country_australia (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_country_belgium (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_country_france (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_country_italy (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_country_new_zealand (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_country_portugal (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_country_spain (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_country_usa (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_vintage_1001 (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_vintage_2014 (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_vintage_2015 (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_vintage_2016 (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_vintage_2017 (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_vintage_2018 (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_vintage_2019 (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_vintage_2020 (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_albamar (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_alma_negra (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_baron_albert (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_bodega_vistalba (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_cantina_sampietrana (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_caza_de_perdices (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_ch_teau_de_l_escarelle (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_cloudy_bay (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_domaine_de_berguerolles (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_domaine_de_poulvarel (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_fonseca (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_grande_alberone (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_joel_gott (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_kentia (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_moss_wood (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_rolf_binder_veritas (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_seresin (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_ten_gaerde (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_tikal (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_torres (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_producer_venta_d_aubert (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_type_red (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_type_red_fortified (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_type_ros (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_type_ros_sparkling (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_type_white (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_type_white_sparkling (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_total_bottles (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_total_value (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.cellar_tracker_average_value (<class 'custom_components.cellar_tracker.sensor.WineCellarSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setup of domain utility_meter took 1.7 seconds
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.utility_meter
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setting up powercalc
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.setup] Setup of domain powercalc took 0.0 seconds
2022-01-24 09:42:51 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.powercalc
2022-01-24 09:42:51 ERROR (MainThread) [custom_components.powercalc.sensors.power] Skipping sensor setup light.terras_7: Cannot select a mode (LINEAR, FIXED or LUT, WLED), supply it in the config
2022-01-24 09:42:51 ERROR (MainThread) [custom_components.powercalc.model_discovery] light.staanlamp_living: Cannot autodiscover model, manufacturer or model unknown from device registry
2022-01-24 09:42:51 ERROR (MainThread) [custom_components.powercalc.sensors.power] Skipping sensor setup light.staanlamp_living: Cannot select a mode (LINEAR, FIXED or LUT, WLED), supply it in the config
2022-01-24 09:42:51 ERROR (MainThread) [custom_components.powercalc.sensors.power] Skipping sensor setup light.light_4: ('No lookup file found for mode', 'brightness')
2022-01-24 09:42:51 ERROR (MainThread) [custom_components.powercalc.sensors.power] Skipping sensor setup light.light_6: ('No lookup file found for mode', 'brightness')
2022-01-24 09:42:51 INFO (SyncWorker_3) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/calendar/v3/calendars/en-gb.be%23holiday%40group.v.calendar.google.com/events?orderBy=startTime&singleEvents=true&maxResults=100&timeMin=2022-01-24T09%3A42%3A51.784225%2B01%3A00&alt=json
2022-01-24 09:42:51 INFO (SyncWorker_5) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2022-01-24 09:42:51 INFO (MainThread) [custom_components.neerslag.sensor] getBuienradarData - timeout
2022-01-24 09:42:52 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.airvisual
2022-01-24 09:42:52 INFO (SyncWorker_8) [HomeControl] Searching for gateway in LAN.
2022-01-24 09:42:52 INFO (SyncWorker_5) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/calendar/v3/calendars/addressbook%23contacts%40group.v.calendar.google.com/events?orderBy=startTime&singleEvents=true&maxResults=100&timeMin=2022-01-24T09%3A42%3A52.693559%2B01%3A00&alt=json
2022-01-24 09:42:52 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.ring
2022-01-24 09:42:52 INFO (MainThread) [homeassistant.components.light] Setting up light.ring
2022-01-24 09:42:52 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.ring
2022-01-24 09:42:52 INFO (MainThread) [homeassistant.components.switch] Setting up switch.ring
2022-01-24 09:42:52 INFO (MainThread) [homeassistant.components.camera] Setting up camera.ring
2022-01-24 09:42:52 INFO (SyncWorker_5) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2022-01-24 09:42:52 INFO (SyncWorker_8) [HomeControl] Connecting to gateway locally.
2022-01-24 09:42:53 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Canon MF8200C Series' for ipp integration not ready yet: Invalid response from API: Error occurred while communicating with IPP server.; Retrying in background
2022-01-24 09:42:53 INFO (SyncWorker_5) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/calendar/v3/calendars/ekqk1nbdusr1baon1ic42oeeik%40group.calendar.google.com/events?orderBy=startTime&singleEvents=true&maxResults=100&q=FP1&timeMin=2022-01-24T09%3A42%3A53.744263%2B01%3A00&alt=json
2022-01-24 09:42:53 INFO (SyncWorker_8) [HomeControl] Inspecting devices
2022-01-24 09:42:53 INFO (SyncWorker_1) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2022-01-24 09:42:54 INFO (SyncWorker_1) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/calendar/v3/calendars/ekqk1nbdusr1baon1ic42oeeik%40group.calendar.google.com/events?orderBy=startTime&singleEvents=true&maxResults=100&q=FP2&timeMin=2022-01-24T09%3A42%3A54.375694%2B01%3A00&alt=json
2022-01-24 09:42:54 INFO (SyncWorker_15) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2022-01-24 09:42:54 ERROR (MainThread) [homeassistant.components.calendar] Entity id already exists - ignoring: calendar.family
2022-01-24 09:42:54 INFO (SyncWorker_15) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/calendar/v3/calendars/ekqk1nbdusr1baon1ic42oeeik%40group.calendar.google.com/events?orderBy=startTime&singleEvents=true&maxResults=100&q=FP3&timeMin=2022-01-24T09%3A42%3A54.974204%2B01%3A00&alt=json
2022-01-24 09:42:55 INFO (SyncWorker_12) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2022-01-24 09:42:55 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.icloud
2022-01-24 09:42:55 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.icloud
2022-01-24 09:42:55 INFO (SyncWorker_12) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/calendar/v3/calendars/ekqk1nbdusr1baon1ic42oeeik%40group.calendar.google.com/events?orderBy=startTime&singleEvents=true&maxResults=100&q=QUALIFYING&timeMin=2022-01-24T09%3A42%3A55.470082%2B01%3A00&alt=json
2022-01-24 09:42:55 INFO (SyncWorker_4) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2022-01-24 09:42:56 INFO (SyncWorker_4) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/calendar/v3/calendars/ekqk1nbdusr1baon1ic42oeeik%40group.calendar.google.com/events?orderBy=startTime&singleEvents=true&maxResults=100&q=RACE%3A&timeMin=2022-01-24T09%3A42%3A56.230888%2B01%3A00&alt=json
2022-01-24 09:42:56 INFO (SyncWorker_1) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2022-01-24 09:42:56 INFO (SyncWorker_1) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/calendar/v3/calendars/ekqk1nbdusr1baon1ic42oeeik%40group.calendar.google.com/events?orderBy=startTime&singleEvents=true&maxResults=100&q=SPRINT&timeMin=2022-01-24T09%3A42%3A56.897141%2B01%3A00&alt=json
2022-01-24 09:42:56 WARNING (MainThread) [py.warnings] /config/custom_components/samsungtv_tizen/media_player.py:703: RuntimeWarning: coroutine 'SamsungTVDevice._gen_installed_app_list' was never awaited
self._gen_installed_app_list()
2022-01-24 09:42:56 INFO (SyncWorker_5) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2022-01-24 09:42:57 INFO (SyncWorker_5) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/calendar/v3/calendars/ekqk1nbdusr1baon1ic42oeeik%40group.calendar.google.com/events?orderBy=startTime&singleEvents=true&maxResults=100&q=Q%3A&timeMin=2022-01-24T09%3A42%3A57.385218%2B01%3A00&alt=json
2022-01-24 09:42:57 WARNING (HomeControl.websocket_connect) [HomeControl] Please consider updating your websocket-client version. Support for <0.58.0 will be removed soon.
2022-01-24 09:42:57 INFO (HomeControl.websocket_run) [HomeControl] Starting web socket connection.
2022-01-24 09:42:57 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.devolo_home_control
2022-01-24 09:42:57 INFO (MainThread) [homeassistant.components.climate] Setting up climate.devolo_home_control
2022-01-24 09:42:57 INFO (MainThread) [homeassistant.components.cover] Setting up cover.devolo_home_control
2022-01-24 09:42:57 INFO (MainThread) [homeassistant.components.light] Setting up light.devolo_home_control
2022-01-24 09:42:57 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.devolo_home_control
2022-01-24 09:42:57 INFO (MainThread) [homeassistant.components.switch] Setting up switch.devolo_home_control
2022-01-24 09:43:02 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.devolo_home_network
2022-01-24 09:43:02 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 29.59s
2022-01-24 09:43:02 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.setup] Setting up google_assistant
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.setup] Setup of domain google_assistant took 0.0 seconds
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.core] Timer:starting
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
2022-01-24 09:43:03 INFO (MainThread) [custom_components.hacs] Stage changed: HacsStage.STARTUP
2022-01-24 09:43:03 DEBUG (MainThread) [custom_components.hacs] HacsTask<load_hacs_repository> Executing task
2022-01-24 09:43:03 DEBUG (MainThread) [custom_components.hacs] HacsTask<load_hacs_repository> took 0.000 seconds to complete
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.garage_open] Initialized trigger Garage Open
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.garage_closed] Initialized trigger Garage closed
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.bureau_deur_close] Initialized trigger Bureau deur close
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.canon_toner_black_below_25] Initialized trigger Canon toner black below 25%
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.canon_toner_black_cyan_25_duplicate] Initialized trigger Canon toner black cyan 25%
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.canon_toner_black_yellow_25] Initialized trigger Canon toner black yellow 25%
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.canon_toner_black_magenta_25] Initialized trigger Canon toner black magenta 25%
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.verisure_ethernet_down] Initialized trigger Verisure ethernet down
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.tuinhuis_minus_5gr] Initialized trigger Tuinhuis minder dan 5gr zet verwarmig zolder
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.licht_voordeur_aan_sunset] Initialized trigger Licht voordeur aan sunset
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.licht_voordeur_uit_sunset] Initialized trigger Licht voordeur uit sunrise
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.brandalarm] Initialized trigger Brandalarm
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.tuinhuis_meer_dan_5gr_zet_verwarmig_zolder_af] Initialized trigger Tuinhuis MEER dan 5gr zet verwarmig zolder af
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.verisure_alarm] Initialized trigger verisure alarm
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.ramses_ii_pause_10_graden] Initialized trigger Ramses II pause < 5 graden
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.ramses_mowing] Initialized trigger Ramses mowing
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.ramses_mowing_duplicate] Initialized trigger Ramses charging
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.ramses_error] Initialized trigger Ramses error
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.ramses_parked] Initialized trigger Ramses parked
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.bureau_deur_open_brightness] Initialized trigger Bureau deur open (brightness)
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.garage_open_meer_dan_10_min] Initialized trigger Garage Open meer dan 10 min
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.ramses_parked_manually_weather] Initialized trigger Ramses parked manually (weather)
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.valerie_in_zone_work] Initialized trigger Valerie in zone work
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.internet_slow] Initialized trigger Internet slow
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.update_openuv_every_30_minutes_during_the_daytime] Initialized trigger "Update OpenUV every 30 minutes during the daytime"
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.garage_waterpartij_af_sunset] Initialized trigger Garage waterpartij af sunset
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.set_themes_2] Initialized trigger set Themes
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.utility_meter_change_tariff] Initialized trigger utility_meter_change_tariff
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.zwembad_pomp_10uur] Initialized trigger zwembad pomp 10uur
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.zwembad_pomp_20_uur] Initialized trigger zwembad pomp 20 uur
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.zwembad_pomp_08_uur] Initialized trigger zwembad pomp 08 uur
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.ochtend_alarm_af] Initialized trigger ochtend alarm af
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.warmwater_fout] Initialized trigger warmwater fout
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.zwembad_pomp_23_59_uur_trigger] Initialized trigger zwembad pomp 23.59 uur trigger
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.zwembad_pomp_1_uur_warmtepomp_af_manueel_naar_normaal] Initialized trigger zwembad pomp 1 uur warmtepomp af
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.zwembad_warmtepomp_10uur_op] Initialized trigger zwembad warmtepomp 10uur op
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.ifttt_webhook_handler] Initialized trigger IFTTT webhook handler
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.extra_power_even_uren_op_350] Initialized trigger extra power even uren op 200 en 125 op oneven
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.devolo_bridge_offline] Initialized trigger devolo bridge offline
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.hue_bridge_offline] Initialized trigger hue bridge offline
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.wasmachine_is_klaar] Initialized trigger Wasmachine is klaar
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.diepvries_af] Initialized trigger diepvries garage af!!!
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.koelkast_berging_af] Initialized trigger koelkast berging af!!!
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.to_grid_v2] Initialized trigger to-grid v2
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.from_grid_1_v2] Initialized trigger from-grid-1 v2
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.perform_auto_backup] Initialized trigger Auto Backup db (12hrs)
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.perform_daily_backup_2] Initialized trigger Automated Daily Backup
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.automated_weekly_backup] Initialized trigger Automated Weekly Backup
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.automated_notify_backup_failure] Initialized trigger automated Notify Backup Failure
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.temp_slaapkamer] Initialized trigger temp slaapkamer OP
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.temp_slaapkamer_af] Initialized trigger temp slaapkamer af
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.sunrise_theme] Initialized trigger sunrise theme
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.sunset_theme] Initialized trigger sunset theme
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.staanlamp_aan_sunset] Initialized trigger staanlamp aan sunset
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.licht_slaapkamer_aan_als_alarm_away_en_motion_trap] Initialized trigger licht slaapkamer aan als alarm away en motion trap
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.dressing_deur_open] Initialized trigger Dressing deur open
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.dressing_deur_close] Initialized trigger Dressing deur close
2022-01-24 09:43:03 INFO (MainThread) [homeassistant.components.automation.utility_meter_change_tariff_duplicate] Initialized trigger utility_meter_change_tariff -2
2022-01-24 09:43:03 INFO (MainThread) [custom_components.hacs] Loading known repositories
2022-01-24 09:43:03 INFO (SyncWorker_11) [homeassistant.loader] Loaded homekit_controller from homeassistant.components.homekit_controller
2022-01-24 09:43:03 WARNING (Recorder) [homeassistant.components.sensor.recorder] sensor.energy_meter_netto has unit W which is unsupported for device_class energy
2022-01-24 09:43:03 DEBUG (MainThread) [custom_components.hacs] HacsTask<prosess_queue> Executing task
2022-01-24 09:43:03 INFO (SyncWorker_3) [homeassistant.loader] Loaded spotify from homeassistant.components.spotify
2022-01-24 09:43:03 WARNING (Recorder) [homeassistant.components.sensor.recorder] The unit of sensor.load_5m (None) does not match the unit of already compiled statistics ( ). Generation of long term statistics will be suppressed unless the unit changes back to
2022-01-24 09:43:03 INFO (SyncWorker_4) [homeassistant.loader] Loaded homekit from homeassistant.components.homekit
2022-01-24 09:43:03 WARNING (MainThread) [homeassistant.helpers.config_entry_flow] ("The Sonos Alarm (sonos_alarm) integration is setting a connection_class when calling the 'register_discovery_flow()' method in its config flow. The connection class has been deprecated and will be removed in a future release of Home Assistant. If 'sonos_alarm' is a custom integration, please contact the author of that integration about this warning.",)
2022-01-24 09:43:03 DEBUG (MainThread) [aiogithubapi] 'GitHubRateLimitResourcesModel' is missing key 'actions_runner_registration' for <class 'dict'>
2022-01-24 09:43:03 DEBUG (MainThread) [aiogithubapi] 'GitHubRateLimitResourcesModel' is missing key 'scim' for <class 'dict'>
2022-01-24 09:43:03 DEBUG (MainThread) [custom_components.hacs] HacsTask<prosess_queue> Can update 225 repositories, items in queue 6
2022-01-24 09:43:03 DEBUG (MainThread) [custom_components.hacs] Checking out tasks to execute
2022-01-24 09:43:03 DEBUG (MainThread) [custom_components.hacs] Starting queue execution for 6 tasks
2022-01-24 09:43:03 WARNING (Recorder) [homeassistant.components.sensor.recorder] The normalized unit of sensor.daily_solar_offpeak (kWh) does not match the unit of already compiled statistics (None). Generation of long term statistics will be suppressed unless the unit changes back to None
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] Queue execution finished for 6 tasks finished in 0.38 seconds
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] HacsTask<prosess_queue> took 0.552 seconds to complete
2022-01-24 09:43:04 WARNING (MainThread) [custom_components.hacs] You have 'sdebruyn/homeassistant-bpost-integration' installed with HACS this repository has been removed from HACS, please consider removing it. Removal reason (Blocked by provider)
2022-01-24 09:43:04 INFO (MainThread) [custom_components.hacs] Stage changed: HacsStage.RUNNING
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] Starting recurring background task for installed repositories
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Integration hacs/integration> Getting repository information
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin AmoebeLabs/flex-horseshoe-card> Getting repository information
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/bar-card> Getting repository information
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/button-card> Getting repository information
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/entity-attributes-card> Getting repository information
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/decluttering-card> Getting repository information
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/flex-table-card> Getting repository information
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin dnguyen800/air-visual-card> Getting repository information
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin fineemb/lovelace-thermostat-card> Getting repository information
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin iantrich/text-divider-row> Getting repository information
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] Checking out tasks to execute
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] Starting queue execution for 53 tasks
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/entity-attributes-card> Running checks against 0.1.2
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin AmoebeLabs/flex-horseshoe-card> Running checks against 0.9.0
2022-01-24 09:43:04 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/decluttering-card> Running checks against 0.6.3
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/bar-card> Running checks against 3.2.0
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Integration hacs/integration> Running checks against 1.19.3
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/flex-table-card> Running checks against master
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Plugin fineemb/lovelace-thermostat-card> Running checks against v1.3.0
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Plugin iantrich/text-divider-row> Running checks against 1.4.1
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Plugin dnguyen800/air-visual-card> Running checks against 2.0.1
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/button-card> Running checks against v3.4.2
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Plugin kalkih/mini-media-player> Getting repository information
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Integration jcwillox/hass-auto-backup> Getting repository information
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Integration thomasloven/hass-browser_mod> Getting repository information
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Integration ualex73/monitor_docker> Getting repository information
2022-01-24 09:43:05 DEBUG (MainThread) [custom_components.hacs] <Integration zachowj/hass-node-red> Getting repository information
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Theme basnijholt/lovelace-ios-themes> Getting repository information
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Plugin kalkih/mini-media-player> Running checks against v1.15.0
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Theme orickcorreia/caule-themes-pack-1> Getting repository information
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Integration AaronDavidSchneider/SonosAlarm> Getting repository information
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Integration Thomas55555/husqvarna_automower> Getting repository information
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Integration jaruba/ha-samsungtv-tizen> Getting repository information
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Integration thomasloven/hass-browser_mod> Running checks against 1.5.1
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Integration jcwillox/hass-auto-backup> Running checks against 0.10.1
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Integration ualex73/monitor_docker> Running checks against 1.14
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Theme basnijholt/lovelace-ios-themes> Running checks against v2.5.0
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Integration zachowj/hass-node-red> Running checks against v1.0.6
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Theme orickcorreia/caule-themes-pack-1> Running checks against v.1.3
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Integration And3rsL/Deebot-for-Home-Assistant> Getting repository information
2022-01-24 09:43:06 DEBUG (MainThread) [custom_components.hacs] <Integration AaronDavidSchneider/SonosAlarm> Running checks against 1.3.1
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Integration jaruba/ha-samsungtv-tizen> Running checks against v1.5.9
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Integration Thomas55555/husqvarna_automower> Running checks against 2021.12.0
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Integration bramstroker/homeassistant-powercalc> Getting repository information
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Integration And3rsL/Deebot-for-Home-Assistant> Running checks against 3.2.1
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Python_Script point-4ward/ps-date-countdown> Getting repository information
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Plugin kalkih/mini-graph-card> Getting repository information
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Integration pippyn/Home-Assistant-Sensor-Afvalbeheer> Getting repository information
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Plugin nervetattoo/simple-thermostat> Getting repository information
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Python_Script point-4ward/ps-date-countdown> Running checks against v6.0
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Plugin RomRider/apexcharts-card> Getting repository information
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Integration sdebruyn/homeassistant-bpost-integration> Getting repository information
2022-01-24 09:43:07 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-template-entity-row> Getting repository information
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Plugin mattieha/slider-button-card> Getting repository information
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Integration bramstroker/homeassistant-powercalc> Running checks against v0.16.0
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Plugin kalkih/mini-graph-card> Running checks against v0.11.0
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Integration pippyn/Home-Assistant-Sensor-Afvalbeheer> Running checks against v4.9.2
2022-01-24 09:43:08 ERROR (MainThread) [custom_components.hacs] <Integration sdebruyn/homeassistant-bpost-integration> GitHub returned 404 for https://api.github.com/repos/sdebruyn/homeassistant-bpost-integration
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-slider-entity-row> Getting repository information
2022-01-24 09:43:08 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/config/custom_components/hacs/repositories/base.py", line 889, in async_get_legacy_repository_object
repository = await github.get_repo(self.data.full_name, etag)
File "/usr/local/lib/python3.9/site-packages/aiogithubapi/legacy/github.py", line 72, in get_repo
response = await self.client.get(endpoint=_endpoint, headers=_headers)
File "/usr/local/lib/python3.9/site-packages/aiogithubapi/legacy/client.py", line 60, in get
response = await async_call_api(
File "/usr/local/lib/python3.9/site-packages/aiogithubapi/helpers.py", line 37, in async_call_api
return await legacy_async_call_api(
File "/usr/local/lib/python3.9/site-packages/backoff/_async.py", line 133, in retry
ret = await target(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/aiogithubapi/legacy/helpers.py", line 81, in async_call_api
raise AIOGitHubAPIException(
aiogithubapi.common.exceptions.AIOGitHubAPIException: GitHub returned 404 for https://api.github.com/repos/sdebruyn/homeassistant-bpost-integration
File "/config/custom_components/hacs/repositories/base.py", line 919, in common_update_data
repository_object, etag = await self.async_get_legacy_repository_object(
File "/config/custom_components/hacs/repositories/base.py", line 894, in async_get_legacy_repository_object
raise HacsException(exception) from exception
custom_components.hacs.exceptions.HacsException: GitHub returned 404 for https://api.github.com/repos/sdebruyn/homeassistant-bpost-integration
File "/config/custom_components/hacs/base.py", line 580, in startup_tasks
await self.recurring_tasks_installed()
File "/config/custom_components/hacs/base.py", line 678, in recurring_tasks_installed
await self.handle_critical_repositories()
File "/config/custom_components/hacs/base.py", line 656, in handle_critical_repositories
await critical_queue.execute()
File "/config/custom_components/hacs/utils/queue_manager.py", line 69, in execute
await asyncio.gather(*local_queue)
File "/config/custom_components/hacs/utils/decorator.py", line 28, in wrapper
await function(*args, **kwargs)
File "/config/custom_components/hacs/repositories/integration.py", line 104, in update_repository
if not await self.common_update(ignore_issues, force) and not force:
File "/config/custom_components/hacs/repositories/base.py", line 516, in common_update
await self.common_update_data(ignore_issues=ignore_issues, force=force)
File "/config/custom_components/hacs/repositories/base.py", line 939, in common_update_data
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Plugin nervetattoo/simple-thermostat> Running checks against v2.4.3
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] 'states' is undefined
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Plugin dylandoamaral/uptime-card> Getting repository information
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Plugin mattieha/slider-button-card> Running checks against v1.10.3
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Plugin RomRider/apexcharts-card> Running checks against v1.10.0
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-slider-entity-row> Running checks against 17.2.1
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Plugin bokub/rgb-light-card> Getting repository information
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/canvas-gauge-card> Getting repository information
2022-01-24 09:43:08 DEBUG (MainThread) [custom_components.hacs] <Plugin dylandoamaral/uptime-card> Running checks against v0.9.3
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] 'states' is undefined
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Integration aex351/home-assistant-neerslag-app> Getting repository information
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Integration amaximus/anniversary> Getting repository information
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Integration hif2k1/battery_sim> Getting repository information
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Plugin bokub/rgb-light-card> Running checks against 1.10.0
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Plugin custom-cards/canvas-gauge-card> Running checks against 0.4.1
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-template-entity-row> Running checks against 1.3.0
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Integration delzear/hass-formulaoneapi> Getting repository information
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-layout-card> Getting repository information
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Integration aex351/home-assistant-neerslag-app> Running checks against main
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Integration ahoernecke/ha_cellar_tracker> Getting repository information
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Integration amaximus/anniversary> Running checks against 0.2.1
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Integration hif2k1/battery_sim> Running checks against master
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Plugin fufar/simple-clock-card> Getting repository information
2022-01-24 09:43:09 DEBUG (MainThread) [custom_components.hacs] <Integration ahoernecke/ha_cellar_tracker> Running checks against master
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] <Integration delzear/hass-formulaoneapi> Running checks against v0.1.1
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-auto-entities> Getting repository information
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-layout-card> Running checks against 2.3.1
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] <Plugin denysdovhan/vacuum-card> Getting repository information
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-card-mod> Getting repository information
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] 'states' is undefined
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] <Plugin ljmerza/fitbit-card> Getting repository information
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] <Plugin SNoof85/lovelace-tempometer-gauge-card> Getting repository information
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] <Plugin benct/lovelace-battery-entity-row> Getting repository information
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-auto-entities> Running checks against 1.9.1
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] <Plugin maxwroc/battery-state-card> Getting repository information
2022-01-24 09:43:10 WARNING (MainThread) [py.warnings] /config/custom_components/samsungtv_tizen/media_player.py:703: RuntimeWarning: coroutine 'SamsungTVDevice._gen_installed_app_list' was never awaited
2022-01-24 09:43:10 DEBUG (MainThread) [custom_components.hacs] <Plugin denysdovhan/vacuum-card> Running checks against v2.2.5
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-card-mod> Running checks against 3.1.1
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin ljmerza/fitbit-card> Running checks against 1.1.1
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-badge-card> Getting repository information
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin SNoof85/lovelace-tempometer-gauge-card> Running checks against 1.40
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin arallsopp/hass-hue-icons> Getting repository information
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin benct/lovelace-battery-entity-row> Running checks against v1.3.1
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin fufar/simple-clock-card> Running checks against 1.5
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin maxwroc/battery-state-card> Running checks against v2.1.1
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-badge-card> Running checks against master
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin totaldebug/atomic-calendar-revive> Getting repository information
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] 'states' is undefined
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin queimadus/last-changed-element> Getting repository information
2022-01-24 09:43:11 DEBUG (MainThread) [custom_components.hacs] <Plugin arallsopp/hass-hue-icons> Running checks against v.1.2.5
2022-01-24 09:43:12 DEBUG (MainThread) [custom_components.hacs] <Plugin pmongloid/flipdown-timer-card> Getting repository information
2022-01-24 09:43:12 DEBUG (MainThread) [custom_components.hacs] <Plugin totaldebug/atomic-calendar-revive> Running checks against v6.2.0
2022-01-24 09:43:12 DEBUG (MainThread) [custom_components.hacs] <Plugin queimadus/last-changed-element> Running checks against main
2022-01-24 09:43:12 DEBUG (MainThread) [custom_components.hacs] <Plugin pmongloid/flipdown-timer-card> Running checks against v0.2
2022-01-24 09:43:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.telenet_dns is taking over 10 seconds
2022-01-24 09:43:31 WARNING (MainThread) [homeassistant.helpers.entity] Entity media_player.browser_07234acf_73fd3f57 (<class 'custom_components.browser_mod.media_player.BrowserModPlayer'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:43:31 WARNING (MainThread) [homeassistant.helpers.entity] Entity light.browser_07234acf_73fd3f57 (<class 'custom_components.browser_mod.light.BrowserModLight'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:43:31 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.browser_07234acf_73fd3f57 (<class 'custom_components.browser_mod.sensor.BrowserModSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-01-24 09:43:34 INFO (MainThread) [hass_nabucasa.google_report_state] Connected
2022-01-24 09:45:10 INFO (Recorder) [homeassistant.components.sensor.recorder] Detected new cycle for sensor.daily_from_grid_peak_cost, last_reset set to 2022-01-24T08:40:05.133643+00:00 (old last_reset 2022-01-23T18:19:58.327681+00:00)
2022-01-24 09:45:10 INFO (Recorder) [homeassistant.components.sensor.recorder] Detected new cycle for sensor.daily_from_grid_peak_cost, last_reset set to 2022-01-24T08:42:51.533004+00:00 (old last_reset 2022-01-24T08:40:05.133643+00:00)
2022-01-24 09:45:10 INFO (Recorder) [homeassistant.components.sensor.recorder] Detected new cycle for sensor.daily_from_grid_offpeak_cost, last_reset set to 2022-01-24T08:40:05.133748+00:00 (old last_reset 2022-01-23T23:00:00.041645+00:00)
2022-01-24 09:45:10 INFO (Recorder) [homeassistant.components.sensor.recorder] Detected new cycle for sensor.daily_from_grid_offpeak_cost, last_reset set to 2022-01-24T08:42:51.533114+00:00 (old last_reset 2022-01-24T08:40:05.133748+00:00)
2022-01-24 09:45:10 INFO (Recorder) [homeassistant.components.sensor.recorder] Detected new cycle for sensor.daily_grid_peak_compensation, last_reset set to 2022-01-24T08:40:05.133941+00:00 (old last_reset 2022-01-23T18:19:58.328026+00:00)
2022-01-24 09:45:10 INFO (Recorder) [homeassistant.components.sensor.recorder] Detected new cycle for sensor.daily_grid_peak_compensation, last_reset set to 2022-01-24T08:42:51.533299+00:00 (old last_reset 2022-01-24T08:40:05.133941+00:00)
2022-01-24 09:45:10 INFO (Recorder) [homeassistant.components.sensor.recorder] Detected new cycle for sensor.daily_grid_offpeak_compensation, last_reset set to 2022-01-24T08:40:05.134014+00:00 (old last_reset 2022-01-23T18:19:58.328112+00:00)
2022-01-24 09:45:10 INFO (Recorder) [homeassistant.components.sensor.recorder] Detected new cycle for sensor.daily_grid_offpeak_compensation, last_reset set to 2022-01-24T08:42:51.533370+00:00 (old last_reset 2022-01-24T08:40:05.134014+00:00)
2022-01-24 09:45:10 INFO (Recorder) [homeassistant.components.sensor.recorder] Detected new cycle for sensor.monthly_gas_cost, last_reset set to 2022-01-24T08:40:05.143339+00:00 (old last_reset 2022-01-23T18:19:58.336864+00:00)
2022-01-24 09:45:10 INFO (Recorder) [homeassistant.components.sensor.recorder] Detected new cycle for sensor.monthly_gas_cost, last_reset set to 2022-01-24T08:42:51.541092+00:00 (old last_reset 2022-01-24T08:40:05.143339+00:00)
2022-01-24 09:45:52 INFO (MainThread) [custom_components.neerslag.sensor] getBuienradarData - timeout
2022-01-24 09:46:36 DEBUG (MainThread) [custom_components.hacs] Running uninstall for sdebruyn/homeassistant-bpost-integration
2022-01-24 09:46:36 DEBUG (MainThread) [custom_components.hacs] <Integration sdebruyn/homeassistant-bpost-integration> Getting repository information
2022-01-24 09:46:37 ERROR (MainThread) [custom_components.hacs] <Integration sdebruyn/homeassistant-bpost-integration> GitHub returned 404 for https://api.github.com/repos/sdebruyn/homeassistant-bpost-integration
2022-01-24 09:46:37 ERROR (MainThread) [custom_components.hacs] Could not use repository with ID 433968883 ('NoneType' object has no attribute 'get_releases')
2022-01-24 09:46:47 DEBUG (MainThread) [custom_components.hacs] Running uninstall for sdebruyn/homeassistant-bpost-integration
2022-01-24 09:46:47 DEBUG (MainThread) [custom_components.hacs] <Integration sdebruyn/homeassistant-bpost-integration> Getting repository information
2022-01-24 09:46:47 ERROR (MainThread) [custom_components.hacs] <Integration sdebruyn/homeassistant-bpost-integration> GitHub returned 404 for https://api.github.com/repos/sdebruyn/homeassistant-bpost-integration
2022-01-24 09:46:47 ERROR (MainThread) [custom_components.hacs] Could not use repository with ID 433968883 ('NoneType' object has no attribute 'get_releases')
From <http://192.168.0.90:8123/config/logs>
