How to schedule a reload of some integration?
Some integrations (Tuya and Govee for me) stop working and need to be reloaded.
In my case it happens every time I reboot (for whatever reason) my router.
I haven’t found a way to schedule this.
Is there a way to schedule the reload of an integration to run every x hours/minutes/days?
Thank you
Air
Yes, you can select Time and Location -> Time Pattern as Trigger in an Automation and then Call Service in the Action and select:
Home Assistant Core Integration: Reload config entry
And select the Integration to reload.
I do something like that, however I just check if a state is Unknown or Unavailable instead of using a Time Pattern.
I too have reloaded misbehaving integrations when they are unavailable but this is just a temporary solution. The root cause of the problem should be found and addressed.
Debugging misbehaving integrations should be done by following this guide:
Let me know if you need help implementing it.
Yes it is a solution.
I set up this automation:
alias: Reload Tuya + Govee Integrations
description: ""
  - platform: time
    at: "07:00:00"
condition: []
  - service: homeassistant.reload_config_entry
      entry_id: 85a2f0874a1fd8d1a14345d054aa7a58
    metadata: {}
      entry_id: 6e40279b48e76b80b17f473147c9ecb7
mode: single
But it has been executed Just one time.
Not every day.
I don’t understand why…
description: ""
  - platform: time
    at: "07:00:00"
condition: []
    metadata: {}
mode: single
When I try to modify it to be triggered by the Integration state, I don’t find the what to check: Entity or Device (Integration state is not present)?
Please check out this guide. Posting your code properly helps folks expedite a resolution.
I check the state of one of the entities the integration provides. It becoming unavailable usually means the integration needs reloading.
Check the automation’s trace.
The automation doesn’t start, so no trace is present.
When i start it manually, all tasks are completed correctly
Your automation is using a Time Trigger set for 07:00. It’s one of the simplest and most reliable triggers because all it needs to do is wait for the system clock to
advance to the specified time. There’s something fundamentally wrong if a simple Time Trigger fails to work on your system.
Enter the following template in the Template Editor and confirm it reports the correct date, time, and timezone offset for your location.
{{ now() }}
When you run it manually, it doesn’t exercise the automation’s trigger and simply executes its actions.
@123
I’m new to HA.
Could you please explain me how to do that, step by step?
Thing I think is better to know:
  1. Home Assistant is powered off and restarted every day at1 am
  2. If I change the time for automation to be triggered after a few minutes l, it works.
    But it isn’t triggered no more.
    It seems the automation is triggered only one time.
  3. I have set up also another automation triggered by sunset.
    It works some days and other no.
Thank you
If a Time Trigger only triggers once but never again and a Sun Trigger works only sometimes but not every day, then there’s a fundamental problem with your system.
I don’t know what that problem might be but it makes discussing automations pointless until the problem is resolved.
What version of Home Assistant do you have and which installation method did you use?
  1. Home Assistant OS
  2. Home Assistant Container
  3. Home Assistant Supervised
  4. Home Assistant Core
Installation Methods
Most importantly, check the Logs for any warning or error messages.
That was very helpful!! Thank you!!
I just had to figure out where to find the Entry_ID for my integration. So let me share that for others:
It can be found in the “core.config_entries” file in the “/config/.storage/” folder. I used VSCode to access it.
Did some widely used integrations just now become much more reliable? Seems like there has been at least half a dozen new or revived threads on the exact same thing during the last day or two…
You can use the config_entry_id function/filter in a template. Would be super simple to use in an automation that triggers off a list of known unreliable sensors going unavailable for X amount of time.
