How to reset z-wave completely
I run a hass.io instance 0.58.1 and just got z-wave added with 1 node. During testing and setup I managed to screw something up and now I want to do a “reset”. That means, deleting every setting/entity and start all over again.
How to do that? Or what is the best way to start all over?
A “reset” would be done by:
  • Use Remove Node on all your devices
  • Shut down Home Assistant
  • Delete zwcfg*.xml
  • Follow the instructions for your Z-Wave stick to factory reset it
This worked for me. Didn’t get to reset my Aeotec Z-stick, my single node was still connected. But it started me all over in HA.
Thanks for the help :slight_smile:
Note: If you’re trying to reset the Aeostick Z-Stick Gen 5, you must unplug it while resetting it! I didn’t realize this and it wouldn’t reset correctly.
Unplug the Z-Stick, press a paperclip into the reset button, hold for 20 seconds until the light flashes solid, and it’s reset.
I tried this, but the Remove node seems to not work - nothing happens.
2019-05-15 10:55:51.075 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2019-05-15 10:55:51.075 Warning, WARNING: REMOVE_NODE_STATUS_FAILED
2019-05-15 10:55:51.075 Detail, Node007,   Expected callbackId was received
2019-05-15 10:55:51.075 Detail, Node007,   Expected reply was received
2019-05-15 10:55:51.075 Detail, Node007,   Message transaction complete
2019-05-15 10:55:51.076 Detail,
2019-05-15 10:55:51.076 Detail, contrlr, Removing current message
2019-05-15 10:55:51.076 Detail, Notification: ControllerCommand - Failed
