I cannot seem to get the yaml correct to make a picture-glance card with the picture right-side up!
cards:
- entities:
- entity: switch.06200046bcddc2e96358
title: Living Room
type: picture-glance
image: /local/Livingroom.jpeg
style:
transform: rotate(180deg)
It might not be possible. Is there a better way to achieve this type of look?
Leave a blank line between your code and the text above before highlighting and pressing the code format button.
Alternatively surround your code with three tic marks ( the key between tab and escape) in lines above and below your code. This method has the advantage of syntax highlighting.
move to Australia? I don’t think you can the way you have it configured. If you had it configured as a camera, I think you could get this working. It appears you have it creating an image in a directory then posting that image. Is there a way to rotate the image from the camera side?
So this is your version of being helpful? If you see the answer provided by tom_I AND read the instruction at the top you will see that the key spacing is not communicated. If ever there was a barrier to general uptake of HA, it is communication and clarity, and perhaps some kindness.
I am still getting an upside down image on Chrome but rightside up on iOS app. I used the 3x tic marks - thanks tom_I
So the problem remains that the image is upside down in Chrome, however, it is right-side up in the iOS app. Thus rotating at source wouldn’t solve anything. Does anyone understand the origin of this problem?
That sounds very much like some form of exif data on the picture which one of the browsers ignore, and the other doesn’t.
I think there are services online where you can upload your picture and have all exif data stripped. After that it should be consistent between browsers, and then you can look at making it right side up.
removing the exif at https://www.verexif.com/en/ did indeed make them render the same on both devices, just upside down. The web was on chrome and presumably the iOS is using a safari platform. However, if I open the image directly in Chrome, it is right side up (even with EXIF stripped). It isn’t clear why HASS on Chrome is behaving differently than chrome by itself.
I opened the file in gimp and exported to .png and used advanced options to not save exif and xmp data. worked like a charm.
Thanks thomasloven and tom_I for teaching me something new that I didn’t know.
I assume you mean without removing the exif. Because either the iOS or the desktop Chrome version would always be upside down. Once exif was removed, image was consistent between two platforms and could be rotated if needed.
