How to set DNS after first install
If you find that Home Assistant can not obtain an IPv4 address after you first install it you likely need to set your DNS server.
Note: if you have access to your Home Assistant frontend website then you should set your DNS server here: Settings → System → Network → IPv4 for your adaptor → DNS Server.
If you do not have access to your HA website then connect a monitor and keyboard to your server and type the following:
login Enter
nmcli con Enter
You will get a reply containing something like: Supervisor enp1s0, yours will likely be slightly different. Then type the following:
nmcli con edit "Supervisor enp1s0"Enter making sure to use the reply you actually got from the last step.
Then if the following command:
print ivp4 Enter returns no DNS server IP addresses you need to do the following:
remove ipv4.dns Enter
set ipv4.dns 9.9.9.9 Enter You can also use 1.1.1.1 or 8.8.8.8 or your preferred DNS server if you know it.
print ipv4 Enter should now show a DNS server set to 9.9.9.9
All you need to do now is:
save Enter
exit Enter
host restart Enter
More helpful topics: The Home Assistant Cookbook - Index
My DNS was set the same as my gateway. Thank you for sending these instructions Tom, as I now set my dns to 9.9.9.9. I am sure all of my remote access troubles are behind me. I am surprised I did not have more remote problems than I did.
This worked for me after I had issues installing. But just a couple notes in case it helps anyone else:
ivp4should be ipv4.
exit was not a valid command, so I used quit.
host restart was not a valid command, so I used reboot.
Thanks, fixed.
Then you may not have been logged in correctly. And since you did not exit to the HA CLI that is why the following did not work:
I just confirmed the original instruction do work.
After adding the DNS servers as described above and changing to static, HA loaded quicker. However Broadlink integration did not find the device (could be pinged though) Bose soundbar integration timed out with the correct IP address which can also be pinged. Both apps work as before.
Any other setting in the network that prevents reconnecting?
If you changed the IP address when setting it to static, the integrations won’t be aware of the change.
Unfortunately most integrations don’t allow you to reconfigure the IP, so you’ll probably have to remove & re-add the integration from scratch.
