Then there is the service “Input Datetime: Set” which you can use in an automation, you ‘just’ need to find out how to format the date as per the blueprint
I’m using this to sync iOS alarms to HA, then I run an automation for the alarm
In the discussion it says
It works with a one time modified scheduled alarm as well, but NOT with non-repeating alarms. They lack a date and can’t be used. A possible workaround could be to use names when setting those kind of alarms and filter those within the shortcuts-automation.
So i suppose date is also required. Not sure why but I don’t want to spend too much time on it.
Apart from the iOS shortcut, I have tried to run the blueprint with an input time only and it did not seem to work, no idea why.
I suppose if I ever decide to disable this iOS shortcut, I could just use the time input. I still have to decide if it’s more convenient to set the alarm via iOS or HA
