Does anyone know how to set the cover position within a scene? Since the state is a required parameter, all I’m able to do is full open or closed, but I’d like to set a percentage opened or closed instead.
My memory is a little rusty. I know you could do this in the past, but I recall the developers made changes that removed this capability. Myself and others have converted over to using scripts instead of scenes. You can set the position using a script.
Thanks, @wmaker. Is this something you can provide an example of?
I don’t have a specific example of using a script to open the covers to a set position, but here is an example of a script that opens my back blinds and shades.
If you want, you could add other things like lights, etc. to the script.
configuration.yaml
script: !include scripts.yaml
scripts.yaml
scripts:
open_back_blinds:
alias: Open Back Blinds
sequence:
- service: cover.open_cover_tilt
entity_id: >
cover.nook_blinds, cover.deck_blinds,
cover.fireplace_blinds
entity_id: >
cover.kitchen_sink_shade,
cover.nook_sky_shades
In your case, where you want to set the position of your covers, instead of using the service cover.open_cover
you would use the service cover.set_cover_position
If you go to the developers tool, you can actually set this up and see what the yaml looks like.
It should look something like:
service: cover.set_cover_position
entity_id: cover.my_cover
position: 33
