one7one
November 3, 2022, 11:38am
1
Hi all,
I would like to use ESPHome to generate sensors in HA from UART reading.
There is an “arduino nano”, it sends data from different sensors via uart to esp-01s
433-esp01-uart.yaml
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
level: VERBOSE
baud_rate: 0
# Enable Home Assistant API
api:
password: "******"
ota:
password: "*******"
wifi:
ssid: "******"
password: "*****"
ap:
ssid: "433-Esp01-Uart Fallback Hotspot"
password: "********"
uart:
- id: uart_bus1
tx_pin: 0
rx_pin: 2
baud_rate: 115200
debug:
direction: BOTH
dummy_receiver: true
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
captive_portal:
Getting data:
Logs 433-esp01-uart.yaml
[18:22:25][D][uart_debug:158]: <<< "4:22.07:17\r\n"
[18:22:34][D][uart_debug:158]: <<< "1:18.63:31\r\n"
[18:23:10][D][uart_debug:158]: <<< "2:15.79:19\r\n"
[18:23:26][D][uart_debug:158]: <<< "4:22.07:18\r\n"
[18:23:27][D][uart_debug:158]: <<< "1:18.63:31\r\n"
[18:24:07][D][uart_debug:158]: <<< "2:15.79:19\r\n"
[18:24:12][D][uart_debug:158]: <<< "3:37.86:10\r\n"
there are 4 sensors
where<<< id:temperature:humidity
How to split data in HA
zoogara
(Daryl)
November 3, 2022, 12:40pm
2
You need a custom UART devices, which involves writing a short piece of C++ code.
There is an example in the docs, and if you search the forum for “custom UART” you will find plenty of posts.
https://esphome.io/custom/uart.html
i see you maybe need the same as i do
maybe you also get some infos from my topic.
Hi all,
i would like to use an ESPHome to create Sensors in HA from an UART Reading.
My oven send every second a long String through an UART interface. The String looks like this:
State= 30. 31, Temp= 29.3, SOLL-Pos= 5, IST-Pos= 76, MotorMAX=1520, Zeit=45143, TempAV= 29, MAX_Temp=749, TempGradient= 0, Tuer=1, ECO= 0, LEDRot=1, LEDGruen=0, ST= 0, Magnet=0, Relais=1, Control=0, PRIME= 1, BetriebsStdn= 1391
Is there a possibility to extract the values out of the string (RegExp?) and creat…
mulcmu
November 4, 2022, 1:49am
4
The UART Bus component provides a write action but no read actions. Typically the UART read is implemented in a custom component that also does the processing. The UART debug sequence can be exploited to act like a call back function whenever there is received data to process. So basically instead of creating a small custom component a large lambda call can be used in the UART debug yaml. Here was an example that implements processing in the UART debug for the text formatting you provided. I tested it on an esp32 devboard with a jumper to loop back the UART tx pin output back into the rx pin. The buttons entities in HA can be used to test the logic.
esphome:
esp32:
board: esp32dev
framework:
type: arduino
api:
logger:
baud_rate: 115200
ota:
password: !secret esp_home_ota_pw
wifi:
ssid: !secret wifi_ssid
uart:
baud_rate: 115200
tx_pin: 17
rx_pin: 16
debug:
direction: BOTH
after:
delimiter: "\r\n"
sequence:
- lambda: |-
int sensorID=0;
float sensorTEMP=0;
float sensorRH=0;
std::string str(bytes.begin(), bytes.end());
//there are 4 sensors
//where<<< id:temperature:humidity
//"3:37.86:10\r\n"
if (sscanf(str.c_str(), "%d:%f:%f", &sensorID, &sensorTEMP, &sensorRH) == 3 ) {
if(sensorID==1) {
id(temp1).publish_state(sensorTEMP);
id(RH1).publish_state(sensorRH);
if(sensorID==2) {
id(temp2).publish_state(sensorTEMP);
id(RH2).publish_state(sensorRH);
if(sensorID==3) {
id(temp3).publish_state(sensorTEMP);
id(RH3).publish_state(sensorRH);
if(sensorID==4) {
id(temp4).publish_state(sensorTEMP);
id(RH4).publish_state(sensorRH);
button:
name: "Test Button 1"
on_press:
- uart.write: "1:1.1:111\r\n"
name: "Test Button 2"
on_press:
- uart.write: "1:2.2:222\r\n"
name: "Test Button 3"
on_press:
- uart.write: "2:33.33:44.44\r\n"
name: "Test Button 4"
on_press:
- uart.write: "giberish\n"
nickrout
(Nick Rout)
November 6, 2022, 4:17am
5
Can’t you skip the arduinos and deal with the sensors directly in esphome?
Thank you friend. Your code is working. Data is sent to Home Assistant
This is cool. I wasn’t aware of this approach. I think a lot of people get stuck with UART once you need a custom component.
mulcmu
November 9, 2022, 11:48am
8
I am not aware of this approach used anywhere else but that was my goal, find a way to help people read UART data without a custom component. It seems to be well suited for implementing simple UART devices where the code in the lambda would be 90% of the custom component code.
Key points are:
to make sure the debug logging gets triggered
the rx data is returned in std::vector<uint8_t> bytes
delimiter and timeout tweaked so rx data is presented in consistent format
direction: RX
if uart.write is used to tx data
Are you aware of any key differences in the two approaches such as performance or reliability?
mulcmu
November 10, 2022, 1:52am
10
The uart-logging-hack:
doesn’t have a setup()
if you need to perform some initialization (esphome.on_boot could be work around)
is constrained to cases where the rx data packets can be handled by the uart debug after mapping
only gets called when data arrives
I think reliability and performance should be similar between both approaches. The uart-logging-hack is only called when there is data to process but the framework is still checking and buffering the data in the background.
sjowett
(Simon)
February 3, 2023, 11:42am
11
I have problems with a very similar set-up which is a modified version of your suggestion to capture a Rx into the uart
[22:38:04][D][uart_debug:158]: <<< "1:4.12\n"
[22:38:08][D][uart_debug:158]: <<< "1:4.12\n"
[22:38:10][D][uart_debug:158]: <<< "1:4.12\n"
For some reason I think it is not being ‘captured’ by the if statement and the ‘batVol’ sensors don’t update when a message is received (I have adjusted names of variables from your example)
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: verbose
uart:
rx_pin: 16
tx_pin: 17
baud_rate: 115200
debug:
direction: BOTH
after:
delimiter: "\n"
sequence:
int sensorID=0;
float sensorBatVol=0;
//there are x sensors
//where<<< id:batteryvoltage
//"1:4.00\n"
if (sscanf(str.c_str(), "%d:%f", &sensorID, &sensorBatVol) == 2 ) {
if(sensorID==1) {
id(batvol1).publish_state(sensorBatVol);
if(sensorID==2) {
id(batvol2).publish_state(sensorBatVol);
if(sensorID==3) {
id(batvol3).publish_state(sensorBatVol);
if(sensorID==4) {
id(batvol4).publish_state(sensorBatVol);
api:
ota:
wifi:
ap:
ssid: "Esphome-Web-6Bdf8C"
password: "hnLdPNIUXUZq"
captive_portal:
- platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
name: "WiFi Signal dB"
update_interval: 60s
entity_category: "diagnostic"
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "Signal %"
name: "Battery Voltage 1"
update_interval: 5s
name: "Battery Voltage 2"
name: "Battery Voltage 3"
name: "Battery Voltage 4"
button:
on_press:
- uart.write: "1:4.1\n"
on_press:
- uart.write: "1:2.2\n"
I also incorporated the test buttons and loop back wire. The test button creates the response at the Rx but again the sensorBatVol never updates.
Things to note:
There are only 2 arguments. the Sensor number and the Battery voltage
I only seen to have a /n in my message (even though I added a /r as well on the Tx of the message sending ESP32.
Also - have I amended this line correctly?
sjowett
(Simon)
February 3, 2023, 12:05pm
12
btw just to add a bit more information. This is the write statement to the sending ESP 32 Tx port
Serial2.write("1:4.12", 6); // write data to serial port for onward transmission to Home Assistant
Serial2.write('\r\n');
I should be able to work this out but it’s got me beat!
sjowett
(Simon)
February 3, 2023, 12:19pm
13
ah ha found the error. It was formatting
I changed this:
int sensorID=0;
to this:
- lambda: |-
int sensorID=0;
Clearly it makes a difference!
Pier_pe
January 12, 2024, 8:33pm
14
Hi.
I’m trying to use your code to extract specific values from the string received by UART.
I receive this string:
57,67,251,0,1,0,31,249
I would like to get the first two values from this string and add them to the HA entity.
Will you help?
mulcmu
January 13, 2024, 4:32pm
15
Take a look at this post for some more general examples. Assuming you want the first two values in HA as numeric sensors, modify the section with sscanf to extract the first two values. Example was changed to use comma as delimiter between the values. The ==2 make sure sscanf reads two values.
//Sample uart text protocol
if (sscanf(str.c_str(), "%d,%d", &val1, &val2) == 2 ) {
id(sensor1).publish_state(val1);
id(sensor2).publish_state(val2);
Pier_pe
January 13, 2024, 6:56pm
17
The code probably works but not entirely correctly.
Code:
sequence:
- lambda: |-
UARTDebug::log_int(direction, bytes,',');
int val1=0;
int val2=0;
unit_of_measurement: "°C"
And these two entities in HA still have the “unknown” status
How do the ESPHOME logs look?
mulcmu
January 14, 2024, 1:07am
19
Pier_pe:
Is this from UARTDebug::log_string
or UARTDebug::log_int
? If it is log_int then you would just need this in the debug lambda:
id(sensor1).publish_state( bytes[0] );
id(sensor2).publish_state( bytes[1]);
The log_string debug output treats the received byte vales as the ASCII index for each character. For the log_int, it prints the byte values received formatted as integers.
Pier_pe
January 14, 2024, 6:28am
20
Amazing, it works perfectly.
Thank you very much.
luconedj
(Luconedj)
July 3, 2024, 3:38pm
21
Hi Gents,
@mulcmu this is a very old post with a very smart solution, that’s awesome!
You saved my day!
Best,
Luca
