Integration of Fibaro Devices connected to HC2 into HA works very good. One reason why I moved from OH2 to HA. Now I want to display the battery level of all wireless Fibaro devices as I am doing this for the Homematic window sensors. For them exist separate entities I can display. But what have I got to do, to show battery level of my Fibaro smoke, water and motion detectors?
Thanks!
Do you got the battery level as a attributes in your states? You could do some templating to show them as a sensor in your HA
What I see in settings e.g. for the motion detector:
battery_level: 51
device_armed: true
fibaro_id: 42
friendly_name: Flur 41.0
icon: mdi:run
device_class: motion
What do you mean with ātemplatingā?
My code for the battery level subtracted from the attribute is as followed.
sensors:
battery_level_door_sensor_525:
friendly_name: 'Batterij Level Sensor Deur Voor'
value_template: '{{ states.binary_sensor.door_window_sensor_158d0003456525.attributes.battery_level }}'
unit_of_measurement: '%'
You could do the same just simply use your entity id which could be
sensors:
battery_level_door_sensor_525: #just an entity id you can define for your battery
value_template: '{{ states.<your entity ID>.attributes.battery_level }}'
I donāt know if this makes any sense to you but you could get it working like this
So it could look like this:
sensors:
battery_arbeitszimmer_60_0_1_63:
friendly_name: 'Batterie Rauchmelder Arbeitszimmer'
value_template: '{{ states.binary_sensor.arbeitszimmer_60_0_1_63.attributes.battery_level }}'
unit_of_measurement: '%'``
But where have I got to put this? In the configurations.yaml or in the Template editor?
Yes that should work. You need to put this in your configuration.yaml under āsensorsā. Check your config and then restart HA. You can then put it in your Lovelace as a normal entity id.
be careful with your quotation marks in your code
Wrong
Correct
Excelent! It is working and I am adding now all the missing entities (Power Consumption of all of my Wall-Plugs, battery level of the smoke and flood sensors,ā¦)
Thanks!
So Iām a bit confused. If Fibaro devices are z-wave, then why canāt a use them in HA without HC2?
Specifically, Iām liking the Fibrao water sensor. Wonāt it work with just HA?
Thanks,
Ambi
Hi, yes, Fibaro devices do work just alone with HA, if you use a Z-Wave stick (which I have)
But all my z-wave devices are connected to the HC2 so I have integrated this into HA as I have done this with my Homematic devices as well.
I have set up some rules in the HC2 that are working fine. So far no need to disonnect all the devices (10 smoke sensors, 3 water sensors 10 wall plugs, 1 motion eye) and reconnect/set them up and build all the rules and logic.
Thatās good, thanks! I can get a water sensor and let the group know how it works with HA directly.
Cheers,
Ambi
I ended up using a Fibaro implant and made a custom case out of an IP6 enclosure, got a old power supply and ordered a handful of temp sensors.
It works like a champ!
![image](https://community-assets.home-assistant.io/original/3X/6/6/665d67bfa8344f72c657a939c9beb1c6216729bc.png)
![image](https://community-assets.home-assistant.io/original/3X/c/e/ceb5f10c29b7811fca8a3d58fe34920417631189.png)
The only issue is the device is discovered by Z-Wave as āFIBARO System Unknown: type=0502, id=2000ā. This is because the default ZWave build (Iām using Nortek HUSBZB-1, BTW) doesnāt have new entity names that are in OpenZwave.
But it does what I need. The Implant also has sensors for voltage and temp within the card itself, and can use a number of sensors so if you wanted outside temp and pond temp for example, youād just need a second temp sensor.
There are 6 DS18B20 temp sensors, 2- and 3-wire analog sensors, and binary sensors. So I use this as temp sensor but you could get water level by strategic placement of binary sensors and a float or just low resistance of a binary sensor line.
In fact, I use it for low water indication because my pond and outside air are always different. But when the temps are the same for pond and outsideā¦especially when theyāre below freezing, I infer the water level is low! And of course send an alert notification to HA.
Oddly, the internal temp seems to be 14 or so degrees F higher than the real ambient temp!
Regards,
Ambidexter
